Tire/rim ideas for my 2003
Discussion in '1st Gen. Tacomas (1995-2004)' started by Notcris, Nov 4, 2019.
  1. Nov 4, 2019 at 1:10 PM
    Notcris
    Notcris [OP] Well-Known Member
    Cristian
    Georgia
    2021 4runner Lunar Rock Trd Pro 2004 Xtra xab red
    None
    Can y’all give me some ideas for wheels/ tires? For my 2003 Tacoma. I’ve been thinking about going with the trd pro wheels and ko2 tires. Please include pictures so I can see your rigs. Thanks!
    tacomainthesun likes this.
  2. Nov 4, 2019 at 2:14 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I have an 03 that looks much like yours. I'm keeping mine stock, and spending my money on parts that need replaced. How many miles does yours have. I just replaced my lower ball joints, since there were leaking grease, and installed new inner and outer tie rods. As many here on TW have stated, the lower ball joints can fail without notice and cause some serious damage. I'm looking to replace the steering rack bushings, shocks, upper ball joints(next spring). But regardless which route you go good luck with your search for better looking rims and tires. I'm currently running Hankook Dynapro, second set and really like them. They have nice manners in all weather, and do okay for mild off road.
  3. Nov 4, 2019 at 2:27 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    3rd Gen offroad wheels would look really good IMHO
  4. Nov 4, 2019 at 2:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That thing is a limo; it's a limited double cab which is the perfect little pavement princess if you keep it on road.
    Otherwise, there are a ton of threads with 1st gens on aftermarket wheels.
    Fyi if you're at 140k miles on original lbj, replace them.
  5. Nov 4, 2019 at 2:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Difference in offset cause 3rd gen wheels to sit inward a bit.
  6. Nov 4, 2019 at 2:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The wheels themselves are sharp; definitely a modern wheel.
    On your truck though? They would clash; that's just my personal opinion though.
    Your vehicle is monochromatic, and contrasting wheels will stick out like a sore thumb.
    Aggressive tires on your stock wheels though? That'd look good.
  7. Nov 4, 2019 at 7:17 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Stock wheels and tires from my 2018 TRD OR
    chrslefty likes this.
  8. Nov 4, 2019 at 7:26 PM
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    These are 265/75r16 Goodyear Wrangler authoritys on stock wheels on my truck it is lifted ~2.5" in front and 1.5 in back though. I kinda like the stock wheels if anything I am tempted to put 1.25" spacers on it or maybe try plastidipping (in case I don't like it) a graphite color or black
  9. Nov 4, 2019 at 9:02 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I'm not trying to be rude but it will come off this way.
    There are literally hundreds of posts with wheels and tires. You can use the search function on the upper right and you will get a plethora of wheel/tire setups with pictures.
    If you want a "specific" one do a search on that or add that to your title :)
  10. Nov 4, 2019 at 9:43 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    rogerman, Area51Runner and Norton like this.
  11. Nov 5, 2019 at 10:35 AM
    tacomainthesun
    tacomainthesun Well-Known Member
    02(sold) 17 trd or
    Nice truck. Keep stock wheels but paint them. Tires are what really matter. If you have disposable income get fuels
    Notcris[QUOTED][OP] likes this.
  12. Nov 5, 2019 at 6:54 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    16” steel wheels
  13. Nov 5, 2019 at 8:02 PM
    CoreysIRTaco
    CoreysIRTaco Well-Known Member
    Corey
    2004 Tacoma DC TRD
    None
  14. Nov 6, 2019 at 11:26 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  15. Nov 6, 2019 at 11:35 AM
    CrustyTaco
    Todd
    Louisville, KY
    What tires are those?
  16. Nov 6, 2019 at 11:41 AM
    CrustyTaco
    Todd
    Louisville, KY
    These are the current wheels I have installed. 17" wheels from the 1st gen Tundra/Sequoia.
    Hamer95USA, frizzman and Area51Runner like this.
  17. Nov 6, 2019 at 11:44 AM
    Area51Runner
    Cooper Discoverer ST Maxx 255/85/16
    Excellent tire, couldn't be happier with them. Highly recommend.
    Hamer95USA likes this.
  18. Nov 6, 2019 at 11:51 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I like those rims!!!
  19. Nov 6, 2019 at 1:04 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @Notcris , I fully understand why you want to change the wheels. I have the same clam shell wheels on mine, and most defintely are lacking in the "Cool" look. But for me, I'm a cheap tightwad, they do what there supposed to do, hold the tire on, but I agree that better looking wheels will make the truck look better. I like what post #4 stated, pavement princess is pretty much what my truck is now that I don't really do any off roading anymore. Or as some friends I used to work with called it a "grocery getter", since they all drove full size Fords, Dodge 1500, and Chevys. I challenged them to a follow me through the woods once, but none would take me up on it. Like I told them, my little ole Tacoma will go places your full size truck can only dream of going. Good luck with your decision, and please post some pics when you get the new wheels, and tires on. If your not looking for a super duty off road tire, look at the hankook dynapro. I'm on my second set and really like them.
    Notcris[OP] likes this.
  20. Nov 6, 2019 at 2:14 PM
    Nate0303
    Nate0303 Well-Known Member
    Nathan
    03 Tacoma TRD
    3in lift on 285/75r16 toyo MTS, cbi Moab front bumper, headache rack, nfab Nerf bars, LED lights, double din head unit, kicker hideaway dub
