Tonneau cover freeze up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nirango kid, Dec 28, 2021.
  1. Dec 28, 2021 at 6:08 AM
    Nirango kid
    Nirango kid [OP] Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Hi all who have tonneau covers.
    I have had soft tonneau covers on all my Taco over the years and yes some have frozen to back corners but not as bad as this new Taco. First off it is a bit of a struggle just to open it during the Summer as the tonneau sits differently and makes it a little harder to open.
    Now with Winter just wondering what you guys do for the tonneau not to freeze to make the tailgate easier to open.
    I was thinking of some kind of silicone spray or a dab waterproof stuff but not sure.
    Any suggestions would be appreciated as long as they are not nasty.
    Thanks
  2. Dec 28, 2021 at 6:10 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I think youre on the right track w the spray.
    TacoManOne and Montana_Actual like this.
  3. Dec 28, 2021 at 6:31 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I don't do anything. If there's ice I push on the tailgate before I try to open it. That breaks the ice and it opens like normal.
  4. Dec 28, 2021 at 6:32 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Silicone spray is probably a good solution. WD-40 would probably work too. Although, I have a hard cover and can't say I've ever run into any freezing issues I couldn't solve just by simply opening the tailgate.
    zoo truck likes this.
  5. Dec 28, 2021 at 7:05 AM
    Nirango kid
    Gilles
    Ontario
    The tailgate does open with a little bit of tugging just afraid that I will rip the seal across the tail gate as the Winter has been weird here. Freezing rain then thaw then snowing then thawing and rain etc etc. Thanks all for your inputs.
  6. Dec 28, 2021 at 7:19 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    My Bakflip is very hard to open in the winter as well.
  7. Dec 28, 2021 at 7:22 AM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    Recently had the same problem in Massachusetts. No amount of pushing, pulling or banging on the hard cover would break the ice to the point where I felt comfortable opening without ripping the seal. Maybe the spray is something to try, seems like a hassle though.
  8. Dec 28, 2021 at 7:35 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I just opened my tail gate and flipped up the factory tacoma cover this morning after some snow, and freezing rain on it....no problemo.
  9. Dec 28, 2021 at 7:36 AM
    Nirango kid
    Gilles
    Ontario
    I think it is the design of the tonneau cover it does not cover the whole back top of the tailgate like the older ones did. On the older models it was not as hard to open like this one is a pain in the ass. As the snow or ice just sits on top of the tailgate and when it thaws if runs underneath the tonneau and freezes. Hope to find the right remedy for this annoying issue soon. As for folding back the trifold is usually no problem if there is no buildup of ice or snow of which I will not fold unless it is clear and try not to use much in the Winter.
  10. Dec 28, 2021 at 1:11 PM
    Tacomaryan18
    I just bought some PB blaster silicone spray. I sprayed it on an old rag and wiped the weatherstripping. I went ahead and did all the door seals also. The last time it rained and froze a couple weekend ago I had a bitch of a time even getting in the truck without feeling like I’m going to rip the seals apart. We will see how this works.
  11. Dec 28, 2021 at 1:38 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
  12. Dec 28, 2021 at 1:50 PM
    Tacomaryan18
    Well at least we made it past ten posts before the first smart ass showed up..
    Chew, Spankomatik and 2021SR5V64WD like this.
  13. Dec 28, 2021 at 2:13 PM
    Nirango kid
    Gilles
    Ontario
    Probab
    LOL yeah the first one of many but we have been lucky over the holidays that they were not around.
  14. Dec 28, 2021 at 3:28 PM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Petroleum jelly (Vaseline) works well.
  15. Dec 28, 2021 at 3:34 PM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    I’d be careful with Vaseline on rubber seals. It can make them swell. So many options for jokes here……but it seriously does.
  16. Dec 28, 2021 at 6:27 PM
    willie2
    Nova Scotia Canada
    4 Banger 5 spd
    Isn't rubber it is EPDM and Vaseline works fine for it or at least it does for me.
  17. Jan 2, 2022 at 7:36 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    My solution is : when going to self service wand wash, do it later in the evening, when no cars in lane waiting for car wash.
    When done with washing, spend 10 minutes and wipe door rubbers and tonneau rubbers and surfaces with microfiber towel.
    Outside was -26c, no prob next morning to get in to the cab or box.
    Overall, times to time wiping with silicone lube helps as well.
  18. Jan 3, 2022 at 11:23 AM
    zoo truck
    None
    Funny this thread came up the other day. We just had a day of warmer temps and rain. This morning a cold front moved through freezing everything to ice. When to load a chair in my trucks bed. Could not open the tail gate nor open the tonneau cover. First time thats happened. Well a bucket of hot water poured over it did the trick.
  19. Jan 3, 2022 at 12:09 PM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    I used to keep a bottle of de-icer in my truck prior to moving to warm weather. I would spray any contact area with my roll up cover on the rails that it sits on as well as any moving mechanisms that could possibly freeze during the winter months. Didn't really happen often though.
