Tow hook install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jbrnigan, Mar 27, 2015.
  1. Mar 27, 2015 at 2:35 PM
    jbrnigan
    jbrnigan [OP] Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    First removed factory passenger side transport bracket. Purchased Curt pt. # 22430 tow hook, rated for 10,000 lbs. (Amazon)
    Purchased (2) 12 x 1.25 x 60 mm grade 8.8 (equivalent to SAE grade 5) metric bolts. Tow hook bolt centers match factory holes. Reinstalled bracket and tow hook, torqued to 80 ft.lbs. 8.8 metric bolts are rated at 120,000 psi tensile strength and 60,000 psi shear.
  2. Mar 27, 2015 at 3:22 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Interesting that the hole spacing is the same.
    Another option offered by Toyota (Part Number: 5196135080) compensates for the off-axis angle of those factory holes:
    Others have experienced this with the Curt style of hook in heavy pulls:
    mmessier2, ebrisse and IronPeak like this.
  3. Mar 27, 2015 at 8:31 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
  4. Mar 27, 2015 at 8:53 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  5. Mar 28, 2015 at 4:07 AM
    jbrnigan
    Midwest
    Your recovery solutions should reflect the kind of wheeling you actually do (unless your just a poser). In 40 years of owning 4 WD vehicles, I've only needed a tow a handful of times and was successfully recovered with a "hook" each time. A quality 10,000 lb tow hook will move a lot of iron for 10 bucks. But, will not substitute for every situation that you could find yourself in.
  6. Mar 28, 2015 at 4:29 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Thank you, just ordered the hook and a new D ring receiver based recovery point. The Harbor Freight receiver hook looks pretty terrible after four years of use.
    Howard
  7. Mar 28, 2015 at 6:43 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
  8. Mar 28, 2015 at 1:02 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Do you think mounting it 25 degrees off axis poses any potential issues?
  9. Mar 28, 2015 at 2:39 PM
    jbrnigan
    Midwest
    Yes, no and maybe - Is every pull perpendicular to the axis? Hey, I installed a "hook". Have never had anything other in 40 years. (yep, I'm a dinosaur) Hope I never need it. If I do, hope it works. If it doesn't, shame on me for getting that stuck. bad judgment or a bad decision. Maybe just walk away and call the insurance guy.
  10. Mar 28, 2015 at 2:42 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I use the one that came on the truck and it works great.
  11. Mar 28, 2015 at 3:03 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Sorry to beat the topic to death and do appreciate your responses.
  12. Mar 28, 2015 at 8:12 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    That would likely be fine for a winch pull (slowly applied loads) but a snatch strap recovery can put loads well in excess of 10k lbf for short periods of time. I would not use such device with a snatch strap.
    Gunshot-6A likes this.
  13. Mar 29, 2015 at 4:45 AM
    SigSense
    True, I’d never snatch/shock load with a carabiner, for those instances it’s good to use industrial rigging equipment such as steel shackles that are rated for 50,000 lb test or greater. Industrial tool shops typically stock galvanized anchor shackles with screw pins (as opposed to a bolt pin or loose pin). These are commonly used with hoists and overhead cranes so if you have a crane supplier in your neighborhood that's a good source.
  14. Mar 29, 2015 at 4:57 AM
    jbrnigan
    Midwest
    Previous poster, EDDO, suggests not using a 10,000 lb tow hook for the same reason. Moral of this thread, don't get stuck - if you do, ask someone on this forum how to get unstuck, what equipment to use, how much to spend, which brand of equipment works best, and their personal anecdotal recovery experiences from some remote off road destination. I'm still looking for the wheat in the chaff. (ps, this thread started as - here's a simple, cost effective, recovery solution for a Tacoma without a front tow hook / or not)
    KTM753 likes this.
  15. Mar 29, 2015 at 6:23 AM
    qnyla
    NM
    Moral of this thread is be careful. The hook you posted about is just fine, within limitations, which were mentioned by EDDO. Not sure what you really want from your thread.
    The use of highly elastic snatch straps (essentially huge rubber bands) have not been around for decades, and they impose much higher loads for short periods of time than traditional tow straps/chains, etc and can kill people when something lets lose. It seems perfectly reasonable to me to discuss these topics in a thread about tow hooks.
  16. Mar 29, 2015 at 8:51 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    OP - I was simply trying to point out some possibly better options. You have very well thought-out reasoning for your choice.
    My main concern with the hook oriented downward is the strap simply falling off when not under tension.
  17. Mar 29, 2015 at 9:29 AM
    jbrnigan
    Midwest
    You are absolutely right, it can and does. Unfortunately, this off the shelf solution does not allow for the hook to point up. I keep a hand full of zip ties in my glove box and have used them in the past to secure the tow loop to the hook on similar downward facing hooks. Never had the issue on my personal recoveries, but they come in handy if you get a little slack in the tow line.
  18. Apr 1, 2015 at 1:36 PM
    hetkind
    Howard
    Johnson City
    The cheap tow hook upgrade is getting expensive...
    $9.99 for the hook from Amazon
    $34 for the really nice smitty built d-Ring receiver recovery point
    $7.98 plus tax for the bolts at TSC
    $45 to get the dog microchipped on the way to TSC
    So the ten dollar hook cost me almost a C note. On the other hand, it installed really easy.
    Howard
    Benzdriver81 likes this.
  19. Apr 1, 2015 at 1:59 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    But you saved enough to get the dog microchipped by not buying this instead of the Smittybilt. That is the TW math! :D
  20. Apr 1, 2015 at 5:11 PM
    hetkind
    Howard
    Johnson City
    I would rather fail an inexpensive recovery point that fail the hitch or frame...
