Touching up the white lettering on my mud flaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Travelair22, Feb 27, 2021.
  1. Feb 27, 2021 at 9:38 AM
    Travelair22
    Travelair22 [OP] Member
    The white paint on my mud flaps is needing touching up. Any suggestions what kind of paint to use?
  2. Feb 27, 2021 at 9:42 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  3. Feb 27, 2021 at 10:26 AM
    SunsetDiesel
    SunsetDiesel Well-Known Member
    Maybe tape off the black and spray with a quality paint made for plastics.
  4. Feb 27, 2021 at 10:35 AM
    esotaco
    esotaco Well-Known Member
    Ed
    Fairfax, VA
    '13 Silver 4.0L AT SR5 4X4
  5. Feb 28, 2021 at 3:30 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Mine are blueish looking as the letters continue to disappear. I need to redo or strip them, one or the other.
  6. Feb 28, 2021 at 4:42 PM
    Muddinfun
    Muddinfun Well-Known Member
    Cut off the flaps just above the 4X4. Problem solved.
    TnShooter, tinker_troy and Bigtrees like this.
  7. Feb 28, 2021 at 4:43 PM
    Steve721
    Steve721 Well-Known Member
    Boston
    2009 Speedway Blue, TRD Sport
    I used a paint marker from Michael’s. I got the white but there are other colors if you choose. I did mine just over 3 years ago, and they still look good.
  8. Feb 28, 2021 at 5:02 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Use a 3M pad and simply scrub the remaining white off and then all black - looks better anyway.
  9. Feb 28, 2021 at 5:12 PM
    spitdog
    I would be scared if you removed the all the white paint the 4x4 wouldn’t work properly.
    DiscoYaker and po35042 like this.
  10. Feb 28, 2021 at 7:26 PM
    JBIdaho
    JBIdaho Active Member
    Jon
    2013 Green Tacoma TRD Sport
    I’m a detail guy by nature, I try to keep my stuff looking new, I’ve been thinking the same thing, thanks for asking and thanks for the ideas of white sharpie or paint pen.
    gkomo likes this.
  11. Mar 1, 2021 at 5:40 AM
    SJBlack
    SJBlack Well-Known Member
    I did the White wide Sharpie from Michael's about a year ago and they still look good.
  12. Mar 1, 2021 at 7:24 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Those with the paint pens... I keep reading reviews they don't work correctly unless the pen is vertical, which would mean removing the flaps to paint the lettering. Is that all yours experience?
    What i did was spray white spray-paint into a red solo cup and use a q-tip to paint the letters. Works great but does come off fairly easy with washes. It's so quick and simple that i don't mind touching up the lettering more often.
