Tire Size Question Stock 2020 SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ct4217, Nov 8, 2024.
  1. Nov 8, 2024 at 7:35 AM
    ct4217
    ct4217 [OP] New Member
    2020 Tacoma SR5
    Hello,
    I’m upgrading to 17 in rims from my stock 2020 SR5 (16in) and wondering the largest tire or best recommendation for best fit on tire size?
    I’m looking at 265/65R17?
    Those should fit without modifying my truck? Is there a better fit?
    thx!
  2. Nov 8, 2024 at 8:15 AM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Nov 8, 2024 at 11:21 AM
    ct4217
    2020 Tacoma SR5
    Could I do at 17in wheel with 0 offset / 8 inch width? I was given gentle used after market wheels and just want to be sure I can fit a 265/65/R17 w/o modifying or issues.
    I’m gonna pass the wheels along to a friend if I can’t :)
    Thanks in advance.
  4. Nov 9, 2024 at 6:39 AM
    topochico23
    topochico23 Well-Known Member
    2022 DCSB SR5 V6 4x4
    Might just have to search the forum for "265/75r17" and read through posts to see who put these on with a given wheel/offset/etc. if you can find your wheel name/style you could search by wheel and see if anyone mentions your desired tire size. Millions of Tacomas on the road so someone likely already has the setup you want, just gotta search for a while
  5. Nov 9, 2024 at 3:27 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    P265/65R17 is a stock size tire. It comes on the Sport. It will fit on stock wheels. I would not personally consider it an upgrade, but it depends on the type of tire and your use case.
