Tire pressure @ 40psi from dealer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thighmaster, Apr 21, 2012.
  1. Apr 21, 2012 at 12:00 PM
    Thighmaster
    Thighmaster [OP] Well-Known Member
    Ward, Colorado
    2012 Red TRD Off-Road
    June 2016 OME Dakars + 3" ToyTec Boss Lift
    My manual says tire pressures should be 29 psi front, 32 rear... why did the dealership put 40 psi in all four?
  2. Apr 21, 2012 at 12:15 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Cuz they're tards.
  3. Apr 21, 2012 at 12:16 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    Cuz they're tards.
  4. Apr 21, 2012 at 12:18 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Jinks! Lulz
  5. Apr 21, 2012 at 12:21 PM
    BMOC
    Paden
    Phoenix, AZ
    :D
  6. Apr 21, 2012 at 12:22 PM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    i see your from colorado... so based on my experiences with the low-pressure warning light going on and off all winter due to the cold temps, i bet they just over-pressured them.
  7. Apr 21, 2012 at 12:23 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    I run 34 in my mich. ltx's
  8. Apr 21, 2012 at 12:23 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    I run 40psi. 29/32 might be nice for the ride, but 40 gets me better mpgs.
  9. Apr 21, 2012 at 12:28 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    chris 4x4 says 34/32 is best.
    idk why you would have 29 in the front more weigh at all times unless you are towing or hauling. but idk anyone that towns hauls EVERY WHERE they go.
  10. Apr 21, 2012 at 12:36 PM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    The factory recommendation is based on a compromise between ride comfort, gas mileage, and handling. I suspect that 29 in front is all about cush. Way too low in my opinion.
  11. Apr 21, 2012 at 6:46 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Never had it happen and I've been running at or near the sidewall inflation levels for 20 years.
    If sidewall max is under 50psi, I run sidewall max.
  12. Apr 21, 2012 at 7:01 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Couldn't tell you on the Taco because I jacked them up on the way home from the dealer, but I average 24.5 to 26.5, rolling from Chino to Burbank 5am and 3:30pm.
    But I got 60k out of a set of 40k cheapies in my '91 Escort, and at 35k on my '06 Duramax 4x4 my BFG K/O's had less than 1/16th compared to the new tire that I got when one got punctured.
    Also, wet traction. People mistakenly believe that a "hard" tire has poor wet traction. The opposite is true. Navy tests show that pressure is directly proportional to the speed at which hydroplaning happens.
    At 28psi that speed is a little below 60mph. At 35psi that moves up to closer to 70.
  13. Apr 21, 2012 at 7:07 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    In the "old days" the dealerships would run lower psi to allow for a smoother ride when you went for that all important test drive.
    Smoother ride = greater sales.
  14. Apr 21, 2012 at 7:35 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And like Jiffy Lube pushing 3,000 mile oil changes, the tire manufacturers and dealers like it because it pads tire sales even though it is just like the 3000 mile oil change... it's a waste of natural resources.
    But the difference is that, other than the waste of resources and money, there is no down-side to 3000 mile oil changes, but there are a number of down-sides to running lower inflation levels from both an economic and safety standpoint.
  15. Apr 21, 2012 at 8:40 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) How accurate is your tire gauge ? Were the tires cold when you measured the air pressure ? If it a quality gauge, then reduce your tire pressure to the stock settings and reset your TPMS.
    Running at a higher pressure will cause the center tread to wear excessively.
    It is your truck and you can run what you want to run. My tires were not equal or at the correct air pressure also. Two of my tires were higher by 4 Pds. and two were low by 2 Pds. Things happen.
  16. Apr 21, 2012 at 11:07 PM
    Lonewolf
    Lonewolf Well-Known Member
    So. Cal
    08 4x4 TRD Sport CC, LB
    King Racing reservoir shocks, Camburg UCA's, Deaver 10 leaf pack, Bilstein 5100's, Magnaflow exhaust.
    I run 40 all the way around on BFG All Terrains.
    Got 35K on the odometer plus 15K towed behind my Class A Motor Home.
    Total of 50K still have plenty of tread, no uneven wear, the trick is 5K rotation.
  17. Apr 22, 2012 at 1:36 AM
    Thighmaster
    Ward, Colorado
    Measurements were taken cold with an above average gauge that is within one PSI of two other gauges. I consider it
    an accurate enough gauge.
  18. Apr 22, 2012 at 1:50 AM
    YikoHama
    YikoHama I Do Not G.A.S.
    Mad Cow State
    2012 Tcaoma Ascecs Cab
    After I bought my truck, I checked and they were 28/28. I usually keep 2+/1+ over recommended PSI. Nice to know that they like to recommend this and that for the longevity of your truck, but they never bother to to do their own QC.
  19. Apr 22, 2012 at 3:10 AM
    Joe D
    Joe D .
    Are you talking about a new delivery or was it at the dealer for service?
    When I worked at a Toyota dealership (years ago) the tires where all pumped up during the delivery process. Part of the pre delivery inspection (PDI) we to adjust the pressure spec. Maybe they still do it and maybe your inpsection wasn't done.
  20. Apr 22, 2012 at 10:04 AM
    Thighmaster
    Ward, Colorado
    ^ ^ It was a new delivery.
