Tonneau Cover?
Discussion in 'Tonneau Covers, Caps and Shells' started by stro1965, Oct 6, 2008.
  1. Mar 10, 2010 at 2:44 PM
    #101
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    You just need to trim the extender a little and it will work fine.
  2. Apr 19, 2010 at 6:09 PM
    #102
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
  3. Apr 23, 2010 at 4:54 AM
    #103
    Ocean's
    Ocean's Well-Known Member
    I just talked to my Undercover Dealer, and he says the 5' New Design Undercover SE Top, will be here by the end of the month... Been waiting patiently for the last 6 months...lol
    apparently, the 6' Undercover SE tops are already out there and in use...
    Will post pix when it arrives
  4. Jun 14, 2010 at 5:57 PM
    #104
    copdude33
    copdude33 Well-Known Member
    Roxboro, NC
    2018 Tacoma Limited 4x4
    Tint, bed cover, led high beams, HID low beams, blacked emblems
    If you want a folding one then be prepared to have a leaky cover. I have had both, undercover and a HD bakflip. The bakflip should be called a leakflip. Sure it's nice to be able to fold it up but the leaking is a pain. The undecover is nice and almost water tight. The undercover does not dent and have rubber joints that will end up cracking. The HD Bakflip will dent, gets smoking hot and does not fit as tight and secure as the Undercover. They now make the SE undercover for both the 5 and 6 foot bed.
  5. Jun 14, 2010 at 7:22 PM
    #105
    sixdoubleseven
    sixdoubleseven Well-Known Member
    Dave
    Boston
    14 DC 4x4
    ^ I have barely any leaking with my Advantage, if you can call it leaking. Maybe one corner has a few drops.
  6. Jun 14, 2010 at 8:47 PM
    #106
    NAYo2002
    Great Falls, MT
    x2
    Only time I see water in my TorzaTop is going through an automatic carwash with multiple pressure hoses spraying from all angles... even then, it still keeps the stuff in the bed dry... just some drops of water along the walls.
  7. Aug 3, 2010 at 8:03 AM
    #107
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    I downloaded the installation instructions on the Access cover and they state the bed rails are removed and all is reinstalled using what looked to be some small tubing as a standoff material (probably aluminum) on each screw. How flimsy or sturdy would you say the tie down rails are with this type of mounting and was I correct in my description of the standoff material? And any chance I could get the length of the standoff? I'm thinking that if the tiedowns are not as sturdy as they use to be, maybe adding a solid spacer down the length of the bedrails vice a few small spacers.
    Thanks,
    Joe
  8. Aug 3, 2010 at 9:22 AM
    #108
    monrad
    monrad Coprolite
    B'wood, SC
    09 DC short box TRD Sport, TM
    Avid light bar+RBG, Lightforce 140s, fog mod, FSM badges, Bobcatoshi grille + Stampede, JDM DRLs, TRD cat-back, rear spring TSB, AccessLE
    I'm not Veccster, but the standoffs on mine are hard plastic cylinders, about 0.783" long, 0.700" diameter, 0.192" wall thickness. I'd characterize it as a solid mount with the wall thickness and type of plastic.
  9. Aug 3, 2010 at 9:32 AM
    #109
    JoeSchmuck
    Joe
    Virginia
    You must have a caliper to measure with. Thanks for the specs and your opinion that it's a solid mount.
    -Joe
  10. Aug 3, 2010 at 4:23 PM
    #110
    JoeSchmuck
    Joe
    Virginia
    I just ordered the Access LE from this site with great pricing: http://www.truckalterations.com/html/tacomaworld.html
    The primary reason I ordered the LE is because both sides of the rear cover latch together as opposed to the regular Access cover where the drivers side is automatic but the passenger side is a manual latch. I also purchased the Pop & Lock Tailgate Lock (Not discussing the lock in this thread, it was just part of my order).
    EDIT:
    Installed the cover, Love It! Pop & Lock is installed too but it looks like cheap plastic but it works very well.
    -Joe
  11. Sep 20, 2010 at 7:19 PM
    #111
    botayota
    botayota Well-Known Member
    New England
    2023 Tacoma TRD Sport 4x4 Access Cab
    Blue Crush Metallic
    I want to install a bed cover before winter hits...
