Tire Valve Stem Issue, Won't Accept Air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rooblik, Nov 18, 2019.
  1. Nov 18, 2019 at 2:57 PM
    Rooblik
    Rooblik [OP] Taxation is Theft.
    Grey 2009 Tacoma DCLB SR5 V6 TRD Sport
    Hey, y'all.
    So I went to add air to my tires and 3 out of 4 went fine. The last tire just wouldn't fill. You could hear that there was no air flowing. I tried another air chuck just in case the first one was acting up, but that wasn't it. Do I need a new valve stem? This is for a 2009 TRD Sport Tacoma. Thanks.
  2. Nov 18, 2019 at 3:20 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Just change the valve core. You can buy one, and the removal/installation tool, at any auto parts store.
    Rooblik[OP] and whatstcp like this.
  3. Nov 18, 2019 at 3:21 PM
    Muddinfun
    Muddinfun Well-Known Member
    Check and see if the little stem in the valve core is bent over to the side. If it’s not, poke the stem with a key and see if air comes out.
    TnShooter and Rooblik[OP] like this.
  4. Nov 18, 2019 at 3:38 PM
    Fullboogie
    Dave
    Houston
    On the left is the tool, on the right are the cores. They are actually for our A/C system high/low ports, but the ones for your tires will look very similar.
  5. Nov 18, 2019 at 4:32 PM
    Rooblik
    I should have mentioned in my post that I depressed that stem and air will flow out of the tire. That's why I'm confused about why it won't flow into the tire. Thanks.
  6. Nov 18, 2019 at 5:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Push on the chuck harder... i have seen deep valvestems have a hard time pushing the chuck center hard enough to actually allow airflow.
  7. Nov 18, 2019 at 5:22 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    If you have metal valve caps, the cap gasket may have stuck on the inside of the valve stem and it won't let the core depress. It happened to me the other day, got a pick and removed it and put a new cap on.
  8. Nov 18, 2019 at 8:00 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    holy crap am i glad i came across this. i got a couple valves that are a pain to fill and air down because the stem is too deep. time to replace!
  9. Nov 19, 2019 at 4:36 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    If it's not the valve core, have you or someone Slimed the tire as a quick fix-a-flat job? Reason being, the slime might have dried in the stem which is preventing air from going into the tire. Unfortunately, the only fix for this is to get another tire. That stuff is messy and ruins tires.
    You might not need to replace, just back the cores out a bit. What I do is back the cores out until air starts to evacuate, then give it at least 2 complete turns back to the right. As long as the stem is flush or slightly below the top of the nipple, you should be good to go.
    -J
  10. Nov 19, 2019 at 8:07 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    hrm good to know. the tool i bought was 5$ on Amazon and came with 4 cores so, might as well replace?
  11. Nov 19, 2019 at 9:41 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    The cores are cheap enough as they are, so since you already have the parts on hand, might as well.
    -J
    ucdbiendog[QUOTED] likes this.
  12. Nov 21, 2019 at 12:11 AM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    Just be aware when you unscrew the existing they can shoot out a couple of feet if not manually restrained.
  13. Nov 21, 2019 at 8:34 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    that actually sounds like fun :rofl::rofl:
  14. Nov 21, 2019 at 9:46 AM
    Fullboogie
    Dave
    Houston
    OP, are you sure the pressure in your air compressor is greater than the pressure in your tires? Easy mistake to overlook.
  15. Nov 22, 2019 at 7:49 AM
    WOODY2
    RAMONA,CA.
    Oh it is until it's dark out and your ankle deep in mud without a flashlight. :bananadance:
    All kidding aside those little valves are one of the most overlooked, and cheapest spare piece of kit to have in your 'oh chit kit'.
  16. Nov 22, 2019 at 8:15 AM
    nd4spdbh
    SoCal
    Yup i keep a lil baggy of 25 i got for 5 bucks on ebay in my tool kit. A few have been handed out to others airing down in the sand that have lost em.
