Towing 6x12 Cargo Trailer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma1951, Jul 17, 2017.
  1. Jul 17, 2017 at 1:36 AM
    tacoma1951
    tacoma1951 [OP] New Member
    2006 Tacoma SR5 4x4 V6
    Hello Everyone,
    I have a 06 Tacoma SR5 with a V6 and the tow package. I will be buying a 6' x 12' tandem axle box trailer soon and hauling my Harley Tri-Glide (about 1200 lbs) to Arizona this winter. Yes, I will be a snowbird. The trailer does have brakes and I already have the setup to connect the brakes to my Tacoma. Any thoughts on this? Has anyone pulled a similar load with their Tacoma?
  2. Jul 17, 2017 at 2:00 AM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    I pulled a 6x12 uhaul box trailer from Houston to Chicago loaded to the max. You'll be fine, just obviously be careful with the snow. Gas mileage will blow however
  3. Jul 17, 2017 at 5:02 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    I moved our entire household stuff 450 miles (multiple trips) using this exact setup with my 05 OR V6. No problem at all. Kept it around 60 MPH, mileage was about 13. Just make sure the trailer brakes work and are adjusted. Keep some weight on the trailer tongue, but most weight over trailer axles. If you are not used to towing, watch when maneuvering in tight spots like gas stations. That trailer rear end can easily bash into things.
  4. Jul 17, 2017 at 5:21 AM
    turkeyeye
    turkeyeye Well-Known Member
    Henry
    Western NC
    You didn't say where you would depart as to a mountainous route could come into play. Be sure you have sufficient and overrated tie downs in the trailer for the HD as it could slide on curves, slow down then. Be more concerned about securing the HD than capacity to tow.
  5. Jul 17, 2017 at 7:14 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Have a 5X10 single axle open utility trailer, primarily to tow 4-wheeler - do you really need a 2-axle trailer that big?
  6. Jul 17, 2017 at 7:34 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I pull a 7x16 foot enclosed trailer with my DCLB. It tows great. The brakes actually crapped out on the trailer and stopping got a little sketchy during a trip awhile back, but the truck handled it fine.
  7. Jul 17, 2017 at 7:51 AM
    Muddinfun
    Muddinfun Well-Known Member
    In addition to all the good info above, make sure you get one with a ramp door and a side man door. Also, having a spare tire for the trailer is good insurance that you won't get a flat.
  8. Jul 17, 2017 at 10:14 AM
    Bobcdn
    Bobcdn Well-Known Member
    WTB; 2nd gen well built Tacoma
    I ended up buying a 6x12 enclosed single axle all aluminum trailer. Trailer weighs under 1000 lbs with a 3500 lbs capacity.
    Single axle is generally easier to tow and if you are not moving heavy loads (3000 lbs+)... plus you need to be careful turning corners with the tandem axle as it chews up tires if you are not careful.
    Mine does not have brakes- but I may eventually put surge brakes on it.
  9. Jul 17, 2017 at 10:43 AM
    wicycletester
    wicycletester Well-Known Member
    se wisconsin
    several
    It's not as much about the weight as it is about wind resistance. I pulled a 6x12 about 1,000 miles with 3 dirt bikes. Trailer was extra tall. Got 9 mpg on one tank in the wind... Truck will be fine, just be patient and try to keep speed below 70 if you can. Don't use overdrive.
  10. Jul 17, 2017 at 10:49 AM
    Toyko Joe
    Toyko Joe Here for the pictures
  11. Jul 17, 2017 at 11:04 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I towed a 6x12 box trailer that was honestly way overloaded with heavy tooling coming in around 3k lbs from Missouri to Arizona. It was a pain in the ass going up the mountains (really needed a v8) , but once past that in the flat it was surprisingly good. Gas mileage takes a huge hit and you have to give your self much more time to brake and accelerate. But it will do it.
    Stay out of overdrive if you have an auto.
  12. Jul 17, 2017 at 11:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    To Arizona from where? Distance matters.
    You might like having a scanguageII installed with the X codes for your trans temps. I'm sure your tow package has an auxillary cooler already, but you may (or may not) find that you'd treat your truck well to upgrade it.
  13. Jul 17, 2017 at 11:53 AM
    tacoma1951
    Traveling from Kansas City to Phoenix via I 44 & I 17 right after Christmas. Coming back in April. Need the extra space for some other stuff (not heavy, just bulky) besides the Harley. Good suggestions from everyone. Thanks.
  14. Jul 17, 2017 at 12:01 PM
    Muddinfun
    If the ramp door has cables for the wind up spring, get some hi viz pool noodles. Split them and slip them over the cables when the ramp is down. This will help prevent people from walking into the cables, and if they do walk into the cable, at least it won't gash their nose open. You'll probably need 3 noodles. Put 1 1/2 noodles on each cable.
    Toyko Joe likes this.
  15. Jul 17, 2017 at 12:04 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    This is my summer travel load, ~5,000 lbs once you add the dirt bikes and beer.
    Mileage is about 10 without a headwind. It pulls fine now that I have a supercharger - it was pretty miserable without it.
    EnonEye likes this.
  16. Jun 22, 2020 at 5:47 AM
    gr8tacsprt10
    gr8tacsprt10 Well-Known Member
    Vince
    Kirtland AFB, New Mexico
    I’m about to move also from Albuquerque to Phoenix, planning to haul 1,500 lbs. U-Haul only has surge brakes on 6x12?
    2010 DCSB
  17. Jun 22, 2020 at 8:22 AM
    Toyko Joe
    Surge brakes are great. Would have them on every trailer of mine if it was practical. My $.02
  18. Jul 13, 2020 at 5:51 AM
    gr8tacsprt10
    Vince
    Hauling 2,700 lbs ABQ to Phoenix today!
    SoCal_Erik likes this.
  19. Jul 13, 2020 at 12:20 PM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    I've pulled both a 4x8 and 6x12 uhaul trailer with my old 14 Tacoma. The 6x12 pulled so much better when it was loaded down. Yeah I could feel it in the loss of power but it wasn't bouncing all over the place on the highway like it did when it was empty. The Tacoma is a light truck so that trailer just wants to bounce all around it.
  20. Aug 16, 2020 at 11:51 AM
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    I’m seriously considering getting the 6x12 for my move from Arizona to Michigan ~1,900 miles. A little nervous though as I have never towed with my truck.
    Jaypown likes this.