    Considering either a roll-up or fold up model...
    Snow load capability ... I'm in New England...
    At times I haul wood & mulch in the bed...
    Also I really want to be able to keep the stock rail system with the slider
    knob tie downs...functioning.
    Done alot of reading on this tread, and a couple others, and so far Access LE, and Extang Trifecta...seem to stand out for my needs, but I'm still not decided.
    Looking for some recommendations....???
  12. Sep 20, 2010 at 8:30 PM
    #112
    NAYo2002
    Great Falls, MT
    If you want a tri-fold, advantage torzatop (better locking system than the Trifecta.) However, you have to decide whether you want a roll up, hardtop, or trifold first.
    For me, I'd have gone with a roll up type if I didn't get the torza.
    Hard covers are too much of a pain to remove/store on the go.
  13. Sep 21, 2010 at 12:56 AM
    #113
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    i really like my access
  14. Sep 21, 2010 at 1:40 AM
    #114
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    i just bought one made by Undercover
  15. Sep 21, 2010 at 3:28 AM
    #115
    JoeSchmuck
    Joe
    Virginia
    I can't speak to the snow handling capability of the Access roll-up cover yet but I read it was good. As for being able to keep the tiedowns, if you want any tiedowns on the front rail, install the tiedowns before putting on the front piece of the access cover. The side rails can still be installed after the cover side rails are installed although you must slide them on from the rear opening (no biggie). As for vertical strength, someone else will have to post if the plastic spacers are good enough (maybe someone that has moved a queen sized matteress down the freeway?). I question the strength in that area and will be installing two square aluminum tubing rails to replace the spacers. This will give it more vertical pull strength without bending and the square tubing isn't really expensive at Lowes. I've just got to get off my lazy butt and get to it.
    I do love my Access cover and I think the regular access cover is better than the LE just because both sides secure with spring loaded latches, but it comes at a price.
    -Joe
  16. Sep 21, 2010 at 4:27 AM
    #116
    killerken
    killerken Well-Known Member
    Philadelphia
    09 toyota tacoma dbl cab trd
    Access LE Cover Toyota Factory Nerf Bars Dynolock Tail Gate Lock
    I would go with the Access LE cover. I live in Philadelphia and we had over 70" of snow last year and I had no problem with my access LE cover.
    :cool:
  17. Sep 21, 2010 at 4:57 AM
    #117
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    I had 3 different folding covers on 3 different trucks. 1 Fold A Cover LS (2002 Ford FX4), 1 Advanced cover (2005 Nissan Titan Crew cab) and 1 Fold A Cover G4 (2011 Tacoma DC TRD Off/Road). None of these covers leaked. I just installed a fold a cover G4 on my 2011 Tacoma DC TRD Off Road. Washed the truck and went through 1 rain and no leaks. Cover locks for security and will even lock the tailgate with lock attachment supplied. I didn't install lock attachment, because I have pop & lock. I like to the fact to be able to secure the bed and bed extender, also when I need to use the bed, I unlock cover with key and fold back in seconds.
  18. Sep 21, 2010 at 6:30 AM
    #118
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    The LE made the top of my short-list as far as roll-ups go. Now if only I can make up my mind on roll-up vs. trifold...
  19. Sep 21, 2010 at 6:35 AM
    #119
    ImpulseRed008
    Susan
    SC
    Roll ups give you the capability to get the tonneau out of the way in a matter of seconds without having to find a way to transport it home. Granted the tri-fold comes off easily, but if you buy something big, you run the risk of damaging it on the way home.
    I love my Access L/E. Had a tri-fold before and it spent more time off the truck than on.
  20. Sep 21, 2010 at 6:40 AM
    #120
    SCFirefighter
    Stephan
    Cary, NC
    How is the Velcro? That's a concern of mine. It sounds cheap. Does it hold up clean or get dirty/gritty and stop sticking like the stuff on clothes and boots does?
    ETA: I'm concerned about it because, more than likely I would keep it rolled up more often than not, exposing the Velcro.
