Tool Roll: What’s in your bag?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wornandtorn, Feb 15, 2022.
  1. Feb 15, 2022 at 9:50 AM
    wornandtorn
    wornandtorn [OP] Well-Known Member
    Nathan
    GA
    2020 Cement Tacoma TRD Sport 4x4
    Hi Fellas (and fellow ladies),
    I’m putting together my must have tools for my onboard tool roll and thought I’d ask you first….
    What’s in your onboard bag/box/cubby etc? What are the must have tools in your truck?
    (For what’s it’s worth, I have a Step22 tool roll.)
    Thank you,
    Nathan
    hiPSI likes this.
  2. Feb 15, 2022 at 9:58 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You need:
    1. A 10mm socket and ratchet
    2. An adjustable wrench
    3. A small pry bar
    4. Duct Tape
    5. Ratchet straps
    6. Zip Ties.
    7. Knife
    You can carry your whole tool box and still not be able to make a repair.
    However, if you carry the above seven items, if you break something you can loosen or cut it, tape it, tie it up, tie it down and tighten it up. You will then get to a place that has proper tools.
    Seriously.
  3. Feb 15, 2022 at 10:03 AM
    Metric Rider
    Metric Rider Well-Known Member
    Gar
    Valley Farms, AZ
    2017 Tacoma TRD Sport
    Body Armor Front Bumper, Smittybilt XRC 9.5 GEN2 Winch, Fab Fours rear bumper, 400 watt inverter anytime, Front camera, On-board ARB air compressor.
    Don't forget the bailing wire, zip ties and duct tape doesn't play well with the exhaust system :rofl:
  4. Feb 15, 2022 at 10:05 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I would add a pair of Vice Grip pliers to that list. Keep it basic, as stated you will not be doing major repairs out there. The intent here is have what you need to patch up and limp home.
    PS: and some of that 4 inch wide Gorilla repair tape is handy to have too. That shit is pretty amazing!
  5. Feb 15, 2022 at 10:05 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    don't have a tool roll. I have a entrenching tool and the factory jack.
    wornandtorn[OP] and hiPSI like this.
  6. Feb 15, 2022 at 10:09 AM
    SGT_Didymus
    SGT_Didymus Member
    2022 MGM SR5 DC RWD LB
    Pretty much this.
  7. Feb 15, 2022 at 10:19 AM
    Shellshock
    Iowa
    Apparently you guys aren’t buying the good zip ties
    (100PCS 11.8 Inch) Metal Cable Zip Ties, 304 Stainless Steel, Multi-purpose Heavy Duty Self-locking Cable Ties,Suitable for Exhaust Wrapping, Fence, Outdoor and Canopy Etc. https://smile.amazon.com/dp/B086265WH2
    Kodiak420, SlickFly, Volt and 5 others like this.
  8. Feb 27, 2022 at 8:49 PM
    tacocat_2019
    tacocat_2019 Member
    Jon
    Central Texas
    97 SR5 4x4 & 2019 SR5 DCLB
    3" OME Lift SPC UCAs Marlin flywheel and clutch 265/75/R16 BFG KO2 Softopper 4Xinnovations sliders, rear bumper, and skid plates
    Holy hell. how did I not know about these. On order and will be added to my kit.
    Thank you!
  9. Feb 27, 2022 at 9:16 PM
    Shellshock
    Iowa
    They definitely come in handy. I’ve used a lot of them over the years.
    wornandtorn[OP] likes this.
  10. Feb 27, 2022 at 9:39 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Not the complete set, but most of it. I've added an allen key set and a torx set.
  11. Feb 27, 2022 at 9:44 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I keep a small tool bag with 10-19mm 3/8” sockets and ratchet, 10-17mm wrenches, an adjustable wrench, Phillips and flat tip screw driver, vice grips, duct tape and zip ties. Probably some other random stuff in there too but those are the basics for most stuff on the truck or anything else out there.
  12. Feb 27, 2022 at 9:46 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Typically I carrry a code reader and what it takes to change a belt, a tire, repair a vacuum line, and tighten a battery cable or throttle body. Any more than that and you are probably calling a tow truck. Most often used: zip ties, vacuum line.
  13. Feb 28, 2022 at 12:56 AM
    Montana_Actual
    Montana_Actual ;)
    Make that multiple 10mm's. Long and short. At least one will run away.
    I have tool boxes. Seeing the above thread reminds me to grab a spare belt. Anyone got the part number? I'll probably hit up Napa tomorrow for it.
  14. Feb 28, 2022 at 6:54 AM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    Rather than a 10mm, I carry one of those Gator Grip multi socket things and a 3/8. Fits a 7 to 19 mm and anything in between. I’ve even turned an eyelet and a wingnut with mine, It’s a been a very handy tool.
    Just buy it at a HD, Lowes, or some other reputable tool store, Amazon has a lot of reviews on it with people getting a Chinese counterfeit. The real one is made in USA:oldglory:
    wornandtorn[OP] and Foushee like this.
  15. Feb 28, 2022 at 7:09 AM
    YotaJoe
    YotaJoe ig @_yotajoe
    Darren
    Vegas
    2017 Tacoma TRDsport 4x4
    insta@_yotajoe : 5100s / spc uca, 34' cooper mts, allpro sliders/skids. sherpa roof rack. agency6 goodies, BAMF hybrid front bumper, BD lights/Hella spots.
    Good stuff. Subed
  16. Feb 28, 2022 at 7:29 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I feel like this should be in the Tacoma owner’s manual.
    I’m also buying those metal zip ties right now lol…I had no idea those existed.
  17. Feb 28, 2022 at 8:41 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    This is the one tool I know for sure I will be able to use:
    When I use it, someone that actually knows what they are doing shows up with the right tools.
  18. Mar 1, 2022 at 4:54 AM
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    2 socket sets
    2 breaker bars
    Cordless 1/2 impact
    Cordless 3/8 impact
    Cordless 3/8 impact ratchet
    Sawzall
    Jump cables
    Jump box
    Flat tire repair I.e plug kit, air compressor, can of fix a flat
    Wd40
    Pb blaster
    Carb cleaner
    Duct tape
    3 pound maul
    Hammer
    2 torx bit sets
    4 Allen wrench sets
    2 open end wrench sets
    2 crescent wrenches
    Assortment of screwdrivers
    That’s just the tool list. I carry more with me.
  19. Mar 1, 2022 at 4:57 AM
    Montana_Actual
    Montana_Actual ;)
    Laughs in Montanan.
    Sometimes cell service is harder to find than the right tools and a little effort.
    Yea, this mod is on my list. Nice setup :thumbsup:
    Also forgot to mention a chainsaw.
  20. Mar 1, 2022 at 4:57 AM
    BigFatDynamo
    BigFatDynamo Well-Known Member
    Charlotte, NC
    2019 TRD OR
    What the other guys said plus:
    - sledgehammer
    - folding/manual saw
