Tool Suggestions? Ball Joint Press kit!
Discussion in '1st Gen. Tacomas (1995-2004)' started by woad4, Feb 2, 2024.
  1. Feb 2, 2024 at 7:06 PM
    woad4
    woad4 [OP] Well-Known Member
    2003 Tacoma Xtra Cab
    3rzfe
    Research is leading me in circles, I know some of you amigos have been down this road before and can answer it!
    I'm doing a complete front end refresh.
    Upper Lower Ball Joints
    Inner/outer Tie rods
    Upper and Lower control arm replacement
    New shocks
    new coils?
    power steering bushings
    tie rods and bushings
    I'm quite excited to do it all!!
    Is there a Ball Joint Press kit that you've all purchased $100 or less that contains the right press receiver and driver tubes without having to purchase additional add on tubes/adaptors ?
  2. Feb 2, 2024 at 8:21 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    More pieces than you need
  3. Feb 2, 2024 at 8:29 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Here's a tacoma survival kit.....it'll do everything but the rear bearings.....
  4. Feb 2, 2024 at 8:31 PM
    O'Silver_Taco
    MD
    To do the rear wheel bearings/seals.....you'll need all this....
  5. Feb 2, 2024 at 8:37 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Osilver…….
    Unfortunately, rear bearings are in my near future
    Saw some videos that guy made some pipe looking thing to assist (as well as a press)
    Are u saying that all u need is a press?
    Interested.
  6. Feb 2, 2024 at 8:56 PM
    woad4
    3rzfe
    you always come in clutch!
    What ball joint press kit is that?
  7. Feb 2, 2024 at 8:57 PM
    woad4
    3rzfe
    Sorry, I meant ball joint press such as:
  8. Feb 2, 2024 at 9:00 PM
    O'Silver_Taco
    MD
    Timmy has three vids on the rear assault.
    2nd vid has that tool you can buy off ebay for a c-note....
    but that still needs a shop press or access to one.
  9. Feb 2, 2024 at 9:02 PM
    O'Silver_Taco
    MD
  10. Feb 2, 2024 at 9:05 PM
    O'Silver_Taco
    MD
  11. Feb 2, 2024 at 9:06 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    A ~$15 Harbor Freight pitman puller has been all I've needed to separate the ball joints and outer tie rods on these.
    Laxtoy and Wulf like this.
  12. Feb 2, 2024 at 9:10 PM
    O'Silver_Taco
    MD
  13. Feb 2, 2024 at 9:23 PM
    O'Silver_Taco
    MD
    I bought that C-clamp tube kit off Amazon for like $45 few years back.....
    looks like they're up to high 50's or low $60's now.....
    I just tried to buy the one with the most tubes available.....
    .....has saved my ass many times..
  14. Feb 2, 2024 at 9:31 PM
    O'Silver_Taco
    MD
    And No.3 behind a line wrench set, would be one of these....
    That is if you want to do universals in minutes, instead of hours.
  15. Feb 2, 2024 at 9:32 PM
    O'Silver_Taco
    MD
    All these together would allow access to all the bearings, bushings, and balls on the truck.....
  16. Feb 3, 2024 at 1:54 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
  17. Feb 3, 2024 at 9:12 PM
    ControlCar
    Steven
    Sugar Land TX
    Took me an hour to absorb but
    Perfect
    Thanks!!!!!!!
    wonder how many members here have that ‘Shawn’s Tool’ ?
  18. Feb 3, 2024 at 9:17 PM
    woad4
    3rzfe
    turbodb[QUOTED] likes this.
  19. Feb 3, 2024 at 9:43 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    More like "just another dude with a Tacoma," seriously. :) Happy to hear you've gotten some use out of the tutorials - I owe a lot of my knowledge to the good folks here on TW, so it's always nice to be able to give back a bit. Always happy to answer questions as well, if anyone's got them (and I can answer them).
    As for the lift - it all depends on how much weight you have up front. I've been meaning to put together a "front suspension options" guide, sort of like the leaf spring guide, just to round out the front of the truck, but there are so many more options with the front that I've continuously procrastinated.
    Really, here's my "summary." And of course, this is all my opinion; I'm sure others will have different opinions
    Non-adjustable, non-rebuildable:
    1. I don't love OME Nitro shocks (which I ran on my 4Runner) as they seemed too stiff. (not too sprung, but too stiff)
    2. I do like Bilstein shocks (which I ran on the Tacoma for a while) as they seemed to give a nicer ride.
    3. For front springs - if you're stock weight up front, look at OME 880s - or a spring in the 500-550 range. If you've got a bumper, winch, etc. then look at the 881/2/3s based on the amount of weight.
    Adjustable/rebuildable:
    If you can afford the initial outlay of rebuildable coilovers, and will drive them for more than 100,000 miles (through a couple of rebuilds), they will be cheaper in the long run (but with more maintenance work necessary). And of course, give a better ride.
    1. For a mid-range (price/performance) - I think the Toytec BOSS are a good option.
    2. King, ADS, Fox, Icon, and most of the other colors are pretty similar and my sense is that you'll be happy with any of them. If you're going this route, consider a few things, each of which add cost, so you'll need to decide which are for you:
      1. Get a 2.5" shock body for better performance and less shock fade.
      2. Get a resi for less shock fade.
      3. Get adjustable clickers for a more customizable ride.
    For all of these, look at a 550-600lbs spring rate, and then dial in the lift using the ride height adjustment ring (most people call this a preload, but it's not really that). You can get any lift you want, from 0-3+" but stick with something under 2" for the best ride.
  20. Feb 4, 2024 at 6:05 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    There's ball joint kits on Fleabay for like $70, I put one on watch before doing my front suspension . . . didn't need it. You can rent/buy the extractor/pullers from Autozone or O'Relleys. I say rent/buy because the policy at O'reiley's is you can keep it, just let them know you're keeping it so they can get another one in. You'll need two sizes, one for the TRE's, one for the ball joints.
    Probably the most important tool you'll need is this, the infamous BAH. Once you get the puller on the TRE's/ball joints start hammering the knuckle like you're Thor.
    Lots of PB Blaster too. Buy two cans, you'll use most of the first one in any suspension work.
    Energy suspension has two grades of rack bushings, red and black. (red = 8.10103R) Black is a little stiffer, be sure to pick up ES grease, doesn't come with it, it is silicon based and sticky as hell. Poly bushings are notorious for squeaks.
    For the rack I'd just spring for a new OEM rack, it hurts but it's worth it, you'll have to move it back for bushings anyway. I wouldn't recommend cheaping out on ball joints OR an aftermarket rack, go OEM. Best price I found is McGeorge/Ourisman Toyota in Virginia.
    Also change out your sway bar bushings, it need to be removed to do the bushings. Sway bar links too if it's in the budget.
    For springs/coilovers, you won't find a better price than this set from SuspensionLifts. I don't see a year/model/engine mentioned in this thread so contact/search them for a fit if those do not match yours. They respond pretty quickly. Here is how they arrived.
