Tire Rotation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shades_Of_Red, Dec 15, 2022.
  1. Dec 15, 2022 at 5:58 AM
    Shades_Of_Red
    Shades_Of_Red [OP] Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    I was looking for some input for those of you who rotate your own tires, what type of pattern do you use? Im on my 3rd set of tires, each of a different brand and model, and each set have gotten loud after getting a little wear on them, usually around 10,000 miles. I always have my tire rotated along with oil changes every 5000 miles at the dealer. Im not sure what type of rotation pattern there using but Im wondering if its the incorrect one. My tacoma owners manual shows a front to back/ back to front pattern with no crisscrossing. Some diagrams and people show a crisscross pattern to follow with a 4wd vehicle but the owners manual shows something else.
  2. Dec 15, 2022 at 6:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    Are you using tires with big lugs like an aggressive looking A/T or maybe M/T ?
  3. Dec 15, 2022 at 6:04 AM
    23TacoSR
    23TacoSR Well-Known Member
    Front to back unless you add the spare to the mix.
    ToyoTaco25 likes this.
  4. Dec 15, 2022 at 6:07 AM
    Bishop84
    Bishop84 Well-Known Member
    Edit : non-directional tires benefit to cross rotations. Dealers typically don’t cross to prevent issues, cross rotations can result in noise and harshness.
    Typically you cross the front tires to rear and move rear straight to front. This prevents any harshness till the operator.
    I do full cross on trucks when I can, most truck tires feather on the edge and get noisy over time. Reversing the rotation combats this.
    rnish, na8rboy, blu92in99 and 2 others like this.
  5. Dec 15, 2022 at 6:09 AM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Which tires are you using
  6. Dec 15, 2022 at 6:19 AM
    Tacospike
    Two Trucks
    I do front to back / back to front, driver / passenger sides stay on the same side
  7. Dec 15, 2022 at 6:21 AM
    TailHook
    TailHook Oh, what shall we do with a drunken sailor?
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Every 5K on all my vehicles...
    Lift DS, swap front to rear, lift PS, swap front to rear, lift rear, swap sides...EZPZ
    cammerv8 and SR-71A like this.
  8. Dec 15, 2022 at 8:32 AM
    54_96
    54_96 Well-Known Member
    On 4x4 truck I go rear straight to front. Then, front X to rear if they're non-directional.
    No2psi, hwntaco20, mic_sierra and 2 others like this.
  9. Dec 15, 2022 at 12:50 PM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    My Wildpeaks started getting noisy after about 30K of FT/BK rotation. Switched to the cross the front to the rear and move rears straight forward. After a few thousand miles, the noise became less. I rotate like this every time now.
  10. Dec 15, 2022 at 1:02 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Rearward cross 5 wheel rotation for me. Never noticed increased noise with wear
  11. Dec 15, 2022 at 1:26 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Spot on.
  12. Dec 15, 2022 at 1:44 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I stopped cross rotating my tires, and spare tire many years ago. I always rotate mine front to back, but I’ve failed to initialized the tire pressure warning system after tire rotation.
    I’m so bad, no issues though
  13. Dec 15, 2022 at 3:08 PM
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    The tires Ive had are all all-terrain. Nothing aggressive like mud terrains
    - Cooper AT3s
    - Falken Wildpeaks
    - Hankook AT2s
  14. Dec 15, 2022 at 3:50 PM
    na8rboy
    WI
    I would do cross rotation. Rear to front, cross fronts to back.
  15. Dec 15, 2022 at 4:19 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Parking brake. Lift front from center cross member under engine add jacks. carefully lift rear from rear axle. add jacks to the axle. Rear tires forward Front tires crossed. Lower torque to 75-85 ft/lbs
  16. Dec 15, 2022 at 4:27 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    All tires get louder with wear. The design is optimized for a new tire and no tire wears perfectly. I've had lots of sets of tires.
  17. Dec 15, 2022 at 4:29 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    This is your best bet on a truck and regardless of what type of tire.
    54_96[QUOTED] likes this.
  18. Dec 1, 2024 at 6:10 PM
    23taco23
    23taco23 New Member
    23 black Tacoma TRD
    Bone stock
    per the manual the tire lug nuts are to be torqued to 83 ft/lbs no more or risk tearing the bolt
    satcom221 likes this.
  19. Dec 2, 2024 at 3:05 AM
    auskip07
    Skip
    Atlanta, Ga
    Your bolts don't tear. I doubt the safety limit is 83 on the dot. 75-85 is well within that limit
  20. Dec 2, 2024 at 5:25 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    In the old, old days you would cross. Then steel belted radial tires came a long and it was thought to be bad to switch sides. People thought it was bad for the tires and that belts would 'shift'. This was funny because there really is nowhere for a belt to go. A tire is solid construction. In any case in modern times the modified X pattern has gained popularity. This put your tires at all 4 corners over the rotations. Theoretically creating the most even wear.
    The reason people recommend against putting the tires on the other side (aside from the old belt 'shift' nonsense) is that they are rolling in the opposite direction. This is why you shouldn't cross directional tires. The only real drawback to this is that you can get additional road noise if the tires have a wear pattern. Also worth noting is that if you have a wear pattern, you won't fix it by moving positions. A worn tire will continue to wear.
    *** This is a 2 year old thread probably revived by a bot ***
