Toolboxes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by utacomah, Jun 27, 2020.
  1. Jun 27, 2020 at 10:34 AM
    utacomah
    utacomah [OP] Member
    2006 TRD OFF-ROAD 4.0
    Hey all, what are your thoughts on and experiences with truck toolboxes in the beds of your rigs?
    I have a short bed, so it would limit bed space even further, however I wouldn’t mind the extra lockable cargo space for tools and gear.
    Provide pictures if you have any!
  2. Jun 27, 2020 at 11:34 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I’ve had a uws for about 5 years still functioning as good as the day I got it. There have Been a couple times the extra bed room works have been nice but I worked around it. For me the lockable storage is a lot more valuable the the space it takes up but like most things it all depends on what your needs are. 5C5FA8A9-87FF-46D5-989C-9FE7604516DF.jpg5C5FA8A9-87FF-46D5-989C-9FE7604516DF.jpg
    dawgn86, DG92071 and utacomah[OP] like this.
  3. Jun 27, 2020 at 6:25 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    This is a highly subjective and personal decision. You can get one that is only a couple inches above the bed rails, or one that comes a third way up the back window. Some are about 12" wide thus shortening the bed effective by a foot. Others are about 22" which would shorten the effective use of the bed by almost 2 feet. You can get premiums ones, Weathercraft I believe, or budget ones like Lowes Kobalt brand, and quality in between. Some have a lifetime warranty, others have a set number of years. I bot my access cab in 2013,....looked at home improvement centers, farm and fleet type stores, 4 wheel parts type stores, on line, etc. Decide what you want to use it for. After a month decided on the Kobalt. Reasons....low profile so no visual rear window impairment,; the narrow model so takes up less bed space, but admittedly holds less stuff; the warranty is iron clad (life time),; it is light weight; it is relatively cheap; and I love it. All boxes are easy to break into, so keep mostly low value stuff in it, a few low end hand tools in a tool bag, bunge cords, rags, gloves and rope, extra quart of oil, 4 way lug wrench, jacket, sun screen, gallon of antifreeze, the bed rail cleats, dog dishes, trailer hitch ball, Frisbee, etc. I keep the value stuff on the floor behind the drivers seat....cordless tools, etc. Mine is still big enuf to get stuff lost or buried, but not deep enuf that I can't find anything while still standing on the ground. The bottom of the box stops about a foot up from the bed of the truck, creating a great place to keep a shovel, a few hunks of lumber for under the jack in case of a flat. Good luck with your search.....
    JGO and utacomah[OP] like this.
  4. Jun 27, 2020 at 6:39 PM
    utacomah
    I appreciate the insights! I have looked into Kobalt toolboxes and I do like them more than some of the others
  5. Jun 27, 2020 at 6:48 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    For work I had two tundras over the years. The first was long bed and with a good sized tool box it still left plenty of room for work stuff. The second was a double cab short bed. Even with a fairly narrow but deep tool box I lost most of the bed and a lot of box space.
    So now I'm retired and just bought a short bed Tacoma. Looking for a solution I found the Swing Case. It fits behind the wheel well. It doesn't take up any bed and you still have the full width between the wheel wells.
    Take note. Swing case says only the passenger side will work on 2020's because they don't have the driver side cubby. I'm working on that. Right now the plan is to put a spacer to provide the standoff from the bed, and Then drill and attach the hinge and latch to that. This may change as I keep coming up with different solutions. I just have to pick one.
    https://www.swingcase.us/
    utacomah[OP] and JGO like this.
  6. Jun 28, 2020 at 8:46 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  7. Jun 28, 2020 at 10:57 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I also have a short bed and haul a lot of furniture and random crap and still have plenty of room for stuff with the tailgate down. I keep all my recovery/winch gear, high lift jack (when not mounted on my roof rack on the trail), tools, shovel, cables, and I’ll stuff anything else I need to keep waterproof that won’t fit in the cab. I like to be prepared and I really have no idea what I would do without one
    Mine’s a H&H (made by UWS) that I enamel painted black
  8. Jun 28, 2020 at 1:48 PM
    Slobber
    Slobber Well-Known Member
    Central PA
    2015 Pyrite DCSB
    I have a Weatherguard chest in the back of my short bed.
    https://www.weatherguard.com/products/truck-tool-boxes-equipment/boxes/AllPurposeChest/654-5-01
    It is massive. It sits up on top of the fenders and blocks most of the back window. The quality is amazing though. I highly recommend WG if you can swing it. Mine is also aluminum so no rust concerns being in New England. Also being aluminum and spanning across wheel wells, I did add metal bracing underneath.
