Towing a 6x12 Trailer 500+ Miles
Discussion in 'Towing' started by 09TRDSport4x4, Aug 29, 2019.
  1. Aug 29, 2019 at 7:49 AM
    09TRDSport4x4
    09TRDSport4x4 [OP] OCD Approved!
    Nick
    Southwest Ohio
    I’m helping my parents move from OH to NC this weekend and I’ll be towing a trailer with the Tacoma. The truck is a 2009 TRD Sport with factory tow package, a 3” lift and 285/70/17 inch tires. I’ve got TSB rear leaf springs with an Icon AAL and I kept the overload leaf. The trailer is 6’ x 12’ and the sticker says it weighs 1600 pounds empty. If I had to guess, they’ll be loading it with around 1000 pounds but seeing as I’ve never towed anything bigger than a U-Haul tow behind, I’m a bit anxious about towing 2500+ pounds this far.
    Other than keeping the truck in 4th gear for the most part (I can probably get away with overdrive through the flat parts of Ohio but will definitely need 4th and likely 3rd or even 2nd in the mountains), any other advice or tips for a roughly 500 mile trip? All of my previous towing experience has been local and with much less weight so I want to make sure I’m mentally prepared for the trip. Any and all advice or tips are appreciated. Thanks!
  2. Aug 29, 2019 at 7:54 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Since you don’t have trailer breaks make sure to take it easy and leave extra space. It’s hard, but try and keep the load balanced, you want just enough tung wait to not let the trailer wag. But not so much that the truck is taking the brunt of it
    Mtn Mike likes this.
  3. Aug 29, 2019 at 8:05 AM
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    I think you got the right mind set & ditto on the brakes comment above. It's also nice if the trailer/hitch set up has a good weight distribution hitch. That makes a huge difference and you might be able to get one from uhaul if it's a rental scenario. I have 2013 TRD Sport, w/ tow package and pulled an enclosed 12' trailer w/ close to 4500# in it from PA to CA a few years back. I had trailer brakes and the aforementioned weight distribution hitch to help, but if you just take it easy I think you will be just fine w/ this weight and distance. I would not want to do what I did again but my Taco survived.
  4. Aug 29, 2019 at 8:11 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    just helped a friend load a trailer for a trip. yosemite to North Carolina. he called and told me it was exactly 2992 miles. (or something)
    his was a uhaul trailer 8x12? it felt huge!! it had that janky trailer brake system that uses the mass pushing on the tongue. i kid you not. i moved every single thing into that trailer solo. he's 70+ old, and i was happy to do it. i kept asking, "you sure you want to take this?". there was a small safe, boxes of coins, guns. i filled that thing up pretty tight, and at the end we pushed a big cement pig (lawn ornament) 200lbs? into it and two upholstered chairs. i bet his trailer was 5000 lbs.
    he said his truck towed fine!! no issues at all. he got 12mpg. not bad since he crossed the continental divide. but his truck is stock height and stuff. your bigger tires are gonna hurt.
  5. Aug 29, 2019 at 8:17 AM
    YamaDirtrider
    Josh
    Elizabeth CO
    A weight distribution hitch wound be nice but probable not available with the drop needed.
  6. Aug 29, 2019 at 8:22 AM
    Shellshock
    Iowa
    You’ll be fine. Just be sure to load the trailer to get the weigh distributed so it isn’t too tongue or tail heavy.
    I’ve towed a 7x14 thousands of miles at this point and the truck has never had an issue.
  7. Aug 29, 2019 at 8:27 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    Oh, I’m well aware the tires are gonna hurt my gas mileage... I’m lucky to get 16-17 mpgs on the highway without towing. I fully expect to get 10-12 if I’m lucky.
    And yes, weight distribution and making sure the trailer is level are my two biggest concerns right now. Other than that, I’ll definitely be taking it easy. I don’t care if I get dirty looks or honked at, I’m not doing anything stupid with a trailer of this size behind my truck.
