Tires are rubbing on upper control arm.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Timjohansson, Apr 8, 2017.
  1. Apr 8, 2017 at 6:50 PM
    Timjohansson
    Timjohansson [OP] Member
    i bought a new 2015 Tacoma. The dealership had already put a 3" lift on it and big tires and nice rims.
    I've always noticed that when I take a sharp turn the tires seem to rub... I looked at it a little closer the other day and noticed the upper control arm is very close to the wheel. Where the tire rubs, the black coating has rubbed off the uca... I took it back to the dealership and after an hour and a half they said the wheels are a little too big... I was like what? No. I paid 40k for this truck and it was sitting on the showroom floor with these wheels and you want me to take smaller ones??? I told him that was unacceptable. He said he was going to have his lift guy look at it this week.
    Any idea what they might offer? Or what I should demand?
  2. Apr 8, 2017 at 7:02 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Aftermarket upper control arms.
    Your caster(alignment) is also too low.
    Wheel spacers possibly.
    dbole007, DustStorm4x4 and Tatts521 like this.
  3. Apr 8, 2017 at 7:52 PM
    Timjohansson
    Is it possible to lift it another inch and a half so it would clear the control arm?
  4. Apr 8, 2017 at 8:00 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    And that's why you don't by the dealer special.... sorry op.
    This wouldn't help as lifting the truck might help with VERTICAL clearance but not HORIZONTAL clearance, if that makes sense. At 3"s of lift, you probably need aftermarket UCAs anyways to get your alignment back in spec. And if that doesn't work, you need different wheels with less backspacing or wheel spacers.
    406tacoS, lynyrd3 and inwood customs like this.
  5. Apr 8, 2017 at 8:01 PM
    Timjohansson
    Also, how big of a deal is this? I don't like the fact that my tires rub when I turn very sharp and the arm is very close to the wheel but if I have them "fix" this is it possible that more could go wrong?
    I just feel like I bought it New from the dealership so I should expect all these things to work perfect!
    Thanks in advance for any suggestions/comments!!!
  6. Apr 8, 2017 at 8:02 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    1. Thinner tires.
    2. Aftermarket UCAs
    3. Spacers.
    Take your pick. Those all solve that problem.
    Alexely999 likes this.
  7. Apr 9, 2017 at 7:14 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Well eventually you'll pop your tires so it's a big deal.
    You need:
    -Skinnier tires (what size are yours?) and/or
    -wheel spacers maybe 1.5" and/or
    -new wheels with the proper BS to move the tires farther away from the uca
    A.priori likes this.
  8. Jul 3, 2019 at 4:47 AM
    Big Brutus
    Big Brutus Active Member
    2010 4x4 TRD Sport
    I am curious to how this panned out. What was the solution? I have a similar problem and need some advice.
  9. Jul 3, 2019 at 4:56 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    I have a set of four Bora 0.75" spacers for sale, they would make the tires poke out 3/4" more, but are about the thinnest you can get for wheel spacers that are high quality. No matter what though, if you buy spacers get either Spidertrax or Bora. I don't trust a lot of the other cheaper ones.
  10. Jul 3, 2019 at 8:03 PM
    Big Brutus
    2010 4x4 TRD Sport
    How much do you want for the spacers shipped to 33704?
  11. Jul 3, 2019 at 8:46 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    I'm not sure how much shipping cost will be, but I'd like $125 plus shipping for the spacers. I paid $200 for them new and they have just under 3k miles on them.
  12. Jul 3, 2019 at 8:58 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I'd make them switch the wheels to ones with a little less backspacing. They could move the tires to the new wheels.
    Post some pics and we can help more.
