Tire Pressure for General Grabber HTS 60 245/75r16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PreRunnerJess, Apr 9, 2020.
  1. Apr 9, 2020 at 12:35 PM
    PreRunnerJess
    PreRunnerJess [OP] Member
    Jess
    '14 Red Tacoma 4 door PreRunner
    Exhaust, aftermarket stereo system
    Just wondering what tire pressure everyone uses for their tires. I have stock rims and the tires are Grabber HTS 60. 245/75r16. The tire psi max says 44 but ive been reading everyone is putting theirs at 30-35 Psi for stock tires. I don't go off roading, mainly city driving. Thanks in advance.
  2. Apr 9, 2020 at 2:40 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  3. Apr 9, 2020 at 2:48 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The numbers on the door jamb are suggested for best ride. That will be 29-32 PSI IIRC. The number on the tire (44PSI) is recommended if you're hauling near max loads in your truck or towing heavy.
    I always ran closer to 35-38 PSI most of the time. The ride is a little firm, but I hauled some weight quite often and if I'd kept them at 30-32 PSI I would have needed to remember to air up every time I needed to haul some weight and let it out later. I just found it easier to keep the PSI a little closer to max all the time. I'll get 1-2 MPG better fuel mileage at 38 PSI than 32 PSI.
  4. Apr 9, 2020 at 2:50 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    30 PSI cold, look in the door jam
  5. Apr 9, 2020 at 5:33 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I have the same sized tires in a Michelin Defender. I run 35 in the front and 32 in the back unless I'm hauling something heavy. Then, I'll air the rears up a little.
  6. Apr 10, 2020 at 5:50 AM
    PreRunnerJess
    Jess
    Awesome thanks everyone for your answers. I really appreciate it. I think I'll start around 35 and see how that goes.
  7. Apr 10, 2020 at 9:20 AM
    winkel
    Corydon, IN
    I think that's a good compromise. Any more and it'll ride like a lumber wagon. Much less and, in my opinion, you'll wear them out faster and give up a little in mpgs.
  8. Apr 10, 2020 at 6:04 PM
    PreRunnerJess
    Jess
    Ya I feel the same way.
  9. Apr 10, 2020 at 6:06 PM
    Bishop84
    Bishop84 Well-Known Member
    I'd run 30 cold weather, 35 warm.
  10. Apr 10, 2020 at 6:12 PM
    PreRunnerJess
    Jess
    Ya, I am going to start at 35 right now. I was running it 28-30 and it wasn't doing to good. It also pulls pretty hard to the right when I have it lower psi.
  11. Apr 10, 2020 at 6:50 PM
    BillsSR5
    bill
    2014 SR5
