Told I need a new rear end
Discussion in '1st Gen. Tacomas (1995-2004)' started by BowlTurninHiker, Jun 22, 2021.
  1. Jun 22, 2021 at 6:47 PM
    BowlTurninHiker
    BowlTurninHiker [OP] Member
    Middle TN
    2002 White Tacoma Double Cab TRD
    OME suspension kit
    I have a 2002 double cab 4wd with 421k miles on it. The other day I noticed that the rear axle seal was leaking. Took it to my mechanic and while he was checking everything out, he found that the pinion bearing was shot and said that I need a new carrier. He said the cost for a rear diff carrier assy from Toyota would be $3200 and change. To rebuild the entire rear end it will cost $7000. Anyone have any other ideas/options out there to help with costs? My mechanic, whom I totally trust, told me that he wouldn’t recommend dumping that kind of money in it with the amount of miles on the truck. Thoughts?
  2. Jun 22, 2021 at 6:50 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I would look around for a used rear axle assembly out of another truck. Shouldn't be too hard to find unless you want one with the e-locker in it. Be way cheaper. Usually see a used rear axle assembly for around 3 or $400. E-locker ones will be more.
    Just make it's got the right gear ratio in it that matches your front diff
    Buying a new one would be crazy
    Superdave1.0, tacojim02 and Wulf like this.
  3. Jun 22, 2021 at 6:51 PM
    Bishop84
    Bishop84 Well-Known Member
    http://4xaddict.com/ TOR seems to be a big name and it would be worth giving them a call to see if you can do a quote.
    Most shops won't rebuild diffs anymore, but it's really not that hard, nor do the parts cost that much.
    Black97v6MT and Wyoming09 like this.
  4. Jun 22, 2021 at 7:06 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Your mechanic has a meth habit.
    Now go out and find a real mechanic that can actually set up a rear end with a third member.
    FWIW, $1500 and change will get you a brand new one from several Toyota dealers. $300-$500 will get you a used one.
  5. Jun 22, 2021 at 7:18 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    never use that mechanic again... that blatant robbery. did he even disassemble the differential? should only cost a few hundred to rebuild that diff. but used ones are plentiful. i sold a complete 3rd member for $25.
  6. Jun 22, 2021 at 7:22 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Replace the rear axle seal, differential breather and mechanic.
  7. Jun 22, 2021 at 8:14 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    Heed all of the above advice, what that shop is quoting you is just plain wrong.
  8. Jun 22, 2021 at 8:22 PM
    BowlTurninHiker
    Middle TN
    OME suspension kit
    Thanks for all the quick responses. I typically stick with Toyota parts, is there a brand of diff parts that anyone of you would recommend?
  9. Jun 22, 2021 at 8:36 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    East coast gear supply ships newly rebuilt diffs and they are basically oem quality. Also your mechanic is fucking you
    alarka and SLAPS 65 like this.
  10. Jun 22, 2021 at 10:08 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Just buy a used axle lower mileage if you can. Should be in the $300 ballpark. Its about 16 bolts 2 retainer clips and 12 lug nuts. A good mechanic should be able to do it for less than $600 in labor.
    Black97v6MT and SLAPS 65 like this.
  11. Jun 22, 2021 at 10:17 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    did he have a loaded gun ..................
    within a reasonable distance there is a taco thats has been rolled over
    air bags deployed whereby an insurance has totaled
    point im making is there is a rear end available for much less
    fewer miles
    & only a weekend to swap out
    still how much longer will engine .....trans....etc will last
    either way $3200/$7000 = sizable down payments new/used
  12. Jun 22, 2021 at 10:20 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Holly shit. You can get a full Currie Dana 60 for like $5k.
    That's the "I don't want to do this work" price.
    If you trust this guy, I assume you're a repeat customer. I can't imagine how much money you've needlessly spent with this guy. Yikes.
    Black97v6MT and otis24 like this.
  13. Jun 22, 2021 at 10:30 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Last February I tore up my truck’s rear end. The ring gear was hosed. It took out the carrier and the locker as well.
    Here’s a video of the incident.
    https://youtu.be/PEJH79AYu2c
    I had them fix everything and while they were in there they replaced the wheel bearings and they regeared to 4.88s.
    They also regeared the front diff and installed an ARB air locker in the front diff that I supplied. I also supplied new CV axles.
    My total cost was $4300 including the CVS but not the locker.
    I bought the locker several
    Months before. It was another $1000.
    Black97v6MT likes this.
  14. Jun 22, 2021 at 11:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What a horrible sound...
    I salute the effort (and cash) to fix it and get it back on the road. :thumbsup:
    otis24[QUOTED] likes this.
  15. Jun 23, 2021 at 3:51 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I can see where if the job was quoted with all Toyota Parts at List price the amount would be rather high.
    So the mechanic might not be the con artist they sure look like.
    Also the work might be farmed out so everyone needs to make there mark up.
  16. Jun 23, 2021 at 3:58 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Check out car-part.com for local salvage yards. AIR your gear ratio can be decoded from your VIN.
  17. Jun 23, 2021 at 8:30 AM
    jbrandt
    Justin
    Mechanic said his pinion bearing was shot. So rather than quote $150 or so bearings and in seals + labor, guy quotes $3200 for an entire carrier. The TRD locker assembly is ~$2300 from Camelback, so $3200 is not all that unreasonable, IF you're dumb enough to buy a new factory OEM replacement when all you need is some bearings and seals.
    I'm just not sure where the dude gets $7k for a rebuild. That's insane.
    This is worse than the mechanics that tell you you need all new control arms because your bushings are shot. It's easier/faster to replace the entire assembly, and if the customer is paying the extra cost for the parts, that's a win-win for the shop.
    Wyoming09[QUOTED] likes this.
  18. Jun 23, 2021 at 8:38 AM
    otis24
    Mark
    California
    I got to put my emergency fund to use!
    Digiratus[QUOTED] likes this.
  19. Jul 7, 2021 at 2:13 PM
    750ml
    750ml Active Member
    A.
    2001 Tacoma
    235/85r16 Toyo Open Country AT3's, 4.88 Yukon gears, Eaton Trutrac front and rear, 2" lift
    If you are in middle TN Hudlow Axle can rebuild it. They are on the outskirts of Chattanooga, but just over the line in Rossville GA. They're great folks.
  20. Jul 7, 2021 at 2:22 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    421k? WOW.
