Tire Pressure 265 70 16
Discussion in 'Wheels & Tires' started by danteisme, Feb 11, 2013.
  1. Feb 11, 2013 at 10:13 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    I found this out too late in the life of my tires, but i'll apply this knowledge towards the next set. stock psi setting on my standard cab 4x4 says 29 psi in the doors for the 245 75 16's. i've upgraded to p series hankook dynapros 265 70 16. the tire shop inflated them to 35 psi. i tried that for a while and they were wearing quickly right down the middle. so therefore they were over inflated. i dropped it back down to the stock psi between 29 and 30. still wearing over inflated. i found the sweet spot of even wear at 26-27 psi front 25-26 psi rear. with the tire pressures this low, the truck seems to wander a bit while driving down the road. aired up higher, the truck drove straight and felt solid. so....do i keep the tires aired up higher and wear them down faster, or do i keep them how i have it and get longer life from the tires but have that "wandering" feeling while driving down the road?
  2. Feb 11, 2013 at 10:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What model do you have? 4 cylinder, AC/DC, etc? For a V6, 4wd, 26-27 psi is too low in my opinion but each vehicle and tire is different. I'd keep them between 28 and 30 psi so it handles correctly (maybe leave the rear a little lower if you are unloaded).
  3. Feb 11, 2013 at 10:23 AM
    danteisme
    South Western PA
    2.7 4x4 standard cab
  4. Apr 13, 2016 at 3:33 PM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    I have the 2.7L access cab w/ 265/70/16 C-rated BFGs. I keep them right at 30 front & back, wearing perfectly evenly, and a nice ride.
    I had a set of Dynapro ATMs and they're the single worst tire I've ever had - horrible in the rain (thought I'd slide on every corner) horrible in the snow and even though they lasted 76,000miles, the compound is trash.
  5. Apr 14, 2016 at 10:32 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Tires and weight of truck make a big difference. I have 265/70/16 in load range D. Door sticker says 46. I have kept 46 in them and just passed 65k with even wear. I could probably make 75k before they got to the wear bands but I will replace before deer season. Ranch roads really chew tires up.
