Tire size for 2012 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hanford, Mar 25, 2015.
  1. Mar 25, 2015 at 5:55 PM
    Hanford
    Hanford [OP] New Member
    New York
    SR5 4 cyl.
    I have a stock 2012 SR5 access cab with a 4 cylinder automatic.
    I want to add larger tires nothing crazy just to give it a better look. Yet have read here that putting bigger tires on will severely hinder the performance.
    That said I currently have 245/75/16's and ask how much bigger a tire I can put on before I will start noticing a diminished performance.
    I was looking at putting either a 265/70/16 or a 265/75/16
    Any comments would be greatly appreciated!
  2. Mar 25, 2015 at 6:47 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    If you can stay away from an LT tire in those sizes that will be your best bet as heavy tires are what will kill your mileage. If your are not going to be going off road get something with a highway/street tread.
  3. Mar 25, 2015 at 8:23 PM
    MagneticTaco
    MagneticTaco Well-Known Member
    Kiel
    Louisiana
    2013 DCSB Magnetic
    3" toytech lift, front spacers, AAL in the rear, 285/75r16 goodyear duratrac, blacked out emblems and taillights, pained grill
    Anything bigger than a 265 and you will have to lift the truck to fit. I have 275's on mine and had to do a 3" lift to fit
  4. Mar 26, 2015 at 6:36 PM
    Hanford
    New York
    SR5 4 cyl.
    Thank you for the feedback.
    Hartford: I am curious if you mean putting on a MT style tire will diminish MPG or acceleration performance?
    I like the look of the MT and in a 265/70/16 with a 2" larger diameter than my current 245/75's will have a great look! just don't want to kill my performance.
    Magnetic Taco: With 2" more you think I will still be okay with the 265's in my stock truck?
    In the end just looking for a good look for the truck thanks.
  5. Mar 26, 2015 at 7:04 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    :DYou will prob be ok with the 265's. Will have to take the front mud flaps off though. And if you rub a little at full turn might need a bit of trimming but nothing major. I would just do the lift and go with some 33's
  6. Mar 26, 2015 at 7:26 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Stick with a P rated tire and a less aggressive tread pattern to save your MPG.
    If it was me, I would stick with a 265/70/16 (30.6"). I would worry about to much tire for your engine and transmission. The 4cyl+auto is a little down on power.
    I recommend michelin ms2 or Hankook dynapro rf10 or cooper at3. Ms2 is the best highway, the other two are AT.
  7. Mar 26, 2015 at 7:44 PM
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    If you run bigger than 265/70 (example 285/75r16 which is common) you will have to re-gear to get back into the power band of the engine. In my 92 (22re) 4cyl engine I had to run 4.88's to run 35"s, 4.56's for the 33"s. I would imagine it is much the same with the tacomas. Not that it can't be done without a re-gear, it is just really hard on the tranny and engine without it.
  8. Mar 26, 2015 at 8:29 PM
    Pigpen
    Northwest Montana
    I had 265/75/16 while stock with zero problems, even lock to lock at full stuff
  9. Mar 30, 2015 at 6:57 PM
    Hanford
    New York
    SR5 4 cyl.
    Thank you for the feed back. I am willing to lose some MPG yet do worry about getting too much tire for the truck which would just slow my acceleration down.
    I like the look of an off road tire and being in the southtowns of Buffalo NY I like to have some bite from my tires in the winter months.
    I currently have some worn Dunlop Grandtrek AT20's and was looking at the 265/70/16 BF goodrich All-Terrain T/A KO2
    In the end being a 4 cyl. auto I wonder if anyone has put the next size on and regretted it.
  10. Mar 30, 2015 at 7:22 PM
    2012SilverSport
    Guam
    Well you wont know until you try. I would say go for what you want and expect that at some point you will have to re-gear. The KO2's are supposed to be a smooth running tire and shouldn't zapp all of your HP, You WILL lose some acceleration but again as long as you expect it no big deal....If you don't have to swap out your gears and you are fine with your power delivery then you came out ahead. If you do end up having to then no biggie you were already expecting to.
