Tonneau Cover using existing rails?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by allelopath, Nov 30, 2023.
  1. Nov 30, 2023 at 7:40 AM
    allelopath
    allelopath [OP] Active Member
    2023 Toyota Tacoma Trail
    Following on to my previous question ... I now wonder if they make covers that use the existing bed side rails. I would think that there could be panels that snap into the rails.
    What do you know?
  2. Nov 30, 2023 at 7:47 AM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    I have the extang 3.0 trifold and it uses the existing rails .:thumbsup:
  3. Nov 30, 2023 at 8:03 AM
    TacoJoe480
    TacoJoe480 Well-Known Member
    Louisiana
    2021 Cement Tacoma TRD Sport
    Many!
    BakFlip uses existing rails.
    Stevie17 and allelopath[OP] like this.
  4. Nov 30, 2023 at 8:24 AM
    allelopath
    Ah, the complication I forgot to mention...GoRhino chase rack.
  5. Nov 30, 2023 at 8:46 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    If you’re a cheapskate, tyger sells a roll up and a soft trifolds on Amazon but it looks like there’s a lot of different brands at that price point now. Both use accessory rails for install. I want to payoff and regear before I get a cap, so a $200 tonneau is perfect for my use until then.
    Roll up
    Trifold
    Edit: just saw your last post. I’m doubtful you’re going to find anything that’s compatible with that thing. All the tonneaus I’ve seen or helped install need to lay on top of the bed rails which that chase thing is obscuring. There’s only a hand full of bed racks that are specifically designed to sit above the rails to allow tonneau installation.
    I could be wrong though
    Barsoom likes this.
  6. Nov 30, 2023 at 9:38 AM
    allelopath
    I wonder if the chase rack could be removed, then tonneau cover installed and the rack installed on top of that.
  7. Nov 30, 2023 at 9:46 AM
    musicisevil
    Alaska
    2019 TRD Sport
    I’m not familiar with the retrax from your other thread, but something like that which lays flush with the top of the bed rails and rests completely inside the bed is the only thing I can imagine working for you. This is all just speculation though…
    soundman98 likes this.
  8. Nov 30, 2023 at 10:20 AM
    GrimesCoAg
    GrimesCoAg New Member
    2023 SR5
    Lomax also uses the existing rails and sits more over the bed than some others. You should call Luke at Truck Alterations to see what he says. I just ordered a lomax for the tacoma, but the one on my f250 still allows bed rails.
    allelopath[OP] likes this.
  9. Nov 30, 2023 at 10:22 AM
    sarcastictechsupport
    sarcastictechsupport Well-Known Member
    SoCal (805) - Mohave Desert
    2020 Super White TRD OR
    My extang 2.0 solidfold bolts into existing rails
  10. Nov 30, 2023 at 10:45 AM
    FMKev14
    FMKev14 New Member
    2021 Tacoma DCLB TRD Sport
    My '21 Taco came with a Toyota OEM soft cover that uses the existing rail system - a few sliding clips that go into the rails and then the cover attaches to those clips. I wanted a hard cover (still need to get rid of the soft cover) so I bought the Lomax (as posted above - from Luke, Truck Alterations) and I love it. You may actually be able to get this lomax to work in your situation (not sure). the Lomax is narrower up near the cab - so you might want to measure what width you have in your situation. For mine, the width at the cab is 57 7/8 inches. I have a '21 Sport with 6' bed. Hope that helps
  11. Nov 30, 2023 at 10:47 AM
    Slow_sr20
    Slow_sr20 Well-Known Member
    23’ DCSB O/R
    Truxedo ProX15 utilizes the stock rails.
  12. Nov 30, 2023 at 10:59 AM
    allelopath
  13. Nov 30, 2023 at 11:03 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Hi, fellow cheapskate here.
    The tyger cover fits perfectly and holds up well to tough use. I honestly don't understand how people end up spending $1,000+ on these things.
    Barsoom and musicisevil[QUOTED] like this.
  14. Nov 30, 2023 at 11:26 AM
    musicisevil
    Alaska
    2019 TRD Sport
    I’m definitely happy with my roll up from them. The testimony that sold me was from a TW user who lives further north than me and hadn’t had any issues after 3 years. They see -20f for weeks at a time and get significantly more snow than where I’m at. If dude was satisfied, I figured I would be too.
    I’m on my 2nd winter and no complaints so far
  15. Dec 1, 2023 at 8:18 PM
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Undercover Flex uses existing rails.
  16. Dec 1, 2023 at 9:36 PM
    Coldpunk
    Coldpunk Well-Known Member
    Karl
    Missouri
    2022 Lunar Rock TRD Off Road Long Bed
    TRD lift w/ OME HD rear pack, Diode Dynamics ss3 fogs and 18” light bar, front/rear steel bumpers, Badlands winch, Method 701’s, at4W pizza cutters, RSI Smartcap, RCI sliders, RCI bed stiffeners, Front Runner load bars, Fitcamx, anytime front/rear camera,
    allelopath[OP] and musicisevil like this.
  17. Dec 1, 2023 at 10:22 PM
    musicisevil
    Alaska
    2019 TRD Sport
    This is an awesome set up!
  18. Dec 2, 2023 at 8:46 AM
    Coldpunk
    Karl
    Missouri
    Thanks! I went with Peragon specifically because of their compatibility with BillieBars rack system. Wanted to be able to haul kayaks while still having secure lockable bed storage.IMG_6377.jpg
  19. Dec 2, 2023 at 9:44 AM
    allelopath
    Are the panels easily removable?
  20. Dec 2, 2023 at 10:53 AM
    McHale
    McHale Well-Known Member
    2023 Toyota Tacoma TRD OR MGM Access Cab
    I keep seeing comments about tonneau covers that use the existing rails when they really don't. Any tonneau cover that comes with it's own rails that mounts to the existing rails doesn't count. Bakflip is the worst. You have to remove the OEM rails, mount their rails in the OEM rails' place them mount the OEM rails to the bakflip rails. I feel Xzibit should really be their spokesperson.
    The cheapo hard cover I just bought uses the existing rails as in, you slide 3 small brackets down each side and it mounts to them. It's the main reason I bought it. The Extang is basically the same cover with better clamps and costs a bit more.
    https://www.ebay.com/itm/404616529228
    Irons and allelopath[OP] like this.
