Torque Atermarket wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rwood, Nov 11, 2023.
  1. Nov 11, 2023 at 12:06 AM
    Rwood
    Rwood [OP] Well-Known Member
    Raymond
    WNC
    15 TRD Off-road
    I got some Method wheels and was wondering what torque specs everyone used on the aftermarket wheels? The gentleman that installed my wheels said 83lbs for factory wheels with the washer but he thought it was more for aftermarket wheels but never told me a spec. He torqued mine to 90lbs so I was wondering what everyone torqued there wheels too.
  2. Nov 11, 2023 at 3:24 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    If no torque is given by the manufacturer, I use the standard industry chart to determine torque spec. 83 is the factory spec as determined by the stud size.
    I use anti seize on studs, so I lower the torque wrench 23% as per the standard 20-25% reduction recommendation for a lubricated fastener. So I torque to 62 lbs ft
  3. Nov 11, 2023 at 9:11 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Seriously? 62lbs/ft? I’ve been around for a while and I’ve never heard of that before.
    It’s your truck so you can do what you want but that math sounds sketchy to me for wheel nuts on a vehicle....
    OP, I’d use Toyota’s specs or contact the wheel manufacturer...
  4. Nov 11, 2023 at 10:09 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    85 ft lbs. If yours were torqued to 90 then leave it, it will be fine.
    You should see what most mechanic shops torque them to. 6 ugga duggas of the impact which is always over 100 ft lbs.
    atc250r, TS4x4 and Big tall dave like this.
  5. Nov 11, 2023 at 10:23 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    He is correct when using anti seize. Anti seize makes it easier to thread the nut to the point where it achieves the required clamping force. Meaning you will reach that point about 20-25% more quickly. That results in lowering the torque spec by about that much, which is what he did.
    If sticking to the Toyota spec (which is perfectly fine), then you’d keep the spec at 83 but you’d only want to install them dry. Installing with anti seize and torquing to 83 would risk overstressing the studs.
    PTSDTherapy and faawrenchbndr like this.
  6. Nov 11, 2023 at 10:33 AM
    WBTaco
    WBTaco To be determined
    West Bend, WI
    2023 TRD Sport DCSB MGM
    None
    Coming from a guy who uses anti-seize a lot, that is good to know. Thanks for sharing.
  7. Nov 11, 2023 at 10:35 AM
    Bishop84
    Bishop84 Well-Known Member
    You’d have to be coating it like chocolate if you were to reduce it by 20%
    anti seize restores the thread use back to factory spec. Studs generally have resistance with time.
    Use sparing amount of anti seize and always use factory specs.
  8. Nov 11, 2023 at 3:51 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    been working on aircraft for 40 years. Do your own research and look up specifications for lubricated fasteners. Apparently you have quite a bit to learn
    PTSDTherapy likes this.
  9. Nov 11, 2023 at 3:52 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    this is completely incorrect. If you use factory specs with a lubricated fastener, you will over torque the fastener.
  10. Nov 11, 2023 at 4:02 PM
    Bishop84
    In ideal scenarios for sure.
    No fastener that is exposed to elements is factory clean anymore.
    Also a dab of anti seize is not "wet torque"
    Wet torque is literally dripping, like head bolts.
    You suggesting 62ft lbs is naive and dangerous.
    Superdave1.0 and Big tall dave like this.
  11. Nov 11, 2023 at 4:17 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Your opinion…..but the charts don’t lie
  12. Nov 11, 2023 at 4:28 PM
    Bishop84
    Yes, if the fasteners are wet. Not a light paste on rusty threads.
    Wet torque is dripping bolts, usually SAE30 or motor oil on them.
    Superdave1.0 likes this.
  13. Nov 11, 2023 at 4:30 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Lubricated threads are lubricated threads.
    If it has lube on it, it is wet.
    Do your research & quit throwing out garbage
  14. Nov 11, 2023 at 4:33 PM
    Bishop84
    Ive actually been trained in it, hence my correcting. Crazy you think a paste is wet.
    I happily quote wheels on under torqued wheels for people that think they know more than engineers.
  15. Nov 11, 2023 at 4:42 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    funny thing is engineers are the ones that created the torque reduction charts. And their charts out there that specifically state anti-seize. These are pretty easily searchable for people who want to know the truth versus your BS
  16. Nov 11, 2023 at 5:09 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The torque is determined by the stud diameter, thread pitch, and material grade. Changing wheels doesn't change the required torque. 90 ft-lb is too high on OEM studs.
  17. Nov 11, 2023 at 6:25 PM
    Big tall dave
    I’m always willing and open to learning something new, and I’ve used ARP head studs with their special oil and torque specs so I understand the logic behind what you’re saying, but IMO, 62lbs/ft seems really loose for a fastener on a wheel of any Tacoma-sized vehicle on the road.
    Maybe the aircraft industry is different, or maybe I just can’t help thinking about all the vehicles I towed over 15+years where a wheel came off (or came loose) and I’d check the other wheel nuts and they’d be loose too....
  18. Nov 11, 2023 at 7:14 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Just going to throw this out here, but on my motorcycle per its specs pretty much say the same thing as faawrenchbndr is saying here. When torquing your bolts when using anti sieze you have to reduce the amount of torque applied. It specifically lists anti-sieze and the percentage of reduction is in line with what is being said here.
    PTSDTherapy and BLtheP like this.
  19. Nov 11, 2023 at 7:25 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    No disrespect to any of the above info, but I wouldn't ever feel comfortable @ 62 lbs ft, regardless of any proven chart. Especially with heavier oversized tires.
    I'd rather go with what Toyota recommends, but that's just me.
  20. Nov 11, 2023 at 7:25 PM
    BLtheP
    Plano, TX
    Yep…lubricated is lubricated. Extra wet or not doesn’t really matter. Following Toyota specs is fine, but using anti seize is not following Toyota specs…not that I’ve ever seen anyways. If you want to follow the specs, install dry.
    MadKatt and PTSDTherapy like this.
