Torn CV Boot,How far can you drive before replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lynlan1819, Apr 30, 2017.
  1. Apr 30, 2017 at 10:12 AM
    lynlan1819
    lynlan1819 [OP] Well-Known Member
    Tacoma
    Lifted
    Hi guy's,About how far about can you drive with a just torn open front cv axle boot,a couple blocks,2 miles,etc.?
  2. Apr 30, 2017 at 11:52 AM
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    You can drive for a while, the problem is that now the axle is exposed to debris and moisture. Two things that will eventually cause it to fail. Replacement would be necessary at that point. I would look into OEM Toyota or CVJ's rebuilt Toyota axles for replacement.
  3. Apr 30, 2017 at 11:58 AM
    Muddinfun
    Muddinfun Well-Known Member
    It's not cost effective to clean, regrease, and replace boots, so you can drive it till it starts clunking, then install a rebuit half shaft. If you drive it a long time after it starts clunking, eventually it will fail catastrophically.
  4. Apr 30, 2017 at 12:02 PM
    Tayoflor
    Tayoflor Well-Known Member
    Taylor
    Woodinville
    2013 DCSB MGM
    Leer topper BAMF weld on sliders BAMF LCA skids Icon stage 4 SCS F5s wrapped in 285/75r16 Cooper Stt Maxx
    CV boot kit=80 bucks
    New shaft=~300
    I'd say it's more cost effective to replace torn cv boots.
    FishaRnekEd likes this.
  5. Apr 30, 2017 at 12:03 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Lol. I tore one at 26,000 miles. I intended to drive it till it failed. 275,000 miles later, still working fine.
  6. Apr 30, 2017 at 12:29 PM
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    You can get cheaper half axles; but I cannot attest to their quality yet. I purchased a new one for my 92 from BuyAutoParts for about $95.
    One with a busted boot will last a long time, but also depends on your driving conditions. I drove over a year with a busted boot and it was not clicking when I replaced it, so I think it would have lasted longer.
  7. Apr 30, 2017 at 12:32 PM
    magnetic4x4
    magnetic4x4 Well-Known Member
    2013 Magnetic Gray DCSB XSP-X 4x4
    I'd rather replace the boots than replace the axle with some aftermarket junk that won't last long. Most have a lifetime warranty, and you're going to need it when you have to replace them more often.
  8. Apr 30, 2017 at 1:59 PM
    lynlan1819
    Tacoma
    Lifted
    Nothing at all wrong with the axle itself,Its just that I noticed a very small wear spot on the boot itself that looks like it is going too open up soon,so if it does BEFORE I can get it replaced,that's why I asked here so I can see if it would be safe too drive it home from work if it tears open..Thank you for the replies guys.
  9. Apr 30, 2017 at 2:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Relax you'll be fine.. nothing is going to come flying off the truck LOL..
    If it's a tiny rip rebuild with a boot kit.. or you really can just drive on it till it's trashed and then replace the whole axle..
    Sometimes I would go to the trouble of re-booting only to have the axle click and make noise anyway. That's why sometimes it makes more sense to just buy a rebuilt axle and throw it in..
    koditten likes this.
  10. Apr 30, 2017 at 5:36 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Now I don't feel so bad about driving with mine torn lol. Think I've been driving around with half of the boot missing for almost 2 years now. No noise at all.
  11. Apr 30, 2017 at 7:43 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Maybe give it some protection with saran wrap and some zip ties. Just to keep the dirt and water out of it in the mean time.
    RacecarGuy likes this.
  12. Apr 30, 2017 at 9:29 PM
    koditten
    Kirk
    Central Michigan
    Think about how these parts work. Dirt getting in is not really the issue. Centrifugal force of the joint spinning and shedding the grease is the biggest issue. Stay out of the mud and not much dirt will get into the joint.
    Tight turns while the joint is flexing is the biggest worry. If no grease is in the joint you get binding and break the joint.
    Get it fixed in the next 10,000 miles and never worry about it again.
  13. Apr 30, 2017 at 9:34 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    Rarely see actual axle failure on these trucks, boots getting ripped or torn is pretty common. It's hard to justify using a factory axle over rebuilt due to cost.
    Replacing the boot is a option but replacing the axle isn't much more expensive and a hell of a lot quicker
    lynyrd3 and koditten like this.
  14. Apr 30, 2017 at 9:41 PM
    koditten
    Kirk
    Central Michigan
    Most definitely.
    If you are not an active 'wheeler, there is no harm in going the after market route. As easy as it is to change out the entire assembly, wasting time changing out the boot isn't worth it.
    Lots less mess as well. Changing out the boot is just a nasty, stinky job. The grease is a very sticky stuff that does not just wipe off. Yuck!
  15. Apr 30, 2017 at 9:44 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    If you are replacing the boot yourself it is relatively cost effective to keep the original axle. Just do so before the boot truly Tears. At the point it tears and spews grease, debris will get in an wear on the axle. If you are paying someone to replace just the boot, labour costs may make it more worth your while to replace the entire axle. They come already built.
  16. May 1, 2017 at 1:15 AM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    You can duct-tape it and drive it for a long long long while as long as the duct-tape holds :fingerscrossed::D. I've done that before because I was too lazy to pull the axle off my last vehicle and replace the boot.
  17. May 1, 2017 at 1:19 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Amazon sells cheap halfshafts. You'll be fine for a while. It helps undercoat the frame to prevent rust as well from all the axle grease it's spewing. 10/10 would recommend. When you feel like tearing into it, they aren't hard to replace.
  18. May 13, 2018 at 10:07 AM
    Buckaroo1993
    Buckaroo1993 Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Rock Auto sells them for something like $45. It's the same exact shaft O'Reilly's charges $72 for.
  19. May 13, 2018 at 10:10 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Don’t put in aftermarket crap
    It does NOT take that much longer to just re-boot
  20. May 13, 2018 at 10:25 AM
    Buckaroo1993
    Vinny
    Georgia
    My comment was NOT intended for FT crawlers and/or boggers. Yes, you will need OEM shafts or better. These particular shafts have a lifetime warranty and will do FINE for street apps and the occasional off-road.
