Tire Size Question - 245/75 vs 265/70
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigdaddyral, Jun 24, 2016.
  1. Jun 24, 2016 at 10:47 AM
    bigdaddyral
    bigdaddyral [OP] Member
    2014 Tacoma TRD Off Road Doublecab 4x4
    I bought a 2014 Tacoma Doublecab Off-road that had 245/75/16 BFGoodrich KO tires that needed to be replaced. I order the new KO2 version of this tire and then discovered later on the inside driver door panel that the stock size is actually 265/70/16.
    What's the difference here? Is there a logical reason the original owner would have put smaller tires on? Should I install the new tires I ordered, or return them and buy the stock size?
    Any help is greatly appreciated.
    Edit: I should mention this is my first truck, first 4x4, and I know very little about trucks beyond what my friends and other truck owners I come across have imparted. Total newbie.
  2. Jun 24, 2016 at 10:58 AM
    Pigpen
    Dan
    Northwest Montana
    Both of those tire sizes are stock sizes for the Tacoma and are basically the same diameter, but the 265 is wider. There's a tire size calculator on here so you can check if you ever need to.
  3. Jun 24, 2016 at 11:00 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Only base models and SR5's came with 245 width tires. I changed mine to 265's and couldn't be happier. The truck corners so much better.
  4. Jun 24, 2016 at 11:56 AM
    bigdaddyral
    Thanks guys. This truck clearly originally came with the 265s and the owner changed them to the 245s.
    Is there a benefit to using the 265s over the 245s, other than cornering? Are there downsides? I use the truck mostly on the highway and in town, but do occasional off roading for access to river spots and camping. Nothing extreme however.
    I don't mind the added expense of the 265s, I just want to use what's best.
  5. Jun 24, 2016 at 12:57 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    A narrower tire is a little better in the snow, but probably not noticeably so. All I can tell you is that I like driving my truck a lot more with 265s. Maybe you can find a used Tacoma on a lot with 265s and go for a "test drive".
  6. Jun 24, 2016 at 1:09 PM
    Pigpen
    Dan
    Northwest Montana
    You'll see far more performance gain wherever you want it by choosing the appropriate tread design than with such a small difference in tire size. If you had the same tire in those two sizes, you wouldn't notice any difference on or off road. Appearance is the real difference between the two.
  7. Jun 24, 2016 at 1:12 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The 245s should weigh less, and have less rolling resistance for better gas mileage.
    Clearwater Bill likes this.
  8. Jun 24, 2016 at 1:59 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I lost about 1/2 a mpg since switching to the 265s. I guess that adds up over the years, but I like the truck better with the slightly wider tire.
    tomwil[QUOTED] likes this.
  9. Jun 24, 2016 at 3:07 PM
    Pigpen
    Dan
    Northwest Montana
    I usually get about 18 mpg around town on load E 33s with a ton of weight in my truck. 265s won't affect mpg much, especially 265/ 70. Drive wisely and do your math correctly when figuring mpgs.
  10. Jun 25, 2016 at 4:15 PM
    bigdaddyral
    Thanks everyone. I appreciate all the responses. I decided to get the 265/70s figuring that using what's on the door placard will give me closest to the listed specs of MPG and towing capacity.
    As a side note, what a spectacular forum this is! I jumped in as a newbie and had a ton of helpful responses right away. Thank all of you for being class acts!
    NAAC3TACO likes this.
  11. Jun 25, 2016 at 6:23 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Mine came with 265/70/16's. Over the 9 years I've owned the truck I've used 245/75/16's once. They are the same height, but 1" narrower. I think the truck looks a lot better with the 1" wider 265/70/16's. If there were any difference in performance I couldn't tell it. In fact I've gone to 267/75/16's. They are the same width as the 265/70/16's but are 1" taller. One reason is that 265/70/16's are harder to find, limited in styles, and actually cost more than the larger 265/75/16. Same reason I bought the 245/75/16's. I couldn't find a 265/70/16 I liked. That is not a common size only used on certain Tacoma models. I'm not aware of any other manufacturer that uses it.
    Skada likes this.
