Tire PSI sensor battery replacement, DIY? Or Dealer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whttaco2whl, Sep 11, 2017.
  1. Sep 11, 2017 at 7:25 AM
    whttaco2whl
    whttaco2whl [OP] Well-Known Member
    KC
    North of LA
    2009 Tacoma base model, 2Whl 5Lug
    None
    After the replies on my previous thread wandered off somewhere, I put the most likely source of the warning in my 2009 without a spare tire sensor on the 4 sensor batteries. Those must be very small, and after +/- 8 years (not counting shelf time), not hard to imagine them getting weak. I wonder if there is a way to check'em.....
    Has anyone gone through the process of having them replaced? Curious what the job requires. Do the tires need to be dismounted? If so, too bad I didn't know about it a few months ago at the new tires recently put on.
    Gotta love technology,.... And just waiting for this Artificial Intellegence to start coming on strongER, it's in the news and scary!
  2. Sep 11, 2017 at 7:31 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    turn off TPMS and enjoy
    Or spend the money on new TMPS sensors and get it programmed which requires tire removal
    ebay has new ones for 80-160 a set
  3. Sep 11, 2017 at 7:37 AM
    whttaco2whl
    KC
    North of LA
    None
  4. Sep 11, 2017 at 7:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    You cannot replace the batteries. You have to replace the sensors. Here is what the inside looks like.
  5. Sep 11, 2017 at 7:51 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Batteries are not replaceable. Any shop should have the capabilities to scan each sensor to see if it's dead or alive. Do it all the time
  6. Sep 11, 2017 at 7:53 AM
    TacoAC
    TacoAC Well-Known Member
    Cali
    DCSB In Progress
    Saved myself some money and decided to put up with the light on the dash lol.
    Bebop likes this.
  7. Sep 11, 2017 at 8:03 AM
    Bebop
    Nick
    Never understood the sensors for everything. Just something else to break and cost money. I can buy 40 of those pen gauges for the cost of 1 sensor. Or I'll just buy 1 good digital gauge to read my tires. They way people are today amazes me. What did people do to check their tire pressure before sensors?
    azreb likes this.
  8. Sep 11, 2017 at 8:32 AM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    I saved a buncha money by.... just dealing with the light in the dash. I have the TPMS sensors from my stock wheels and maybe eventually build the pipe to contain them but I'm not that worried about it.
  9. Sep 11, 2017 at 8:55 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Toyota's TPMS OEM sensor's have a life span of anywhere from 8-10 yrs. After that well the dreaded tpms light symbol on your dash will just be there, staring at you, annoying your ass.
    So either just deal with it or do something about it by (1) just strongly ignoring it?......... (2) just cover it up?........(3) just disconnect it?......or.....(4) replace all four sensor's (five if your spare has one) and as someone else has already mentioned, have the new ones reprogrammed, etc., the cost? .....well not cheap either $.
    Forget about going cheap and trying to replace the batteries on them because that won't work either and even "if" you were to replace the batteries on them, the system would "still" need to be reprogrammed so basically.......your screwed.
  10. Sep 11, 2017 at 10:58 AM
    uwu
    uwu Well-Known Member
    a small piece of tape will cover that light forever!
    coma toy likes this.
  11. Sep 11, 2017 at 11:55 AM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    I think they waited until it ran flat then bought a new car...
  12. Sep 11, 2017 at 12:02 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it has nothing to do with you or me, but the largest number of vehicle owners are idiots
    and Ford spec crap tires at 28psi, and people died from tire failures because...they never check tire pressure
    or do a vehicle walk around every time they drive...so they murdered the tires from constant low pressure
    until they rip apart and ....crash at speed
    it is a Federal mandate that all cars and truck must have TPMS when sold. if vehicle doesn't
    have TPMS then TPMS must be retrofitted.
    SR-71A likes this.
  13. Sep 11, 2017 at 12:34 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I believe you forgot the part about 2007 and up are required by federal law. There's no way I'm putting a tpms system in my 83 Toyota to sell it.
  14. Sep 11, 2017 at 12:37 PM
    Bebop
    Nick
    If somebody died from not checking their tire pressure then that's just natural selection. It's only a 30k dollar piece of machinery your still making payments on. Why would you want to take care of it? I say remove all warning labels and safety devices from everything and let's just let the idiots off themselves. Imagine the lanes opening up on the highway at rush hour.
    SR-71A and Avsfreak18 like this.
  15. Sep 11, 2017 at 1:03 PM
    Bebop
    Nick
    Just pulled this broken sensor out of a Porsche Panamera. (Ugliest "supercar" on the planet)
    Pabloeeto and Jere like this.
  16. Sep 11, 2017 at 1:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    I like the look of that car. One of the few Porsches that doesn't look like a beetle.
  17. Sep 11, 2017 at 1:36 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    it's not DIY unless you can remove the tire and remount yourself.
    my local toyota changes $175 for an OEM replacement and labor
  18. Sep 11, 2017 at 4:50 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    The issue with Ford and Firestone tires, mainly on the Explorer, is much more complicated than the owner not checking the tire pressure. Ford specified 26 psi originally, which was too low, causing extreme overheating of the tire and lots of tire failures at high speeds, and many deaths. There were also problems on the Firestone side in the manufacturing process. Read all about it here: https://en.m.wikipedia.org/wiki/Firestone_and_Ford_tire_controversy
    I personally prefer no sensors, but other than folks here at TW and other "enthusiast" sites/clubs, most drivers don't have a clue. And, thanks to computer technology, there is no end in sight as far as nanny sensor/devices are concerned. You can't argue the potential safety aspects of V2V and V2I technology, but it also creates a lot of debate also. A little fun reading...
    https://www.wired.com/insights/2014/09/connected-cars/
    https://youtu.be/ZHMfQrYydtE
  19. Sep 11, 2017 at 6:42 PM
    JoefromPTC
    Joe
    For my second TMI post of the day...
    The first passenger vehicle to adopt TPM was the Porsche 959 in 1986, using a hollow spoke wheel system developed by PSK.
    In the United States, TPM was introduced by General Motors for the 1991 model year for the Corvette in conjunction with Goodyear run-flat tires. The system used sensors in the wheels and a driver display which can show tire pressure at any wheel, plus warnings for both high and low pressure. It has been standard on Corvettes ever since.
    FYI - According to the statistics, for every 10% of under-inflation on each tire on a vehicle, a 1% reduction in fuel economy will occur. In the United States alone, the Department of Transportation estimates that under inflated tires waste 2 billion US gallons of fuel each year.
    and... Under-inflated tires lead to tread separation and tire failure, resulting in 40,000 accidents, 33,000 injuries and over 650 deaths per year. Further, tires properly inflated add greater stability, handling and braking efficiencies and provide greater safety for the driver, the vehicle, the loads and others on the road.
  20. Sep 12, 2017 at 6:09 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    That interior tho...
