Touch up paint for dashboard?
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco57, Mar 29, 2017.
  1. Mar 29, 2017 at 4:16 AM
    taco57
    taco57 [OP] Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    Anybody find a good color match paint to fix a couple of areas on my dash top (gray) that has been rubbed off? Just need a little bit to cover up a couple of places where the paint pulled off but can't find a color match.
    Thanks!
  2. Mar 29, 2017 at 7:08 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    I'm interested in this as well.
  3. Mar 29, 2017 at 9:57 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    As am I...
  4. Mar 29, 2017 at 10:53 AM
    jammer
    Ben
    Bentonville, AR
    Jeff, this is a post I had a while back. Like yourself though, I'd love to know what matches.
    https://www.tacomaworld.com/threads/help-interior-color-2003-prerunner-4door.318947/
  5. Mar 29, 2017 at 12:46 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    @tacomatrd22
  6. Mar 29, 2017 at 3:03 PM
    taco57
    Jeff
    Columbus Ohio
  7. Mar 30, 2017 at 7:19 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I haven't messed with the paint on the top of the dash. Just the interior pieces that were black. I would look around a place that makes car paint and have some vinyl paint made (bring a sample of your interior color) Would be hard to get the right color because the dash doesn't have a color code I went off from.
  8. Mar 30, 2017 at 8:10 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I made the mistake of wipe it with rubbing alcohol to get a greasy film off goo off and the paint just wiped off.
    when I looked at what I could do with it, it seemed to be, you cant match the faded paint so the best solution is, you have to take the dash out (several hour job) then just paint the whole thing and reinstall it good as new. a short version is, take as much off as you are willing and then try painting it all "in place" that way
  9. Mar 30, 2017 at 9:19 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I bought a vinyl repair kit from True Value intended for stuff like furniture, kitchen chairs etc. It comes with little viles of key colors you can custom-mix yourself to get an exact (or close) color match. It also comes with grain swatches you apply heat to to achieve the texture of the surface. I bought this to repair a scratch I caused across my glovebox and part of the dash near it.
    I am still developing the balls to go through with it:(
  10. Apr 21, 2018 at 6:36 PM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Scuffed mine today on top of dash. Did anyone find a good solution...and take before/after pics? It appears the gray color is only on the surface. Not all the way through the plastic. Would really like to find a wipe on/ brush on solution, instead of disassembling the entire dash to spray.
  11. Apr 23, 2018 at 1:06 PM
    Benny123
    Ben
    South Charlotte, NC
    To future readers. Found out you can paint the dash with plastic primer and paint and solve the issue.
  12. Apr 24, 2018 at 6:17 AM
    kgt0001
    kgt0001 Well-Known Member
    Kyle
    San Antonio, TX
    2003 Toyota Tacoma PreRunner, 1997 Tacoma 4wd
    The prior owner of our truck had stuck a GPS mount to the dash. After removing the paint underneath was mostly missing. I had a company that a used car dealer told me about come out and color match and respray that area. It was $75 which to me was worth it- match is excellent. He mixed the color on site and blended it out so you cannot tell.
    Downside (for some) is that you cannot Armour-All the dash - will impact the touched up area. A non-issue for me, but if you like the shiny look you will need to find another solution.
  13. Apr 24, 2018 at 6:25 AM
    Benny123
    Ben
    South Charlotte, NC
    Good to know. I ended up repainting mine, made a new post on TW.
