Torque Pro vs. Fusion vs. others, which one???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tah-koh-mah, Feb 11, 2020.
  1. Feb 11, 2020 at 9:16 PM
    Tah-koh-mah
    Tah-koh-mah [OP] Well-Known Member
    2012 Tacoma TRD-Off Road
    So I just got a OBD2 bluetooth reader and now am looking for a good app to show ATF temp. Which one does it best for the price? I know it takes some work to get Torque pro working with custom PID's and stuff, but how about Fusion, does it work out of the box or do you have to pay more for "add-on" packages? Is there other apps that can show ATF temps out of the box for a reasonable price?
    eherlihy likes this.
  2. Feb 12, 2020 at 12:45 PM
    chaoselephant23
    chaoselephant23 Active Member
    Kristian
    SECT
    2015 Tacomer V6 AC TRD TOW
    Dual USB, Bed Store Locks, Remote Diff Breather
    Micbt25 likes this.
  3. Feb 12, 2020 at 1:11 PM
    Tah-koh-mah
    How much was the Fusion app and add-on?
  4. Feb 12, 2020 at 1:56 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I tried the Fusion app with a Toyota add on. It is a very nice looking app, however, I found some of the readings were way off. I was pretty sure my Tacoma was not getting 75mpg, so I didn't have much confidence in it and I asked for a refund. I think with the Toyota add on, it was $20-25.
    Torque Pro looks more "dated", but it only costs $5. The transmission temperature PIDs are available and easily entered into the program. Torque Pro's readouts seem fairly accurate.
    In defense of Fusion, my 2005 does not have all the sensors a 2015 may have, so it may be a better value with a later model truck. If your vehicle doesn't have a sensor, no app is going to provide data.
  5. Feb 12, 2020 at 1:59 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    I use the fusion. I purchased the add on so I could get pan temp and converter temp withputbthe hassle.
    It’s fine. Really just a novelty, but I do use it for trans fluid swaps.
  6. Feb 12, 2020 at 2:04 PM
    Tah-koh-mah
    How much was the add-on?
  7. Feb 12, 2020 at 2:04 PM
    Tah-koh-mah
    Was the $20-$25 with the Apple version or android?
  8. Feb 12, 2020 at 2:13 PM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    I don’t remember. $10 maybe?
  9. Feb 12, 2020 at 2:46 PM
    chaoselephant23
    Kristian
    SECT
    I paid $9.99 for the Fusion iOS (Apple) application.
    Toyota Add-On is $9.99 as well. Total of $19.98.
    However I did not buy the Add On pack to get ATF pan temp. Just refer to https://www.tacomaworld.com/threads/how-to-get-transmission-temps-on-fusion-app-for-ios.359279/ for the formula to create your own user defined PID. Once the User Defined PID is created, you can create a new dashboard widget that is backed by the User Defined PID.
  10. Feb 12, 2020 at 7:39 PM
    Tah-koh-mah
    That's interesting. This whole time I thought the add-on pack included ATF temps. Or is that for Apple products only?
  11. Feb 12, 2020 at 8:22 PM
    chaoselephant23
    Kristian
    SECT
  12. Nov 24, 2020 at 5:11 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Has anyone had success using the Fusion app in reading engine oil temperature and miles to empty for gas? in an earlier generation 2nd gen tacoma.
    thanks
