Tire Size experts (here you go again)! 265/60/18
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CConley, Sep 1, 2014.
  1. Sep 1, 2014 at 10:49 AM
    CConley
    CConley [OP] Member
    New York
    Leveled with 5100s
    Ordered 5100's and 1" block: plan on 1.75 on the 5100's. will one of these fit without cutting?
    Current tire is 265/60R18 or 30.5 and 7.5 inch wide wheel
    Size Rim width Tire width
    LT265/70R18 or 32.64. 7 - 9. 10.7
    Or
    LT275/65R187.5 or 32.09 7.5 - 9.5. 11.1
    Any advice will help
  2. Sep 1, 2014 at 10:56 AM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Another popular size is the 265/65/18.
    These will for sure fit with your lift.
    I would expect the 275's to fit but I could see some rubbing at full lock.
    Stick with the 265/65's
  3. Sep 15, 2014 at 7:15 PM
    CConley
    CConley [OP] Member
    New York
    Leveled with 5100s
    Went 265/65r18. Very happy, thank you for the advice!
  4. Sep 15, 2014 at 7:17 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Looks great! Now get those wheels plastidipped up in gunmetal ;)
  5. Sep 15, 2014 at 7:21 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I know I'm in the minority but I like the wheels. Sure would like to find a set...
  6. Nov 12, 2024 at 7:09 PM
    John1234
    John1234 Member
    Will those 265/50r18s fit on a stock second gen no lift?
  7. Nov 13, 2024 at 4:16 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    275-70-18
    1” block in the rear and 2.5” at 5100. No rubbing.
    09 Redneck likes this.
  8. Nov 13, 2024 at 3:17 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Plug in some sizes here to get a visual of what they will look like. Put in the size you currently have and compare it to various other sizes. You'll get the numbers on actual tire sizes and how they affect your speedometer There is a link to determine how much it changes your axle ratio as well.
  9. Nov 13, 2024 at 4:14 PM
    TacoTuesday1
    FL
    35’s minimum
