Towing a 4x8 Uhaul Trailer in '11 Manual
Discussion in 'Towing' started by mikeshardtacoma, Dec 14, 2020.
  1. Dec 14, 2020 at 12:20 PM
    mikeshardtacoma
    mikeshardtacoma [OP] Member
    2011 Grey Tacoma TRD Offroad DoubleCab
    My family and I are moving across the country soon, and I will be towing a small 4'x8' UHaul trailer along with me. There won't be much other weight inside the cab or the bed, as we're taking two vehicles. I know it isn't much weight, but I have never towed in this truck and my towing experience is limited. Are there any tips for doing this, or any advice? My truck is a 2011 TRD Offroad DC SB with the V6 and 6-speed manual. The owners manual says not to use sixth, but I don't want to completely kill gas mileage and much of the drive will be flat. I don't know for sure if I have the towing package or not, either. Any help is greatly appreciated!
  2. Dec 14, 2020 at 2:29 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    It’s all about the total weight. However you can’t haul that much in a 4x8 trailer. Loading it up with household items the weight should probably be under 1000 lbs plus weight of the trailer. The truck will have no problem with this. You’ll hardly know you are towing anything behind you. Just drive a little slow and remember it takes longer to stop with a trailer behind you. Many trailer tires are not rated for over 65 mph so keep that in mind.
    Also as I have stated many times here rather than towing a trailer full of stuff look into moving pods. They deliver what ever size you want, you load it up and then they pick it up and deliver it to your destination. Easy peasy, no towing hassles.
    SLeeper512 and Lastplace like this.
  3. Dec 15, 2020 at 12:04 AM
    mikeshardtacoma
    That helps a lot, thanks. We looked into moving pods, but we're leaving California, and since there are so many others doing the same thing, they're charging a hell of a lot more to do it.
  4. Dec 15, 2020 at 12:24 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You don’t want to lug the engine.
    If you’ve driven a manual long enough, you’ll know what gear to be in.
    Gas is cheaper than engine or transmission repair bills.
  5. Dec 15, 2020 at 12:35 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Review the Towing Bible tread for info.
    The Tacoma Towing Bible | Tacoma World
    You need to load so some tongue weight for handling and the thread lists all that stuff as well as overall gross weight.
    Your mileage will drop to 10-12 towing most probably.
    Braking will lengthen so have all drivers do a hard stop early so they really know/feel the increased distance for safety.
    The actual tow will be a breeze.
  6. Dec 15, 2020 at 2:26 AM
    mikeshardtacoma
    If I'm just cruising at 60-65, I imagine 6th gear won't lug the engine, right? Obviously, incline/decline or passing (in the rare occasion that I need to pass someone at that speed) would be done with downshifting.
  7. Dec 15, 2020 at 5:21 AM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    Just use common sense and you’ll be fine. I occasionally use 6th gear while towing but only on flat ground or small declines. Big declines I like 5th or even 4th just so I have more control because stock brakes aren’t great. If you feel it lugging, just drop a gear. It’s not going to hurt anything unless it’s literally lugging for hours and hundreds of miles.
    TnShooter likes this.
