Tow harness wiring diagram
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Suplex, May 6, 2019.
  1. May 6, 2019 at 7:17 AM
    Suplex
    Suplex [OP] Unknown Member
    Shane
    California
    ‘15 Prerunner TRD Sport v6 DCLB
    Would like to tap into the wire for the tow reverse lights, but not sure which color it is. Is there a wiring diagram?
  2. May 6, 2019 at 9:17 AM
    Muddinfun
    Muddinfun Well-Known Member
    Suplex[OP] likes this.
  3. May 6, 2019 at 9:32 AM
    Suplex
    Shane
    California
    Perfect, thank you!
    Muddinfun likes this.
  4. May 6, 2019 at 9:17 PM
    caribe makaira
    Caribbean, Puerto Rico
    2015..no color change
  5. Jun 1, 2019 at 10:41 AM
    thebeardedbeerguy
    thebeardedbeerguy Well-Known Member
    Newnan, GA
    2015 Tacoma PreRunner SR5 with towing package
    Dealer installed (running boards - part of purchase deal) Weather Tech (floor liners, headlight guards, bug shield); Vent Shade (rain guards, door sill protectors); Color matched body side molding; ARE color matched rear hatch; rubber bed and tailgate liner; Ranch Hand brush guard; SteelCraft Elevation rear bumper; 4" auxiliary running/stop/turn for place in bumper; led light to light up "SteelCraft" logo in bumper.
    Can you tell me the color code on the reverse light itself?
  6. Jun 1, 2019 at 12:31 PM
    Suplex
    Shane
    California
    Yellow.
  7. Jun 1, 2019 at 12:48 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I did just this exact same thing on my trailer. 5 pin flat connectors and the needed 7 round to 5 flat are available at Bass pro shops... Noticed them at Auto zone after i bought mine.
    The wire for reverse on my plug for the trailer was blue.
  8. Jun 1, 2019 at 12:56 PM
    thebeardedbeerguy
    Newnan, GA
    Thank you kindly. I was not clear. I want to tap into the reverse light in the tail light assembly. Again, thank you.
  9. Jun 1, 2019 at 1:00 PM
    Muddinfun
    Pop the taillight out. There will be 2 wires going to the reverse light bulb. The ground will be white/black. Connect to the other one.
    thebeardedbeerguy likes this.
  10. Jun 1, 2019 at 1:07 PM
    thebeardedbeerguy
    Newnan, GA
    Many thanks.
  11. Jun 1, 2019 at 1:09 PM
    thebeardedbeerguy
    Newnan, GA
    Thank you. I want to install an LED auxiliary back-up light as well as back up horn. I'm tired of these people with their heads in the phone and I'm trying to get out of the parking space.
  12. Jun 1, 2019 at 1:10 PM
    caribe makaira
  13. Jun 1, 2019 at 1:11 PM
    caribe makaira
    The tow reverse has its own relay and fuse. It can "handle" better the added items than the reverse lamp in the tail lamp.
    tetten and Suplex[OP] like this.
  14. Jun 1, 2019 at 1:14 PM
    thebeardedbeerguy
    Newnan, GA
    Understood. Thank you.
  15. Jun 1, 2019 at 1:19 PM
    Muddinfun
    If you want really bright reverse lights, the Deauto LEDs are awesome.
  16. Jun 1, 2019 at 1:31 PM
    thebeardedbeerguy
    Newnan, GA
    Are those intended to replace the OEM bulb?
  17. Jun 1, 2019 at 2:04 PM
    Muddinfun
  18. Jun 11, 2019 at 3:39 PM
    thebeardedbeerguy
    Newnan, GA
    Purchased a pair. Will let you know outcome. Thanks again.
  19. Jun 11, 2019 at 3:51 PM
    Muddinfun
    When you get them and open the package, your reaction will be, "That's it? Those don't look very impressive". But, after you install them, you will be blown away at how bright they are. And the best part is that they also shine light straight out to the sides where you need to see if you're going to sideswipe the wifes Lexus.
  20. Jun 15, 2019 at 6:50 PM
    thebeardedbeerguy
    Newnan, GA
    Holy Chit. Every TACO needs these! Going to order turn signals. If you can’t see these you need a vision or sobriety test.:cheers::cheers: I have hijacked this thread enuf. Again. Thank you.:hattip:
