torque spec for lug nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black cx, Mar 10, 2011.
  1. Mar 10, 2011 at 8:39 AM
    black cx
    black cx [OP] Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    whats the torque spec for the lug nuts?
    Thanks,
    Lord Humongous likes this.
  2. Mar 10, 2011 at 8:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    85 ft-lbs
    DG92071, knayrb and foampile like this.
  3. Mar 10, 2011 at 8:53 AM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    thank you
  4. Mar 10, 2011 at 9:11 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    85 x2 I took one off with a cheater bar. 70$ to fix.
  5. Mar 10, 2011 at 9:17 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    You can find it in your owners manual if i am right for next time.
    JDMREXX likes this.
  6. Jul 15, 2017 at 5:04 AM
    johng34
    johng34 Member
    NH
    2006-4x4 5sp 6.1ft bed
    River rat 69
    What? You overtorqued to 170 ft-lb and broke the stud?
    Benzdriver81 likes this.
  7. Jul 15, 2017 at 7:36 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Here's my $0.02 on this.
    The correct amount of torque should always be applied to the nut lugs-always (as someone previously mentioned, check your owners manual it should state the correct torque valve).
    It is also important to set the correct torque value when installing new spark plugs as well (many don't believe this to be true but it is).
    Norton and Bebop like this.
  8. Jul 15, 2017 at 9:20 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I just crank everything down until the threads strip and then I blame the manufacturer for making substandard parts.
  9. Jul 16, 2017 at 1:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Zombie thread!!!!!!!!!!!!!!!!!!!!!!!!!
    EatSleepTacos and bullaculla like this.
  10. Jul 16, 2017 at 2:39 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    LOL!
    Besides being banned, he hasn't been active since march 2015, so I doubt he's gonna answer ;) I'm pretty sure that x2 meant he was agreeing with 85ft lbs, not multiplication by 2.
    But good job using the search function! :thumbsup:
    Lord Helmet and tetten like this.
  11. Jul 16, 2017 at 12:15 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    2013 4x4 Sport Access cab with 6 lug alloy wheels. per the manual 83 ft lbs
    TOMB
    bullaculla and Tex-Tac like this.
  12. Jul 16, 2017 at 1:12 PM
    brapp_kid7
    brapp_kid7 Well-Known Member
    Following
  13. Jul 17, 2017 at 11:12 AM
    Tex-Tac
    TEXAS
    Strange but true......(I'm sure you'll be safe n secure using either spec.)
    The Owners Manual for my 2008 Tacoma states to torque the nut lugs at 85 ft-lbs.
    The Service Manual for my 2008 Tacoma states to torque the nut lugs at 83 ft-lbs.
    Hopefully this bit of info will help someone out whenever needed. Just a bit more specific info on a wheels nut lug tightening pattern.
    TreeFortRichard and bullaculla like this.
  14. Jul 17, 2017 at 11:37 AM
    bullaculla
    Da big big island!
    Yep, I go to 83 lbs too. I always use a torque wrench for lug nuts.
  15. Jul 17, 2017 at 11:45 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    What??? No discussion on lug nut torque without bringing up whether to use anti-seize or not?
  16. Jul 17, 2017 at 11:49 AM
    bullaculla
    Da big big island!
    I use dry moly spray :anonymous:
  17. Jul 17, 2017 at 11:51 AM
    Bishop84
    Bishop84 Well-Known Member
    Guys, this is a zombie thread.
  18. Jul 17, 2017 at 11:52 AM
    bullaculla
    Da big big island!
    Yeah, but it's still relevant info.
    EatSleepTacos and ChemDawg like this.
  19. Dec 2, 2017 at 1:49 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Bumping because I just used this thread when checking out my new impact ratchets. Dealer def had my nuts at well over 100. I needed my 22" breaker for 2 on the front right and 1 on the front left. I took them all off and wanted to put them back on at the proper torque. IMG_7048.jpg
  20. Dec 2, 2017 at 2:27 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I have a question..
    I just sold my 90 K1500. The wheel studs are the same diameter and thread pitch of our tacomas. Even the bolt pattern is the same.
    The torque spec for the K1500 from the owner's manual is 115 ft lb.
    Why the difference?
