Torque spec on bed bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, May 10, 2019.
  1. May 10, 2019 at 8:00 AM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I've been having a rattle coming from the back of the truck. Figured it was my handyman on the swing out. However when I investigated today I learned it was the front passenger bed bolt.
    So I'm gonna tighten it up, but does anyone know the correct torque spec on this bolt?
  2. May 10, 2019 at 8:04 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    60ft-lb.
    If the bed is still loose after torquing, you can put a HD piece of rubber between the frame and bed. Don't grind down the sleeve.
    shakerhood likes this.
  3. May 10, 2019 at 8:07 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  4. May 10, 2019 at 11:17 AM
    nevadabugle
    Elko, NV
    Re tourqed and it's now tight. Thanks.
    tonered likes this.
  5. May 10, 2019 at 11:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    :cheers:
  6. May 14, 2019 at 6:35 AM
    nevadabugle
    Elko, NV
    Well fix was short lived. Its loose again. Gonna have to try the rubber spacer.
  7. May 14, 2019 at 6:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry to hear that. The bed wear was discussed in the 2nd Gen forum.
  8. May 14, 2019 at 7:01 AM
    nevadabugle
    Elko, NV
    Kinda strange, my second gen never had this issue. And I wheeled it hard also. I'll try the rubber spacer fix and hope for the best.
    shakerhood and tonered like this.
