Towing a 17ft Trailer with a 4cyl Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ftwth, Sep 4, 2018.
  1. Sep 4, 2018 at 2:11 PM
    ftwth
    ftwth [OP] New Member
    2015 Toyota Tacoma 4X4
    Has anyone here had any experience towing a 17 ft 3000 pound travel trailer? I am considering getting a trailer but need to know how it will go
    Thanks for the input
  2. Sep 4, 2018 at 2:25 PM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
  3. Sep 4, 2018 at 2:30 PM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Welcome aboard:hattip:. 3K seems a bit much for a 4 popper
    Alexely999 likes this.
  4. Sep 4, 2018 at 2:32 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Lol you're gonna hate it. Especially if you have a manual. Have fun hill starting that or backing it up. Hope you like the smell of burning clutch
  5. Sep 4, 2018 at 2:34 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I got caught towing a 5x8 enclosed trailer across the Mohave desert in a wind storm. My little 4 banger taco really struggled back then. I was scared I was going to run out of gas. That was the last 4 cyl I ever owned. I think if you buy that trailer,you will also buy a bigger truck soon after.
    TireFire likes this.
  6. Sep 4, 2018 at 4:52 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I've seen it done with a 1st gen 4cyl with a manual....very similar trailer as you described. He had another 700 pounds on top of it. He pulled it. But he was a very good driver and only had to go about 20 miles with it with no serious large hills/mountains and didn't go to fast. He only did it because he had to move the thing that day and his plan to use his dads full size f-150 fell through.
    It will work in a pinch....but certainly not preferred.
    Edit....we guys with 4cyl manuals have pulled lots of things....I have pulled F-350 duallies with beds full of gravel out of snow banks and ditches....but that's for short distances and in 4LO when I did it....not on long road trips where there are large hills, mountains and such.
  7. Sep 4, 2018 at 4:57 PM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    ftwth[OP] and Alexely999 like this.
  8. Sep 4, 2018 at 7:40 PM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Will it pull it, probably if it is rated for that level. Will you shortly buy another tow vehicle to haul that camper? Yes you will.
  9. Sep 5, 2018 at 6:35 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    No.
    I honestly wouldn’t do it with a 6 cyl.
    No way the travel trailer is 3,000lbs... your going to have stuff in it that will quickly weigh it down.
    Truck will not have the weight to safely control movement of the trailer.
    My advice to anyone who tows trailers regularly over 3,000lbs and over distances needs to buy a full size.
  10. Sep 5, 2018 at 7:38 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    NO
    PackCon likes this.
  11. Sep 5, 2018 at 8:25 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    it will tow 3500 lbs, been there done that with a gen1 i4 and worked out well. Don't expect to win any races and use those upper RPMs when needed. I would do 65 in 3rd gear to maintain speed a times
  12. Sep 5, 2018 at 9:07 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    The comment about burning more fuel is true!
  13. Sep 5, 2018 at 9:23 AM
    stomachbuzz
    stomachbuzz Well-Known Member
    Silver Spring, MD
    2005 V6 6spd!
    I towed a 5x8 utility trailer back when I had a 4cyl Tacoma. Trailer weighed probably 400lbs? I had a 52" stander mower (900lbs), and a 36" walk behind (500?) on it. Definitely had a hard time keeping up with traffic at 60mph on flat ground. Constantly ringing it out.
  14. Sep 5, 2018 at 11:29 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Not a good idea, it will be straining when pulling it, & it will be dangerous stopping it. I've not tried it with my Tacoma, but did try it when I had my 4 cyl. Mitsubishi 4X4, that was much stronger than my Tacoma 4 cyl., with my bass boat, it will do it, but don't do it.
  15. Sep 5, 2018 at 12:05 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I would guess that trailer is more than 3000 pounds. Just towed a friends little civic. Car plus trailer was ~4,700lbs. It was fine but I have the V6 with tow package.
  16. Sep 5, 2018 at 1:45 PM
    potstech
    Midlothian, Va
    2013 DCLB
    If it is a true travel trailer and not a popup or other low sitting trailer then you also have to consider wind resistance as well as weight. Sail area of a full sized trailer even a 17 foot will add to the strain n the truck.
  17. Sep 5, 2018 at 3:42 PM
    Newfiebruh
    Tom
    what's with people talking about stopping it? they are aware the 4cyl and 6cyl are identical or than the motor right? unless they are thinking about the absolute base model which has only slightly worse braking
  18. Sep 5, 2018 at 3:44 PM
    Newfiebruh
    Tom
    The v6 are rated at 6500lbs and are only slightly heavier than the 4cyl (and not even heavier in certain configurations) If the v6 is rated at over double the 3k lbs im sure the 4cyl can handle it (weight and stability wise)
  19. Sep 5, 2018 at 5:24 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    My trucks are always reg. cab. I don't know what they weigh, I just know they aren't heavy enough to stop a bass boat very well. Yes, it will stop it, but you must learn to begin stopping very early & as long as you've got plenty of room it's fine, but those other times when a quicker stop is needed, is when you will realize they aren't good for stopping loads.
