Tonneau cover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pressedmeat, Apr 28, 2024.
  1. Apr 28, 2024 at 11:26 AM
    pressedmeat
    pressedmeat [OP] New Member
    Vinny
    2023 off road
    I’m having a hard time deciding between a tri fold, and a roll up. All opinions are wanted. Also, what brands should I look at.
  2. Apr 28, 2024 at 11:38 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I'd consider how often you plan to use and/or remove it.
    Tri fold is easier to use often, roll up is easier to nearly fully open bed space or remove.
    Also consider tri folds eventually leak, the foam absorbs water, and become heavy AF.
  3. Apr 28, 2024 at 12:05 PM
    Ace04
    Ace04 New Member
    Pennsylvania
    2023 Lunar Rock DCLB TRD Off-road
    KDMax-Pro-10
    Holling likes this.
  4. Apr 28, 2024 at 12:14 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    another good point!
    and while it does look good, OP should keep in mind since the tri fold does sit IN the truck box, the Tacoma's already short box is even more limited. In the end, this is what pushed me to sell my tri fold and buy a fiberglass topper. What was left of the height didn't fit what I used the truck for,,, including simply a cooler.
    Ace04[QUOTED] likes this.
  5. Apr 28, 2024 at 2:40 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    I have an extang 2.0 tri fold easy on and off in 5 minutes.
  6. Apr 28, 2024 at 3:41 PM
    kane22
    kane22 Well-Known Member
    my vote is role up, Ive been really happy with mine
  7. Apr 28, 2024 at 4:32 PM
    duckytw
    duckytw Well-Known Member
    Any. They all offer a slight security because the back is covered from peeping eyes, the all offer somewhat waterproof design, and they all do pretty much the same thing. All depends how much you want to spend.
  8. Apr 28, 2024 at 4:34 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    There’s a vendor on this site @truckalter that can help you out. I’ve seen a lot of positive things about the Lomax trifold
    truckalter and Holling like this.
  9. Apr 28, 2024 at 4:39 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    You might consider looking locally for a used OEM trifold cover. The OEM cover doesn't get a lot of love here, but it is a beast of a cover and is very easy to remove and install. You can put a decent amount of weight on it and not hurt it at all.
  10. Apr 29, 2024 at 7:29 AM
    truckalter
    truckalter Well-Known Member Vendor
    Luke
    Waynesville, NC
    We deal with most of the brands and offer discounts on what we sell to forum members.... Either way feel free to reach out as I am always happy to work through options for you. Best thing to keep in mind is there is no best tonneau cover but more what is best for you and how you use the truck.
  11. Apr 29, 2024 at 7:34 AM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    I’ve had a Lund Genesis Elite trifold on my Tacoma for the past six years. Very happy with it. The “Elite” version is worth the extra dollars: the cover is high-end convertible top material.
    Easy on and off. No tools required. Utilizes the truck’s bed rails.
  12. Apr 29, 2024 at 8:02 AM
    brigsby99
    brigsby99 Member
    Montana
    2022 TRD OR MT
    I have the Truxedo Pro x15 that I bought from RealTruck. IMO the ability to use the bed for work is a necessity that a trifold doesn’t quite allow. It’s also cheaper…
    The Pro x15 sits nice and flat, is very durable, and is waterproof enough (not 100% but will keep your stuff from getting soaked in pouring rain).
    I live in Montana and installed mine in the winter so sadly the wrinkles never quite came out of the fabric (unless it’s in direct warm sun)… RealTruck sent me a replacement fabric for free which I plan to install in summer. Hopefully the constant heat will help it form permanently flat—even in the cold.
    Besides that it’s excellent overall. Installs over everything factory with no drilling required and when rolled up even allows you to still use those plastic factory bed rail hooks. IMG_4697.jpg IMG_4612.jpg
    GaDawg78644 and kane22 like this.
  13. Apr 29, 2024 at 8:09 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    I'm happy with my BakFlip tri-fold. Allows you to still use the entire bed.
