Torque Specs for rear shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swivot, Oct 16, 2017.
  1. Oct 16, 2017 at 12:21 PM
    Swivot
    Swivot [OP] Well-Known Member
    Anyone have torque specs for rear shocks? replacing mine now need upper nut and lower nut spec. Its a 2001 Tacoma 4wd V6 Bilsteins 4600
  2. Oct 16, 2017 at 1:37 PM
    Sodom
    Sodom Well-Known Member
    New England
    2001 Xtra Cab SR5 4x4 3.4L 5-Speed Gold
    Rust
    From 2003 FSM:
    4WD and pre runner: 71 N·m (730 kgf·cm, 53 ft·lbf)
  3. Oct 16, 2017 at 2:24 PM
    Swivot
    Is 53 for the upper or lower bolt?
  4. Oct 16, 2017 at 2:30 PM
    Your-10Ply-Bud
    Your-10Ply-Bud Should be fine, not my truck..
    Marshall
    Ontario, Canada
    2001 3RZ 4x4 5spd
    5-Stars/Satoshi 5100's/OME 881's TG AAL/Cooper AT3's
    Both, same bolt size I believe
    Sodom likes this.
  5. Oct 16, 2017 at 2:35 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Hmm...I just tightened mine as tight as I could with my wrench and used some blue Locktite on them. They haven't come off yet lol.
    Sperrunner likes this.
  6. Oct 16, 2017 at 8:01 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Same here! Tightened them as tight as I could get them. Been fine ever since!
  7. Oct 16, 2017 at 11:13 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nothing like the ol gutentite 1/4 turn from being stripped lol. 53 ft lbs for suspension related bolts isn't too much even if top and bottom aren't exactly the same. I'm assuming they are though. I think 2nd gens are 75.
  8. May 12, 2018 at 8:44 PM
    themightygoose
    themightygoose Member
    Fleiman
    2016 Tacoma Dbl Cab SB, TRD Off-Road 4x4
    Premium air in tires.
    This is why that's a bad idea:
    Toyota sets torque specifications for a reason. And Murphy's law guarantees this will happen only when you're far from home.
  9. May 12, 2018 at 9:13 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  10. May 12, 2018 at 9:17 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Jesus man, did you use like a 4’ breaker bar on that? Unless you’re He-Man or giving yourself a hernia trying to tighten it, I don’t think you’d get enough torque to snap a shock bolt from a box wrench.
    While a torque wrench is a good idea, I’ve never brought one on the trail. “Putting it on as tight as it was getting it off” is usually good enough, especially for a trail fix. Get home and fix it proper, with torque specs.
    Dalandser likes this.
  11. May 12, 2018 at 9:19 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Pic looks familiar lol
    https://www.tacomaworld.com/threads/the-torque-spec-guide.318116/
    I don't think @eon_blue is applying stretching-the-bolt-to-near-failure amounts of torque. Once someone puts on enough aftermarket parts on a truck there's no more specs to follow unless you want to go with a general spec chart for bolt size. I was trying to get some torque specs for the bolts on my Solo suspension kit and was told "I have one of the younger guys get on it with a breaker bar." Yep lol.
    themightygoose likes this.
  12. May 12, 2018 at 9:20 PM
    themightygoose
    Fleiman
    That wasn't my bolt. But I've over-torqued bolts before and had them break. If you get the bolt too tight, the truck will add torque in certain situations and the bolt can break like the one in the photo above. Those situations would likely be when you're off roading and the suspension is under extreme stress. You might not ever have a problem, but those torque settings exist for a reason.
  13. May 12, 2018 at 9:28 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Pretty sure a M10 shock bolt that doesn't hold any tension and goes into a blind hole single shear isnt going to be flexing to the point of breaking. Torque specs exist for a reason but so does common sense. If you need torque specs for this bolt you are probably overthinking the whole thing haha. I've yet to hear of this mythical bolt snapping after effect on something as mundane as minitruck suspension, usually you know right away when you've torqued to full yeild, your tight bolt just suddenly gets nice and loose.
  14. May 12, 2018 at 9:36 PM
    themightygoose
    Fleiman
    Yeah, you're probably right. It would probably be hard to over-tighten one of these bolts to the point they will break and fail. But just wrenching down on bolts as tight as you can get them isn't really a great practice.
  15. May 12, 2018 at 9:38 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Right you just want them Gutentite
  16. May 12, 2018 at 9:42 PM
    themightygoose
    Fleiman
    I am the weirdo who reads the manual. And it seems the more I learn, the less I know...
  17. May 13, 2018 at 5:26 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Snug with never seize .
    About all I have ever torqued is engine work Head bolts Rod and Main Bearing bolts fly wheel
  18. May 13, 2018 at 9:36 AM
    jbrandt
    Justin
    It’s not about tightening them as tight as you can get them. Contrary to how my father did car repair, it’s not a strength competition.
    We aren’t talking about torque to yeald bolts, like head bolts or other critical engine bolts. These are shock bolts. The only thing over tigtening these bolts will do is make it a little harder than needed to remove them.
    You turn enough bolts and you start getting a feel for how tight they should be. With a lot of bolts, you can judge by how hard you had to work to get the bolt off.
  19. May 13, 2018 at 9:51 AM
    eon_blue
    Azusa, CA
    I should have been a little more specific, I meant as tight as I could get them relative to me laying on my back looking up with maybe a foot of workable room to turn the wrench...definitely not using all of my strength because there simply wasnt any feasible way to do so...but as tight as I could get it in that situation. Certainly nowhere near tight enough to over-torque the bolts. If anything, I'd be afraid I under torqued them.
    I've since picked up 2 torque wrenches though because I had to work on my LBJs and my u-bolts and I know how critical those numbers have to be. I almost always use a torque wrench now if I can get it to fit in the space I'm working in, along with blue loctite if it's something that could spell disaster should it come loose.
  20. May 14, 2018 at 3:50 PM
    themightygoose
    Fleiman
    If nothing else, it’s a good reason to get a new tool.
