Torn cv boots - how bad is it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrcheap, May 5, 2020.
  1. May 5, 2020 at 10:34 PM
    mrcheap
    mrcheap [OP] Well-Known Member
    On both sides no sign of grease
  2. May 5, 2020 at 10:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You should total the truck. It's done.
  3. May 6, 2020 at 5:45 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    In all seriousness, it's a "relatively" simple replacement. You could go with a stock boot but I would run one of these boots. Pull your axle (or both if both are fux'd), pull the old boot off and check your CV's for condition. Run it through a parts cleaner to get all the old grease out. If everything's gravy, you should be able to re-grease the joint, push the new boot on and clamp it down then prime for reinstall. If that sounds like too much work, buy replacement axles and install them while you take time to rebuild your current ones. Now you have spares for 'just in case'. Getting a new boot on is easier if the joint is pulled apart but it is possible to shoe-horn the boot on if its fully assembled. It'd be a fun project, I dont envy you.
    -J
  4. May 6, 2020 at 5:50 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Put that on your need to get to list.
  5. May 6, 2020 at 5:54 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Any torn boot is bad road grit and water does not play well with bearings and grease .
    CV axle failures can be exciting .
    If money is really tight installing new boots if no real damage has been done is a option .
    unless your a hard core off roader the New Napa ones have worked for me..
    I have two sets to rebuild if I get in the mood.
  6. May 6, 2020 at 5:55 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    if no sign of grease, all the grease has exited. You should probably rebuild and add more grease. Otherwise you may be hearing some clicking soon
  7. May 6, 2020 at 5:55 AM
    fatfurious2
    David
    Ashburn, VA
    I have an extra set to send out to CVJ to reboot. Im tired of rebooting, and then the clamps fail
    Wyoming09[QUOTED] likes this.
  8. May 6, 2020 at 6:02 AM
    rnish
    Tacoma 2nd gen
    Somebody was selling “orange super boots”. Have you tried them? Snake oil?
  9. May 6, 2020 at 6:06 AM
    fatfurious2
    David
    Ashburn, VA
    CVJ sells high angle boots, but I will let them reboot mine. Ive done it a few time, and had the boot clamps fail a few times.. enough for me to justify paying for someone else to do it
  10. May 6, 2020 at 6:09 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Why not something like this or that?
    -J
  11. May 6, 2020 at 6:12 AM
    fatfurious2
    David
    Ashburn, VA
    I have them on my current axles now. Not bad, but I think they are a little wider than the part on the boot for the clamps. But Im still going to go with these
    https://www.cvjreman.com/product/9808tr/
    JustAddMud[QUOTED] likes this.
  12. May 6, 2020 at 6:12 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    sell the truck
  13. May 6, 2020 at 6:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    If that is 'no sign of grease' to you, I'd hate to see what gunked up means.
    They really need to be replaced ASAP. And stay out of mud, water and dirt roads until they are.
    Wyoming09 likes this.
  14. May 6, 2020 at 6:13 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
  15. May 6, 2020 at 6:15 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
  16. May 6, 2020 at 6:21 AM
    tacofish
    N NJ
    14 ext cab 4x4
    Have you ever used these?
  17. May 6, 2020 at 6:25 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    yah.. why i say only better till the boot is over extended then it slides
    tacofish[QUOTED] likes this.
  18. May 6, 2020 at 7:23 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I just had to replace my driver side for almost the same reason. Mine was the inner boot. I was in a time crunch so I got a reman napa cv, put it in, and ordered the reboot kit -- your outer boot part is
    04427-0T060 ... I could drive immediately and then had the time to receive the order and reboot it. I couldn't figure out the outer clamp so ended up with the more basic fold over. Anyways, last weekend I rebuilt the OEM CV with the inner boot and it's sitting here waiting to be re-installed. I don't have anything coming up that's going to stress the napa CV and it drives great so I'll probably leave it in until I need to get back in there. Also -- if you have any sort of vibration under the pedal that goes away in 4WD I highly recommend installing the ECGS bushing while you have the axle out.
  19. May 6, 2020 at 7:54 AM
    mrcheap
    Thanks guys. I know its on the to do list. Just gauging criticality and options based on the pics. As mentioned earlier time and resources are tight. It’s not my daily driver.
  20. May 6, 2020 at 8:08 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Napa CVs with discount are less than $100 and the best OE option
    dk_crew likes this.
