Tires feel "loose" when going over bumps
Discussion in '1st Gen. Tacomas (1995-2004)' started by WATSON, Jun 7, 2011.
  1. Jun 7, 2011 at 5:20 AM
    WATSON
    WATSON [OP] Member
    HAMPTON VA
    98 TACO BASE 4X4
    Just upgraded from stock 225/75/15 to 31-10.50-15 on my 98 4x4 non TRD.Wondering if the SR5 or TRD had some kind of steering dampner mine doesn't have.Doesn't seem to like the extra tire when going over bumps.
    Anyone else have this problem?
  2. Jun 7, 2011 at 6:25 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well first off 31"x10.50x15" is stock tire size for 6 lug 4x's & pre runners
    rack & pinion so no steering dampners per say. maybe your due for some new struts & check all for tightness..
  3. Jun 7, 2011 at 6:30 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    do yuo feel some chatter in the steering wheel? you might want to look into new steering rack bushings as well
  4. Jun 7, 2011 at 6:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...Go thru and check torque on all the bolts and stuff. Look for play in steering components. How much balance weight did they use on the tires?
  5. Jun 7, 2011 at 6:47 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    Are you saying the "looseness" wasnt present with your previous tires? This may sound stupid but check your lug nuts, assuming you didnt do that yet. 2nd.... and im very curious as to why there arent many more complaints / reviews / mods with this...... i know its somewhat labor intensive and time consuming but i would imagine everyone experiences this and is not happy with it....
    http://www.tacomaterritory.com/forum...g+wheel+rattle
  6. Jun 7, 2011 at 6:49 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    also jack up the front end and grab the top and bottom of your wheel and see if theres any play in it just incase your wheel bearings are going out
  7. Jun 7, 2011 at 7:17 AM
    WATSON
    WATSON [OP] Member
    HAMPTON VA
    98 TACO BASE 4X4
    No chatter or clunking sounds.Just doesn't seem to take the bumps as well.Truck has very low miles and ball joints are in good shape.Didn't really notice this until I put the 31s on it.Drives flawless on smooth highways at 80mph but certain bumpy roads at 35 mph feels like tires are shaking or bouncing for lack of better words.
  8. Jun 7, 2011 at 8:45 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    sounds like a suspension issue.. how old are you shocks?
  9. Jun 7, 2011 at 8:51 AM
    WATSON
    WATSON [OP] Member
    HAMPTON VA
    98 TACO BASE 4X4
    13 years old
  10. Jun 7, 2011 at 8:52 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    replace them and if your springs are sagging replace those too
  11. Jun 7, 2011 at 9:02 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    Yeah, I'd say your about due in that area. Tire pressure correct?
  12. Jun 7, 2011 at 9:18 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Yeah... low miles or not. They're done.
    My stock front end (03) felt loose/was down right dangerous with 100k miles on it. Went to 881's/5100's and couldn't be happier.
  13. Jun 7, 2011 at 9:25 AM
    scocar
    scocar hypotenoper
    x2. Start with new shocks, unless you think you want to lift it at all, in which case you should start doing your homework:
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
    Warning: you are about to enter a rabbit hole if you decide to replace your suspension with aftermarket stuff. It's a good rabbit hole, but be warned.:D
  14. Jun 7, 2011 at 9:40 AM
    WATSON
    WATSON [OP] Member
    HAMPTON VA
    98 TACO BASE 4X4
    I'll give it a shot.Seems like bilstein 5100 are the most popular shock.
  15. Jun 7, 2011 at 11:25 AM
    scocar
    scocar hypotenoper
    They were designed for the stock coils, so it is a good place to start. You could also just get the Bilstein HDs that came on TRDs if you aren't interested in lifting/leveling the front end (which is what 5100s do) and want to save some ducats.
  16. Jun 7, 2011 at 3:42 PM
    mx04taco
    mx04taco Well-Known Member
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    Flowmaster exhaust, Pioneer DVD HU, Pioneer speakers all around, , Viper security w/ remote start, Tinted Windows, Silverstar Headlights, Toytec 3" Coil Springs, All Pro Offroad Diff Drop 3/4", Bilstein 5100s, 2" Toytec AAL's, Toytec poly rear leaf bushings, Deckplate Mod 4", 265/75r16 firestone destination a/t's
    i have the same problem, just installed slightly larger tires on mine at 106,000 miles. After checking out all the joints to make sure alll are good and tight, and then having someone drive by me while going over a bump i determined the right front strut is making the noise. my 5100s just came in the mail today and i will be installing them tomorrow. i will let you know how it goes.
  17. Jun 8, 2011 at 1:17 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    What's the tire load range? And psi in them? On my BFg km if I run them at 35 psi it rides rough and bouncy. I have them at 27 psi, they ride alot better.
  18. Jun 9, 2011 at 11:27 AM
    WATSON
    WATSON [OP] Member
    HAMPTON VA
    98 TACO BASE 4X4
    Putting on new front strut/springs and rear shocks as well today.Will check tire pressure too.Thanks for all the advise
  19. Jun 9, 2011 at 11:47 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Let us know how it is afterwards
  20. Jun 10, 2011 at 5:38 AM
    WATSON
    WATSON [OP] Member
    HAMPTON VA
    98 TACO BASE 4X4
    Fixed.Rides much better now.Feels nice and tight when going over bumps now and feels more firm when turning.