    I just sold a house with a basement and garage full of tools and moved into a small apartment with limited storage. The idea was to keep the stuff I didn’t think I could part with. Now that I am a few months into that transition, I have thinned our what it is the chest quite a bit and can store some more things for travel now.
    I can fit a full socket set, recovery bag and straps, tie downs, highlift jack shovel, full electrical kit, misc tools, and three duffel bags as luggage. There will still be room for traction boards when the time comes for those. I don’t regret the size of it yet, it has proven to be very nice to have. In the bed of the truck I can still fit a 48 gallon and two 24 gallon action packers.
    It works well for me but I also have adapted to it. I may have been fine with a smaller box but still, no complaints!
    BigEasy, Naveronski and utacomah[OP] like this.
  9. Jun 29, 2020 at 1:52 PM
    utacomah
  10. Jun 30, 2020 at 5:06 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    on my previous truck I had a UWS. Loved it. That ended up being my sleeping platform for years. Don't think I could deal with the bed loss on my short box, but I miss the storage!
    utacomah[OP] likes this.
  11. Jul 7, 2020 at 5:18 AM
    Slobber
    Central PA
    2015 Pyrite DCSB
    And it is a big loss on a shortbed. Luckily without a house, the need for a truck bed has gone down and has not been an issue. There is no way I would have been happy with this setup a year ago though.
    KanakaRebel and utacomah[OP] like this.
  12. Jul 7, 2020 at 12:00 PM
    rayban1
    rayban1 Well-Known Member
    Seattle
    2015 tacoma sport 4x4
    truck covers usa roll cover, popnlock remote lock, iron cross running boards, p2 trailer Brake, rear view mirror upgrade with auto dim temp and homelink, yakima rack bars , goodyear wranglers, heated side mirrors with directional signal.
    I have a truckcovers USA roll cover added a work cover jr tool box...The tool box, roll cover and my tailgate all lock.....
  13. Jul 7, 2020 at 9:51 PM
    Truck Chick
    Truck Chick Active Member
    Lauren
    California
    '13 Tacoma
    Get one! I have a basic Husky, simple one compartment box. Love it. I also have a short bed, so yes, it makes storage when it's in the bed limited, but it's super helpful when you need secure storage, and when you don't, take it off. Mine is currently full on my camping gear in my garage due to moving a few months ago, but also-very helpful to securely store things in the garage!
    BigEasy and utacomah[OP] like this.
  14. Jul 7, 2020 at 10:06 PM
    utacomah
    @Truck Chick Do you have pictures of your set up by chance?
  15. Jul 7, 2020 at 10:19 PM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    I'm looking at the DuHa Humpstor as a possible low-profile toolbox. It's an odd choice, but I think it can be modified to mount on the header rail under a tonneau cover. It isn't very big, but should be suitable for storing wheel chocks, a grease gun, fluids, and a few tools. It'll also leave enough dead space underneath for me to store emergency supplies, like my trauma kit, litters, and various other items. This should only take up around a foot of my bed, leaving me with 5 feet to work with (the benefits of having a long bed).
    https://www.amazon.com/DU-HA-70200-Humpstor-Truck-Storage/dp/B00HQZ8QE4
    I'll probably have to chop the lid off, since I doubt there will be enough space to open it when stuffed under the forward end of my BakFlip G2. I think it'll do the job of keeping the bulk of my vehicle equipment out of my living room, which is all I really need.
  16. Jul 7, 2020 at 10:52 PM
    Truck Chick
    Lauren
    California
    '13 Tacoma
    not anymore sorry!
  17. Jul 7, 2020 at 11:04 PM
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
    There was a weather guard on mine when I first bought it. I knew I was going to get a tonneau though so I sold it.
    Having said that, I had a super cheap one on my full size Chevy and the weather guard is in such another league it’s amazing. If I were to buy another one or need one for work it would be that one.
  18. Jul 8, 2020 at 7:49 AM
    DG92071
    DG92071 Well-Known Member
    I bought mine used from a local to me company that sells new and used camper shells and tool boxes. It's a Husky. $125, the lock didn't work, and the lock had no key. Another $30 for a key to be made, a little silicone spray, and I was in business. Eventually I'll paint or wrap it black.
    Later I built some sliding sheetmetal trays.
    DCLB!
  19. Jul 8, 2020 at 7:55 AM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    DCSB here as well. Love having the lockable storage, hate taking up 1/3 of the bed! Its pretty easy to remove if needed so...
    9GZwJ3toUEfokK7WQDMQanjQ5bfw2QWFe9YKxsWe_606edaf7465aaaeb484a07eac2e4fb78ad3f8365.jpg
  20. Jul 8, 2020 at 8:10 AM
    utacomah
    No worries thanks!
