Toshiba laptop Battery problem
Discussion in 'Technology' started by TheHansen, Sep 12, 2012.
  1. Sep 12, 2012 at 10:57 AM
    TheHansen
    TheHansen [OP] Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    I'm going to try to keep this as short as possible
    I haven't had a battery for over a year. I bought a new one and it worked, but would not charge. Once it died it was dead for good. I tried it on another compatible laptop with the same result. I returned the battery and they gave me a new one. I installed this one and now i get "no battery is detected"
    I'm a little lost now.
    Any advice would be greatly appreciated.
  2. Sep 27, 2012 at 8:42 AM
    kurtw
    kurtw Extra Regular
    Kurt
    Leander, TX
    07 PreRunner Double Cab TRD Sport - Sold / 2016 4runner Trail Premium
    Go to Toshiba's web site, see if there's an update to your BIOS available.
    Depending on your model, some Toshibas (and Gateways as well) were known for charging issues. If I recall correctly, it was due to how the charging port was connected to the mobo, and there were (are) all kinds of issues with the port breaking off, over heating, battery charging issues, etc. How old is the laptop? Do you keep it plugged in when using it?
  3. Sep 27, 2012 at 6:25 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Check the contacts where the battery pops in to the laptop. If your laptop is plugged in all daylong and you do not do alot of work on it that requires saving, then remove the battery it will last longer. Only drawback by doing this is you lose your un-saved work if a power failure happens or your kids trip over the power cord.
