Too Late to Change Rear Differential Oil??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blacktaco8, Aug 7, 2012.
  1. Aug 7, 2012 at 6:48 AM
    blacktaco8
    blacktaco8 [OP] New Member
    MA
    08 SR5
    Is it ever too late to change your rear differential oil? I have 120K on my 2008 truck and I was thinking of changing it for the for the first time.
    I haven't had any problems with the truck so far, but I'm thinking if I change the diff oil I may change my luck.
    Has anyone else been in this mental dilemma?
  2. Aug 7, 2012 at 6:52 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    its never too late.. do it or pay later
  3. Aug 7, 2012 at 6:52 AM
    PhantomVirus
    PhantomVirus Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    My BMW mechanic told me that in his opinion if you never changed it - don't.
    YMMV of course ;-)
  4. Aug 7, 2012 at 7:07 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can make a decent argument for that when it comes to an automatic transmission but that makes no sense when it comes to a rear end. The rear end is a constant mesh gear system, any grit just wears the gears faster where as having some grit in a worn out torque convertor can actually keep it running.
    That's why you don't let a BMW mechanic near a pickup :laugh:
  5. Aug 7, 2012 at 7:11 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I realize this is the 2nd gen section but my dads 1st gen 02 DC tacoma has 315k miles on it with no rear diff fluid change. never had any problem but he is not rough on the truck and it only sees pavement with a path here and there you could drive a cadillac down.
  6. Aug 7, 2012 at 7:13 AM
    Pugga
    Massachusetts
    Yikes :eek:
  7. Aug 7, 2012 at 7:17 AM
    2000GTacoma
    Snow Hill NC
    no doubt but he does keep up with transmission fluid filter and oil and filter changes alone with the air filter.
  8. Aug 7, 2012 at 7:25 AM
    Pugga
    Massachusetts
    Sounds like he does keep up on maintenance generally, why did he let the rear diff go? That one is probably the easiest of them all to change. No filter, just drain and refill.
  9. Aug 7, 2012 at 7:27 AM
    2000GTacoma
    Snow Hill NC
    just never has not really sure he has a reason but he still drive it over 100 miles daily. but yes i agree no hard to change i just changed mine about 6 or 7k miles ago.
  10. Aug 7, 2012 at 7:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The arguement of to change or not to change ANY fluid/oil/lube is clear cut. Fluids oxidize, and additives become neutralized over time. Change it according to the MFG's guidelines or at your next earliest opportunity.
    Any benefits to not changing a fluid are negated by the damage caused by old fluid/oil/lube. Old school thinking on this subject is false.
  11. Aug 7, 2012 at 9:56 AM
    blacktaco8
    MA
    08 SR5
    Thanks for the insight everyone. Leaning toward changing it.
  12. Aug 7, 2012 at 10:03 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Of course you change it, it is a recommended service for the truck. Mobil 1 (75-140) for the rear. I changed mine (at the dealership) when the truck went through deep water at 6 months old, and it was contaminated. I performed the rear breather mod. Now, at almost 40,000 miles I did it again (at Speedfreeks in Vista) and it was dark, but no water contamination. Did the transfer case and front diff as well (75-90 Mobil 1).
    Oil breaks down, it needs to be changed to maintain lubrication of the gears! You change your motor oil, don't you?
  13. Aug 7, 2012 at 10:23 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Iirc, doesn't BMW say they use a lifetime fluid?
  14. Aug 7, 2012 at 10:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Find a new mechanic. [​IMG]
  15. Aug 7, 2012 at 12:49 PM
    09SpeedwayBlue
    09SpeedwayBlue Active Member
    Craig
    Houston
    09PreRunner SR5 DCLB 4.0L, 4x2
    I will get in line with everyone else, change it!!
  16. Aug 7, 2012 at 1:05 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Change it if you can remove fill plug and drain plug. Although 120K could have welded fill plug to diff.
  17. Aug 7, 2012 at 1:13 PM
    2000GTacoma
    Snow Hill NC
    thats why op should remove fill plug first that way if he cant get it off he can take it somewhere or do whatever.
  18. Aug 7, 2012 at 1:15 PM
    Pugga
    Massachusetts
    x2 and that is awesome advice for any fluid change! If you can't get fluid back in, don't drain it! Even shitty fluid is better than no fluid. No fluid = tow truck.
  19. Aug 7, 2012 at 1:18 PM
    Manwithoutaplan
    ID
    Change it man.
  20. Aug 23, 2012 at 5:31 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    it's too late when the diff starts making noise :eek:
    i bought my truck with a little over 100k on it, maintenance record unknown. i dumped the diff's, t-case, trans and the oil wasn't too bad. now she's rolling with Lucas 75-90w and it's smooth.
    everyone has their own schedule of preventitive maintenance, gear oil should be part of it :cool:
