Tires - Passenger vs LT question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacodile, Feb 11, 2024.
  1. Feb 11, 2024 at 8:11 AM
    Tacodile
    Tacodile [OP] Member
    Pearland, Tx
    12 PreRunner SR5 Texas
    Black badging
    If someone knows of a thread that answers my questions I'd appreciate a link.
    I have a 2012 Taco with the Texas/TSS 17" Delta wheels. It came with 256/65 R17 "P" tires.
    Can I put "LT" tires on a "P" rim?
    Are "P" passenger rims metric and LT not metric?
  2. Feb 11, 2024 at 8:14 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    If your question is in fact genuine, yes. You can put LT tires on a rim that has been used for a P tire.
  3. Feb 11, 2024 at 8:15 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes, you can put LT tires on a rim that previously had P tires. If you have worries. Have the same vendor from who you purchased the tires do the installation.
  4. Feb 11, 2024 at 8:16 AM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    P is passenger rated. LT is light truck.
    P is 4 ply, vs LT 6 8 or 10 ply.
  5. Feb 11, 2024 at 9:08 AM
    Tacodile
    Pearland, Tx
    Black badging
    Thanks for the responses. I had read somewhere that the bead diameter might be different. Something like "P" passenger tires are metric and LTs aren't.
  6. Feb 11, 2024 at 9:19 AM
    Bishop84
    Bishop84 Well-Known Member
    Nope, same standards. But an LT tire will actually be physically larger, same size, by a tiny margin, but its noticeable.
    LT tires usually have 16/32nd P/SL tires will have 12/32nd new as an example.
    Plus LT tires usually have firm sidewalls, where P/SL will buldge/bow a bit.
    Biggest issue is weight, usually 10lbs-15lbs more if you go LT, and you feel it.
    Steves104x4 likes this.
  7. Feb 12, 2024 at 5:35 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    You can fit whatever tires are the correct size.
    Speed and load ratings don't matter for fitment on the rim.
    If you don't actually use your truck as a truck, i would recommend using p tires as they weigh less and get better fuel economy.
    inwood customs likes this.
  8. Feb 13, 2024 at 11:37 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    The rim doesn’t care, it’s a piece of steel/alloy.
    the rubber tho that matters.