  8. Aug 29, 2019 at 8:28 AM
    sonoran
    sonoran Big Loop
    Brob
    Flagstaffrica, AZ
    Tacoma 4X4 3RZ
    Tires: BF Goodrich TA KO2 235/85-16 Matching Spare (in rotation) Rear Suspension: King 2.5 shocks Custom Alcan springs OME greaseable shackles Front Suspension: King 2.5 coil overs Total Chaos UCAs New OEM LCAs Total Chaos Steering knuckle gussets Total Chaos Steering rack bushings Rear Diff: ARB locker (Zuk-Built diff) ARB HD Compressor Rear diff breather extended Armor: Custom full-coverage skid plates Stubbs sliders CBI rear bumper CBI Frame plates Engine: 3RZ Custom over leaf spring exhaust LCE Heavy Flywheel, Pro clutch LCE Stage 1 Head LCE Stage 1 Cams LCE Balance Shaft Delete Bed: Flip-PAC Camper Spray-in bed liner Footman’s loops Canyon Cooler KIST bottle opener Recovery: Custom and very complete tool/service kit including angle grinder and impact HiLift (I know how to use it) and/or Solo skid floor jack depending on trip Glock e-tool (shovel) Strap Interior: Fire Extinguisher Saddle Blanket seat cover Alpine sound Exterior: Anza Headlights WeatherTech wind deflectors “One Less Sprinter” bumper sticker
    Its been said before and I'll say it again. Load and patience. Make sure your hitch drop is right so the trailer sits level. More weight in front of the trailer axle than rear and give yourself room to stop! I have a first gen standard cab with 3RZ and I regularly tow a 6x8 box trailer with a dirtbike in it. No problems. I also tow this a lot...
  9. Aug 29, 2019 at 9:28 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    You probably already know this, but use a drop hitch to keep the trailer level while towing.
  10. Aug 29, 2019 at 9:34 AM
    aficianado
    back to bone stock.
    yea. my unscientific reasoning also tells me the lift and tires reduce your towing capacity. my friends tow a giant ocean fishing boat (they share the boat). both have equal duramax trucks. one is lifted. the stock one tows everything way better. the long drop hitch puts extra (moument) lever on the back of the truck..you feel the boat more with the taller truck. less power and you feel the load back there.
    i think you'll be perfectly fine tho..smooth and steady wins the race.
  11. Aug 29, 2019 at 9:44 AM
    Greg3492
    Greg3492 Well-Known Member
    Leadville, CO
    2012 White Access Cab TRD Off Road
    Last year I pulled a very loaded 6x12 uhaul from Huntsville Alabama to Leadville Colorado (10,000 ft elevation) and had no problems. I have the same aal. I'll reiterate leaving plenty of space between what's ahead of you, especially going downhill. Fuel economy was awful so I stopped tracking it.
  12. Aug 29, 2019 at 9:45 AM
    Sparky.
    Sparky. Bought, built, totaled
    Dawson
    Enumclaw Washington
    ‘14 AC 6MT -R.I.P, ‘08 cummins
    If it’s an enclosed trailer it might feel heavier than it actually is because of the wind drag. I regularly tow my 6x12 single axle trailer (no trailer brakes) with my little tractor in it (total close to 3500lbs) and it’s no issue. Only thing to watch if you’ve never towed a trailer that big, it will be wider than your truck so you have to get used to driving in the dead center of the lane. Doesn’t take much to touch the lines on narrower streets with a wide trailer
  13. Sep 1, 2019 at 8:55 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    Well, I made it. The trailer definitely weighed in on the heavy side and the ridiculous rain and wind we drove through was stressful. But overall, it was an uneventful drive and the truck did great. Backing it into the driveway was an adventure though...
  14. Sep 1, 2019 at 11:53 AM
    aficianado
    back to bone stock.
    Well done!
  15. Sep 1, 2019 at 8:44 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Glad you made it with no issues
