Torque Specs 1st Gen. Banjo Bolt.
Discussion in '1st Gen. Tacomas (1995-2004)' started by mewefan, Sep 14, 2020.
  1. Sep 14, 2020 at 1:48 PM
    mewefan
    mewefan [OP] Active Member
    Anyone know the torque specs on a 1st gen tacoma power steering banjo bolt?
    thanks in advance.
  2. Sep 15, 2020 at 1:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I can`t recall every Torquing any Banjo Fitting to any set amount most fittings getting a torque wrench close would be interesting.
    New Crush washers no leaks your good to go.
  3. Sep 15, 2020 at 5:58 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Might find it here. I didn't go through the list though. 2000 FSM:
  4. Oct 16, 2020 at 8:20 PM
    Laisseraller
    Laisseraller Active Member
    2004 Toyota tacoma Prerunner
    I would not recommend torque these are brass and you can easy strip them finding a replacement is hard to find. Just tight enough no over tightening.
