Tool to tighten lug nuts on Moto Metals
Discussion in 'Wheels & Tires' started by FoxySandChick, Jul 11, 2009.
  1. Jul 11, 2009 at 3:08 AM
    FoxySandChick
    FoxySandChick [OP] Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    What socket is used to tighten lug nuts on wheels where the lugnut top is flush with the edge of the wheel?
    I have Moto Metal 957's and they were installed with new lug nuts from an offroad shop, I was getting them rotated for free there until that location moved far away from me. My boyfriend took my truck to his work at a dealership to do my oil change and rotation, he says he has to use a thin walled spark plug socket to tighten my lug nuts due to the clearance between the wheel and the lug nut :confused: he says due to this he can not check the torque. He also says that the lug nut wrench in my truck will not work, so if I get a flat I can't change the tire :frusty:.
    What tools do I need to be able to remove the lug nuts and what should I put in my truck in case of a flat?
  2. Jul 11, 2009 at 3:45 AM
    rick
    rick `
    19mm socket
  3. Jul 11, 2009 at 4:08 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Sorry, I wasn't asking the size of the socket...the sockets are too thick to fit around the lug nut which are 'inside' the wheel that is why he used a 'thin walled spark plug socket' which is not the ideal tool. :confused:
  4. Jul 11, 2009 at 4:20 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Check with the wheel dealer you got'em from. They should be able to hook you up with the correct tool.
  5. Jul 11, 2009 at 4:28 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Hi FSC, Tire Rack sells a Gorilla Wrench and thin walled sockets. I like the gorilla wrench because it expands giving me more leverage if I have to take off a tire myself. It has worked great for me. I actually keep one in the tacoma and the honda.
    Also Wally World world sells a knock off the wrench and my second one I bought on Amazon fwiw.
  6. Jul 11, 2009 at 4:29 AM
    rick
    rick `
    its what i used with my motos and never had a problem. sorry i can't help.
  7. Jul 11, 2009 at 4:43 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Yeah I was going to, but they closed the location near me and I don't trust that they can give me good info on the phone. If I can't figure it out then I'll drive out to them sometime.
    I haven't tried it myself, he's the mechanic so I took his word. I'll take a look at it today. My wheel lock tool fits, so I'll compare it to the wrench and sockets. :)
  8. Jul 11, 2009 at 4:46 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Yeah I told him I can't remove them myself anyway :laugh:. I'll check out the Gorilla Wrench and look for some thin walled sockets, I'll take the wheel lock and spark plug socket to compare.
    Looks like that would be what I need!
    http://www.tirerack.com/accessories/detail.jsp?ID=44
    And they have different sized diameter 'thin wall sockets' and adapters...Thanks!!
    http://www.gorilla-auto.com/thin.wall.sockets
  9. Jul 11, 2009 at 8:58 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Funny you post a thread about this. I'm basically in the same situation. I was told to get a good deep 13/16 socket and use a belt sander to grind down the socket so it fits in the lug nut holes on my moto metals.
    I'd prefer the gorilla wrench though, can anyone confirm the 21mm socket it comes with will work with the moto metals???
  10. Jul 11, 2009 at 9:14 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a half inch drive deep well,thin wall socket from sears(craftsman) and a half inch breaker bar should take care of you.
