Tires: 16 vs 17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MaxKrax, Aug 30, 2021.
  1. Aug 30, 2021 at 12:36 PM
    MaxKrax
    MaxKrax [OP] Well-Known Member
    Kris
    Sparks, NV
    2021 Cement Tacoma TRD Sport
    RCI Skid plate RCI bed rack Roofnest RTT Baja Designs Squadron Pro yellow fog lights
    Hi, I'm fairly new here and having a hard time with the search function so please bare with me...
    I just bought my 2021 Tacoma TRD Off Road a month ago and looking at upgrading my tires to the BF Goodrich All Terrain T/A K02 265/75.
    I'm thinking about trying to keep my stock rims and going with the 16", however I see that the 17" is also very popular. I'm wondering if there is any performance difference between 16" and 17" rims while off road?
    Thanks for any insight
  2. Aug 30, 2021 at 12:37 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    16 more side wall for off-roading
  3. Aug 30, 2021 at 12:38 PM
    Bishop84
    Bishop84 Well-Known Member
    No noticeable difference, 17" is better because there is more selection and choices in size.
    If just going up one size to 265 76 R16 stick with the factory rims, they look great from the start and the bigger tires will give the truck the look it needs.
  4. Aug 30, 2021 at 12:42 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    I agree. Only advantage to 17's is more choices of rubber.
    xxTacocaTxx likes this.
  5. Aug 30, 2021 at 12:59 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can get the same overall tire diameter and width with either wheel size. The only difference is the size of the hole in the middle, and how much rubber is between the bottom of the wheel and the ground. Larger 17" wheels mean less rubber between the wheel and road assuming the same overall diameter. That will provide better handling when cornering aggressively on pavement.
    With 16" wheels you get more rubber between the wheel and ground. That means a little softer ride and a little better off road performance. But less on road performance especially when driving aggressively. But there isn't that much difference between 16 and 17" wheels.
    For what you want to do I'd stay with 16" wheels. At one time there were more 16" tire options, that may have changed, prices for 16" tires are almost always less. The 265/75/16's currently on my truck were $175 each. A 265/70/17, which is almost identical overall are $206 each.
  6. Aug 30, 2021 at 1:06 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    If you off road, go with a 16". If you're a street taco like me, go with a 17".
  7. Aug 30, 2021 at 1:14 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Stick with the 16's. No appreciable difference in performance if going with the same overall tire dia. The 16" will offer more sidewall at the same overall diameter.
    Save the money and put it towards gas, as you'll probably go through a lot more of it with those tires at 54 lbs(!) each. I noticed quite a performance drop when I put on my KO's vs some lighter truck tires. Note that these KO2's come in a D range 245/75R16 as well, which saves 8lbs per tire. It's unsprung weight, so every pound makes a big difference. Might be a consideration.
    willie2, Vlady and mquibble like this.
  8. Aug 30, 2021 at 1:20 PM
    MaxKrax
    Kris
    Sparks, NV
    Thanks for your input guys, I think I'm going for the KO2 265/75/R16. From what I've researched this is close to being one of the largest tires you can get on the Gen 3 Tacoma without having to lift or change suspension, is that correct?
    JJ Diablo and Tocamo like this.
  9. Aug 30, 2021 at 1:20 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    16 inch you’ll get an extra 1/2 of rubber between you and the ground - same overall diameter.
    17 inch more tire choices, more choices in C load tires, strong but good weight. KO2 in 265 70 17 C load for 45lbs.
    Woofer2609 likes this.
  10. Aug 30, 2021 at 1:25 PM
    MAD777
    MAD777 Well-Known Member
    White Mountains, NH
    2021 Tacoma SR5 4x4 Double Cab 6' bed
    I've decided to abandon my 16" stock for 17" wheels because I've found there's so much more variety available in both wheels and tires at 17". But I'm a road dwelling Taco.
    That being said, if you find 16" wheels and tires that you love, go for it. Nothing will suffer really.
  11. Aug 30, 2021 at 1:30 PM
    BrianPVan
    BrianPVan Well-Known Member
    Brian
    BC
    2017 DCSB OffRoad
    Stick with 16" and save the $$ of buying new rims ;-)
    JJ Diablo likes this.
  12. Aug 30, 2021 at 1:32 PM
    Crosbaugh
    Crosbaugh Well-Known Member
    As others have said, there are more options at 17 than 16. Also, you have room for a larger brake kit, if you want to go that route. I don't intend to install larger brakes and I like the look of my factory 16s, so I saved thee $1000 I'd spend on wheels.
    I went with the Falken Wildpeaks in 255/285/16 (maybe 150 miles ago) and have been happy with them on-road. I haven't had a chance to get off-road with them yet.
  13. Aug 30, 2021 at 1:36 PM
    maxus
    maxus Well-Known Member
    2017 TRD OR DCSB V6 MT
    I found a set of the factory TRD 4runner wheels & BFG tires for really cheap (< $500), and went to the 17s. Didn't really dis-like the 16s, just preferred the look of the 4runner wheels.
    BrianPVan and JJ Diablo like this.
  14. Aug 30, 2021 at 1:42 PM
    GrizzlyHair700
    GrizzlyHair700 Well-Known Member
    Dustin
    2021 TRD Sport
    Let us know how you like your BFs I was thinking about this same tire when my stock ones are junk.
  15. Aug 30, 2021 at 2:04 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Get both!
    265-75/16 rear 265-70/17 front
    TacoZmtn and Stocklocker like this.
  16. Aug 30, 2021 at 2:11 PM
    Rudimentality
    Rudimentality Well-Known Member
    Brad
    Mesa, AZ
    3rd Gen DCSB TRD Off-Road
    Stuff that costs more than my wife thinks.
    Am I missing something here? The thought of knowing that I'll have to get two tires at a time in different sizes each time seem like far more hassle than benefit.
    Care to enlighten me? Or is this pretty strictly personal preference?
  17. Aug 30, 2021 at 2:15 PM
    Lphonzy09
    Lphonzy09 Well-Known Member
    Texas
    2022 Midnight Black Metallic SR5
    If you want to save money, stick with 16”.
    eurowner and grogorat like this.
  18. Aug 30, 2021 at 2:28 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    265/75/16 Duratracs for the Win! (C Load, 6 ply.)
    The Goodyear tire, Toyota should put on the Off Road Tacos.
  19. Aug 30, 2021 at 6:30 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Nope!
    Sure! I have both sets (4 16” & 4 17”) and was swapping the 17s off to the 16s, as they weigh 8lbs lighter per wheel, for a big road trip.
    Rudimentality[QUOTED] likes this.
  20. Aug 30, 2021 at 6:34 PM
    Lphonzy09
    Texas
    i’ve come across this thought for weight savings, but did you end up weighing the tire size difference? I wonder if it is significant, given the tires are probably heavier than the wheels itself?
