TOTAL CHAOS Long Travel *Discussion Thread*
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Oct 2, 2018.
  1. Oct 2, 2018 at 9:46 AM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
  2. Oct 2, 2018 at 9:48 AM
    TOTAL CHAOS
    Corona, CA
    PRODUCT SPOTLIGHT - TOTAL CHAOS +3.5" Race Series Long Travel
    https://youtu.be/3r6YdLJskv8
    LIFT: 3-4"
    TRAVEL: 13"
    TIRE: 33" or 285
    TRACK WIDTH INCREASE: 7"
    MORE INFO
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
      • 100% chromoly constructed Race System offers maximum ground clearance and weighs 10 pounds less than the standard TC +3.5" LT kit.
      • 3.5" extended 4130 chromoly tubular upper arms bolt to factory control arm mounting locations.
      • Upper and lower ball joints are replaced with 1" uniballs for maximum wheel travel and component strength. TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
      • 4130 chromoly boxed and internally gusseted 3.5" extended lower control arms bolt to factory control arm mounting locations and are pre tabbed for dual shock capability.
      • Lower control arms feature an integrated uniball cup that provides 2.5" additional ground clearance when compared to the standard mild steel +3.5" LT kit.
      • Lower arms are 5 pounds lighter each side than the standard +3.5" LT kit.
      • 2.5" long travel specific coil over shocks bolt into the factory coil bucket location. Extended travel shocks are too short and will not work.
      • A secondary external bypass shock can be installed to increase dampening and tune-ability.
      • Spring rate options offer the ability to customize your ride for your specific application allowing you to custom tune the vehicle for specific terrain or desired performance.
      • Adjustable limit strap clevis' are included so that you can properly limit the suspensions droop wheel travel and make necessary adjustments during the life of the limit strap.
      • DOT approved stainless steel braided brake lines, TC custom 17-4 stainless hi-misalignment spacers and grade 8 mounting hardware is included.
      • TC 4340 custom extended axles reuse factory inner and outer CV's to retain 4wd.
        (axles are sold separately and not included with the kit)
      • 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
      • Hand crafted in the U.S.A.
      • Fiberglass fenders are required on Tacoma.
      • *If FOX Shox will be used, an "F" must be added to the LT kit part number, i.e. 86000-R-F
  3. Oct 9, 2018 at 7:55 AM
    TOTAL CHAOS
    Corona, CA
    The_Black_Pearl and SilverSurfer like this.
  4. Oct 16, 2018 at 8:00 AM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    In the process of burning on the cam tab and shock tower gussets. It is easy to forget about stuff like this, but I think it is going to pay off.
    ChadsPride and Doomsday like this.
  5. Oct 18, 2018 at 11:53 AM
    TOTAL CHAOS
    Corona, CA
  6. Oct 25, 2018 at 10:22 AM
    TOTAL CHAOS
    Corona, CA
  7. Oct 25, 2018 at 10:25 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Do you have information on the fitment of ADS coilovers with your +2 LT kit for 2016+ Tacomas? I'm curious if the Fox or King variant of the kit would be the right one to mate up with ADS shocks.
  8. Oct 25, 2018 at 10:51 AM
    TOTAL CHAOS
    Corona, CA
    Unfortunately, we don't. We don't work closely with them, and to our knowledge, they don't have a coil over shock with the right specifications for our LT kits. I'm mostly seeing factory replacement shocks.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  9. Oct 25, 2018 at 10:53 AM
    PcBuilder14
    Brent
    Nor Cal
    Understood. I think they have "LT" coilovers for Tacomas on their website, but there aren't any details about the shocks. I'll look into it more when the time comes for LT.
  10. Oct 25, 2018 at 10:59 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    @90yota...found your thread bro!
  11. Nov 15, 2018 at 9:31 AM
    TOTAL CHAOS
    Corona, CA
    Doomsday and TrapComa like this.
  12. Nov 15, 2018 at 9:33 AM
    TOTAL CHAOS
    Corona, CA
    45596937_2525153677525165_67035468119922_c5852dcf9805f7f67ba5f1e44b5df08705130739.jpg
    Have questions about TOTAL CHAOS Long Travel? Comment below!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  13. Nov 15, 2018 at 9:33 PM
    TrapComa
    Mason
    Cedar Park, TX
    That Cruiser is baaaaaaad. If I had that kinda money, that’s exactly what I would spend it on
    Gunshot-6A likes this.
  14. Nov 19, 2018 at 1:19 PM
    TOTAL CHAOS
    Corona, CA
  15. Dec 4, 2018 at 7:54 AM
    TOTAL CHAOS
    Corona, CA
  16. Dec 5, 2018 at 5:59 PM
    TOTAL CHAOS
    Corona, CA
  17. Dec 10, 2018 at 10:39 PM
    MGRIZZ
    MGRIZZ Member
    Manny
    Central California
    2017 White Tacoma SR5
    Hello, fairly new to the tacoma scene and LT scene hopefully my questions make sense. Was very interested in your +2 race series kit, From what I can tell you orrder the coilovers separately and this adds clearance to the truck like a lift? Also what's the best recommendation for building the rear suspension and obtaining the same amount of "lift" and travel? Thanks for the help.
  18. Dec 11, 2018 at 10:03 AM
    TOTAL CHAOS
    Corona, CA
    Different coil over shocks are required when running a Long Travel System. The longer coil over will give you increased wheel travel and provide some lift over factory. A great recommendation for the rear is our SUA Conversion. This pairs greatly with our Long Travel Systems
    https://www.chaosfab.com/accessories/2016-2017-Tacoma-Mid-Travel-Rear-Suspension-Kit-86450-HD
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  19. Dec 11, 2018 at 2:05 PM
    MGRIZZ
    MGRIZZ Member
    Manny
    Central California
    Awesome thanks for the response. Do you guys offer the shocks for long travel kits through your site or from a different vendor?
  20. Dec 11, 2018 at 3:38 PM
    TOTAL CHAOS
    Corona, CA
    We don't sell directly on our site but if you email info@chaosfab.com we can give you different suggestions for shocks. We do sell certain options if you reach out to us. Happy to get you set up if you give us a shout.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
