Tow Package vs. Standard Towing Capacity Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaulK, Oct 22, 2013.
  1. Oct 22, 2013 at 2:02 PM
    PaulK
    PaulK [OP] Life is hard. It's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    Can someone help me understand the significant difference in the factory towing capacity ratings between a standard (non-Tow Package V6) and Tow Package truck? The Toyota web site says the factory rating for a standard Tacoma is 3500 pounds, and a Tow Package is 6500 pounds. My 2013 Access Cab Baja Edition has the exact same 4-leaf springs and running gear as my buddy’s SR5 Double Cab with the Towing Package, so why the 3000 pound difference? I understand that I don’t have the oil and transmission coolers, sway control, or trailer brake connection, but does that really make a 1.5 ton difference?
    To further confuse things, my Baja came with a dealer tow hitch and a 4-pin connector – I’ve been told by several people that this was actually added at the TX assembly plant when the Baja conversion was done, and that all Bajas come this way, but I don't think it matters who put it on. My hitch has a sticker that says the truck now has a 5000 pound towing capacity. Other than the connectors, our hitches look nearly identical…but am I missing some significant difference here? Can I get a different hitch to get up to 6500?
    Thanks for the help.
  2. Oct 22, 2013 at 2:23 PM
    theTupper
    theTupper White and Nerdy
    Jacob
    Raeford, NC
    '10 DCSB Off Road PreRunner
  3. Oct 22, 2013 at 2:27 PM
    brochacho
    brochacho Well-Known Member
    Vancouver, WA
    2016 4Runner SR5
    Add a 130A alternator, heavy duty battery to that list and there is your 1.5 ton difference.
  4. Oct 22, 2013 at 2:32 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The 1.5 ton difference is largely the factory hitch. A non-tow package equipped Tacoma is rated to tow from the bumper where as a factory tow package has a class IV hitch installed. The bumper can only handle 3,500 lbs and a 350 lb tongue weight. I installed an aftermarket class III receiver on my Tacoma and would not hesitate to tow over the 'rated' 3,500 lb capacity so long as you have the truck wired properly and a trailer with brakes (and not to exceed the rating of the receiver).
  5. Oct 22, 2013 at 2:59 PM
    PaulK
    Paul
    Bumper vs. hitch makes sense. I guess I still don't get the difference between my hitch (dealer) and a tow package hitch. Are they different classes? If so, can I swap to a beefier hitch to achieve the 6500 pound rating - would also add a trans cooler, trailer brake wiring, bigger alternator and a better battery.
  6. Oct 22, 2013 at 4:39 PM
    brochacho
    Vancouver, WA
    2016 4Runner SR5
    Yes there are different classes. You will need to check with the dealer and see which class they put on. The class that comes with the tow package is a Class IV.
    If you add all the things you mentioned and add in oil cooler to list then verify that they installed a Class IV hitch then I would think you would basically have the factory tow package and could achieve the 6500 pound rating.
  7. Oct 22, 2013 at 4:43 PM
    Pugga
    Massachusetts
    There should be a sticker on the receiver itself somewhere telling you what the receiver is rated for. If it says 500# tongue weight and 5,000# trailer weight/550# tongue weight 5,500# trailer weight with WD hitch, then you have a class 3 hitch, if it says 650# tongue weight, 6,500# trailer weight, then you have a class 4. I have never seen an aftermarket class 4 receiver for the Tacoma so unless it's a Toyota hitch, it's likely a class 3.
  8. Oct 22, 2013 at 4:48 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you have a look at the factory hitch you'll see that is also bolted to the bumper along with the frame just a bit more pull and support.
  9. Oct 22, 2013 at 5:06 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    With the factory towing package the bumper is actually attached to the factory hitch, not the frame at all:(
  10. Oct 22, 2013 at 6:32 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Mine came with full factory tow package. Lots of Baja's up north do not come with factory tow. To me the number one thing you are missing is the tranny cooler but it is an easy add on.
  11. Oct 23, 2013 at 5:25 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Really? Think you better have another look.
  12. Oct 23, 2013 at 5:34 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Toyota is not about to cover some one else tow assembly they know what there tow hitch will stand but not what an aftermarket one will. It's not just the hitch either wiring, coolers (trans and oil for the auto) larger battery and alt. I also cry foul with a 4 wire hitch assembly because Toyota says nothing over 1,000# with out brakes and with 4 wires that ain't going to happen does not seem likely that they would call that a 6500# hitch.
  13. Oct 23, 2013 at 6:06 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    +1
  14. Oct 23, 2013 at 3:46 PM
    robssol
    Rob
    S. Wisconsin
    Don't need to look again, had the bumper off the truck last week, (hitch & bumper rusting all to hell:() Rest of the truck is in good shape, runs great. I don't think I would put 6500# on that hitch in it's current condition.:confused:
  15. Oct 24, 2013 at 5:41 AM
    PaulK
    Paul
    Well, the hitch I have is a Toyota product - the one that you can find in the accessories list on the web site - and it says 5000 pounds total on the sticker with no other tow package equipment in place when I bought it. So I need to determine if the extra 1500 pounds is due to the other tow package items (coolers, wiring, battery, etc.) or if my hitch is in fact different from a tow package hitch. If it's the same I can add all the other tow package stuff (except sway control). I wonder if the dealer could do this and then "approve" the 6500 pound rating.
  16. Oct 24, 2013 at 5:48 AM
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    maybe im mistaken but isnt the 3500lb the towing capacity of the 4 cylinder and the 6500lb towing capacity for the 6 cylinder? And also to my understanding the "towing package" would just mean the truck came with a factory class III or IV hitch reciever. I have the 4 banger so i could be wrong
  17. Oct 24, 2013 at 6:20 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    its your hitch, you dont need that sway control.
  18. Oct 24, 2013 at 6:44 AM
    PaulK
    Paul
    So, If the dealer can/will replace my hitch with a true tow package hitch, I'll get the 6500 rating? I would still add the trans cooler, alternator, battery, and a brake controler. Would pass on the oil cooler, and assume I can't get sway control added.
  19. Oct 24, 2013 at 7:08 AM
    jake72
    Jake
    N.E. PA
    I would say you would be good to go then. sway control probably has sensors and computer and would be expensive.
  20. Oct 24, 2013 at 7:14 AM
    PaulK
    Paul
    Agreed regarding the sway control, and don't think it's necessary - would be nice for sure, but not required.
    I emailed my dealer to see if the tow package hitch is available, and also asked about the other parts. I would probably install an aftermarket trans cooler, as it would be less expensive and probably better than the factory unit. I can source my own battery as well. Ideally I would have the dealer add the hitch, the 7-pin connector, the trailer brake harness, and the 130 amp alternator.
