Tire pressure for 265/70/17
Discussion in 'Wheels & Tires' started by Nashwaak1, Oct 14, 2016.
  1. Oct 14, 2016 at 10:32 AM
    Nashwaak1
    Nashwaak1 [OP] Well-Known Member
    NB, Canada
    2011 Tacoma TRD Sport
    Bilstien 5100 at 1.75, WeatherTech Floormats, AVS vent visors
    Recently purchased BFG KO2 tires size 265/70/17 for me DCLB and was wondering what tire pressure others members with the same tire are using?
    The recommended pressure for the original tire size 265/65/17 was 29 psi.
  2. Oct 14, 2016 at 1:35 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    I have the same tires on a SB and I found 38 front and 36 rear gave me the best ride. 29 psi is for the P rated stockers. After 20k miles they still have 12/32nds and are wearing evenly. Rotate every 5k, same as oil change.
  3. Oct 14, 2016 at 5:33 PM
    Nashwaak1
    NB, Canada
    Are your tires E rated or C
  4. Oct 14, 2016 at 5:49 PM
    3coma
    rob
    C rated
    Nashwaak1[QUOTED][OP] likes this.
  5. Oct 14, 2016 at 5:51 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Try 34, then 36 or 32 and find your sweet spot. Don't want to go too soft on LT tires. The 29psi is for the stock P rated rubber, which needs less air.
  6. Oct 14, 2016 at 5:58 PM
    Nashwaak1
    NB, Canada
    Thanks for the help. I pumped them up to 38 psi this evening and going to give that a try. I'm mostly do pavement driving with a little off roading this time of year on logging roads.
  7. Nov 2, 2016 at 3:51 PM
    KVJ
    KVJ Active Member
    Kenny
    Bristolville,Ohio
    2015 TRD sport
    Raptor style grill
    I just had a set put on my 2015 TRD Sport access cab. The tire dealer set them at 29. I upped them to 35 today before I found this thread. I'm glad to have your input.
    KVJ
  8. Dec 1, 2016 at 12:26 PM
    Baron107
    Baron107 Member
    Dee
    2011 Tacoma 4Door.,4 W.D.,Long bed TRD
    None
    Sir, I cant answer your question, but was hoping you could answer 1 for me ... I have a {all stock}2011 Tacoma, 4D.,4Wd that came with 265/65/r17 and thinking about going to 265/70/r17 like you did. Did you have any rubbing problems ? Did this change add any ground clearance ? Thank you.
  9. Dec 2, 2016 at 3:23 AM
    KVJ
    KVJ Active Member
    Kenny
    Bristolville,Ohio
    2015 TRD sport
    Raptor style grill
    I had none at all. I can turn the wheels to the extreme and no rub. I lifted the truck about a half inch, actually made it look better.
    KVJ
  10. Dec 3, 2016 at 10:46 AM
    tkn
    tkn Well-Known Member
    Seattle
    2014 Tacoma TRD Sport 6spd
    Full Icon Stage 4 Lift w/ OME Dakar rear spring
    I run around 32 and its seems to work fine for me
  11. Dec 3, 2016 at 11:54 AM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    I run close to 50 in my e rated 265/75/16 ko2s. obviously c rated needs much less than that.
    Mike likes Tacos likes this.
  12. Dec 3, 2016 at 11:59 AM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    That's too much. I went 38 front and 36 rear. for my old 265s and now on my 285s. The dealer put 50 in mine one time and I knew it right when I drove a block down the street. crappy ride.
  13. Dec 3, 2016 at 12:04 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    I actually prefer the ride with more air. Dealer put 35 in mine and the rolling resistence was horrible. I gained 2 mpg after I went up to 45. You're talking about 10-ply right?
  14. Dec 3, 2016 at 12:06 PM
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    Yeah 10 ply. I'm all for a smoother ride over a couple mpgs. 50 just seems like a lot though. Id be interested to see a chalk test on that.
  15. Dec 3, 2016 at 12:26 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    Did you do any at various psi? Felt to me like the outsides would wear at 35. Mine don't have 1000 miles on them so I can't tell if the center is wearing more, but even if it is I prefer the ride and mileage with more pressure.
    I'm in a 16 too with a quirky transmission that is geared way too tall. With bigger heavier tires that 10psi makes a night and day difference.
  16. Dec 3, 2016 at 1:59 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    50psi in e-rated tires on a Tacoma lol I wouldn't make it around the block in that back breaker :bananadead:
    I see your tires balding in the center from here :laugh:
  17. Dec 3, 2016 at 2:02 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    I might try 60psi next and see how I like that :D
  18. Dec 3, 2016 at 2:04 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    50 psi will ride better in E rated than it would in C or P rated. The heavier the tire, the more air they need. I've driven with 50 before on 10 ply ms2's (after removing my slide-in camper and before airing back down) and they didn't ride that horrible. Noticeably firmer but I survived it just fine.
  19. Dec 3, 2016 at 3:16 PM
    Justinlhc
    E-rated tires in general on a mid-sized truck is a bit much on top of the 50psi was my point. Some people feel they need the super crazy heavy tire and yes, some people actually do.
    My work truck calls for 59psi but it rides like a roller skate at that setting and I can barely drive up a .09% grade if there is a light dust on the hill with my concrete tires lol
  20. Dec 3, 2016 at 3:21 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    I run 34 psi front and rear on my E rated KO2's. I really need to get a compressor so I can play around with it. For now it works and the ride is good.
