Tire/Wheel Fit 2002 Tundra 2WD Access Cab V8
Discussion in 'Wheels & Tires' started by Kiwi400, Feb 21, 2021.
  1. Feb 21, 2021 at 12:28 AM
    Kiwi400
    Kiwi400 [OP] Member
    2002 Tundra
    I am new- bought my truck and joined Tacoma World because I see lots of 1st Gen Tundra talk here! I apologize if I have offended by asking a Tundra Q.
    Call me crazy but tire and wheel sizes are SUPER CONFUSING. I have researched like crazy and just to be sure thought I woulf ask the experts....
    THE QUESTION: Will these tires/wheel fit 2002 Tundra 2WD Access Cab with your 3" lift? (Plus Offset)
    I have a a Fat Bob 3” lift kit on the way:
    Toyota Tundra 3" Lift & Leveling Kit 4WD/2WD (6-Lug) 1999-2006
    3 Inch Front Spacers and 2 Inch Rear Add A Leafs
    These are the tires and wheels for sale that I want to buy:
    Set of 4 Toyo opencountry r/t. 285/70/17. The tires are on Raceline Rockcrusher 17X9 0 (offset) rims. They came off a 2015 GMC Sierra 1500. Bolt pattern 6x5.5
    To see if they would fit I did a lot of research this is the closest I could find: a link to the same year and model as my truck... with same sized tires (285/70/17) and wheels as I want to buy....(however this offset, and I do not know the backspacing, is slightly different than the tires and wheels that are for sale)
    https://www.customwheeloffset.com/w...-block-supreme-suspension-suspension-lift-3in
    These are just the wheels that come with the tires I want to buy - 17x9 - 0 offset
    https://www.customwheeloffset.com/buy-wheel-offset/887-79080/raceline-rockcrusher-17x9-0
    Help! Will the Raceline wheels and 285/70 R17 tires fit my truck after its 3" lift?
    FY FatBob says that with their lift it allows 285/70 R17 or 285/75 R16 tires w/.25" wheel spacers or aftermarket rims.
    Thanks guys!
  2. Feb 21, 2021 at 7:07 AM
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
  3. Feb 21, 2021 at 8:24 AM
    Kiwi400
    Kiwi400 [OP] Member
    2002 Tundra
    Thanks very much Stu. I did post over there and appreciate the tip.
    Kiwi
  4. Feb 21, 2021 at 8:45 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Is your Tundra 5 lug wheels or 6 lug wheels? I don't know much about the Tundras, but I thought the 2WD models had the 5 lug wheels so those 6 lug wheels wouldn't work in that situation (your lift kit might not either so you may want to double check).
  5. Feb 21, 2021 at 9:22 AM
    Kiwi400
    Kiwi400 [OP] Member
    2002 Tundra
    Thanks Jeff - 6 lug
    2002 Toyota Tundra 6 lug 5.5 inch or 139.7mm Medium Offset
  6. Feb 21, 2021 at 2:24 PM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    That link you have looks like the 5 on 5 lug wheels. Check part # 887-79060 which looks like the correct 6 on 5.5 wheels. Raceline Wheels 887-79060 Raceline Wheels Rockcrusher Polished Wheels | Summit Racing You may also want to double check the hub center bore for your truck. I think it's 106.1 mm like the Tacoma so these wheels with the 107.95 mm should work. I'm also seeing some Tundra wheel hub center bore listed as 110.1 mm so they wouldn't fit those trucks.
    Here's a link to some truck wheel information.
    Inandaudi likes this.
  7. Dec 2, 2021 at 6:29 PM
    Inandaudi
    Inandaudi Member
