Towing 4 x 8 Uhaul Trailer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lpranger467, Jan 5, 2022.
  1. Jan 5, 2022 at 11:02 AM
    lpranger467
    lpranger467 [OP] Well-Known Member
    Lawrence
    2020 Tacoma TRD
    None yet
    Towing a 4 x 8 uhaul trailer about 1000 miles. I know about using ECT, but thoughts on staying in D instead of 4 for flat areas ? (4 revs very high)
  2. Jan 5, 2022 at 11:05 AM
    perkj
    perkj Well-Known Member
    how much total weight will you be pulling (including trailer weight)?
    Chew likes this.
  3. Jan 5, 2022 at 11:06 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A 4x8 trailer is nothing. Just drive it. If you feel it getting weird, then do what you said.
  4. Jan 5, 2022 at 11:06 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Keep it in D and let the TCM take care of the gearing. You will experience a lot of gear searching but I found it to still be better than keeping it in 5th.
    lpranger467[OP] likes this.
  5. Jan 5, 2022 at 11:11 AM
    lpranger467
    Lawrence
    2020 Tacoma TRD
    None yet
    I'm guessing I'll be putting under 500 lbs inside. Trailer is probably less than 1000 lbs. Then maybe 250 in the bed of truck
  6. Jan 5, 2022 at 11:14 AM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    5x8 v nose. Trailer is 700lbs empty and I had ever inch filled. Towed from CA to NH. 3200 miles. For the most part keep it in d. Hills go to 4th20210606_150515.jpg
  7. Jan 5, 2022 at 11:15 AM
    perkj
    you'll have no issue leaving it in D and ECT on.
  8. Jan 5, 2022 at 11:15 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    You’re within the 3500 lbs. let me know how you make out. I am thinking of towing 2500 - 3000.
  9. Jan 5, 2022 at 11:15 AM
    MGMDesertTaco
    ECT and leave it in sport (4) per the owners manual.
    Tacospike likes this.
  10. Jan 5, 2022 at 11:17 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Make sure to check the wheels
  11. Jan 5, 2022 at 11:18 AM
    Tacospike
    Two Trucks
    :eek:
  12. Jan 5, 2022 at 11:19 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    About 1,300lb or so total load using my own 4x8. I barely knew it was back there.
  13. Jan 5, 2022 at 11:19 AM
    lpranger467
    Lawrence
    2020 Tacoma TRD
    None yet
    Ok thanks, I just didnt want to burn too much gas in 4th
  14. Jan 5, 2022 at 12:15 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Do you have a scanguage or similar to monitor trans temps? I see that you've got a 2020 and mid-model year toyota decided to delete the aux trans cooler, so be mindful of those temps while you're towing so you don't cook your trans fluid
    Vegasstunts and MGMDesertTaco like this.
  15. Jan 5, 2022 at 1:08 PM
    lpranger467
    Lawrence
    2020 Tacoma TRD
    None yet
    I actually just bought a second Taco, a 22 with the 3.5 and it says it has a trans cooler, (which I'm pretty sure I see from the front)
  16. Jan 5, 2022 at 1:11 PM
    Vegasstunts
    16 TRD sport
    All of them.
    Maybe they went back to them. Cuz they definitely pulled then for a few years
  17. Jan 5, 2022 at 1:18 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    If they did I feel even more cheated than I did upon initial discovery
  18. Jan 5, 2022 at 1:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe the “cooler” is now just the one in the radiator. There was an external one separate for he radiator on earlier models. But for reasons unknown. Toyota no longer finds it necessary.
    Chew, skeletron and zoo truck like this.
  19. Jan 5, 2022 at 1:18 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    S5. you'll not know its there half the time and you'll get great fuel economy. I tow my 5x10 utility trailer thats mostly aluminum with a 500 lb. sled, or lawn tractor that weights less...no problem in S5.
  20. Jan 5, 2022 at 1:19 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's a little confusing there as they count the trans cooler at the AT and the one in the rad as coolers also. The one that you can see on the left side of the Taco in front of that rad (rectangular, not the tubular PS cooler) is the AT cooler that went away.
    TnShooter likes this.
