tire pressure 245 75R16
Discussion in 'Wheels & Tires' started by VBdiver58, Oct 9, 2023.
  1. Oct 9, 2023 at 7:30 PM
    VBdiver58
    VBdiver58 [OP] Well-Known Member
    Virginia
    1999 Tacoma xtra cab 4x4 2.7L
    16" Toyota rims
    haven't been able to find info for a recommended tire pressure on Michelin Defender LTX 245/ 75R16 .
    my 99 Tacoma Xtra cab 4x4 came with P225/75R15 with a psi rating of 26 fwd & 29 rear. I have since upsized my wheels.
    26 & 29 psi seems low . Costco only fills to what is on the door tag . I get it but it's not accurate.
    anyone know if 245/75R16 were standard equipment for any 1st or 2nd generation Tacomas and the factory tire pressure specifications ?
  2. Oct 9, 2023 at 7:32 PM
    tcjacado
    tcjacado Well-Known Member
    32 to 33 lbs are sufficient. Higher tire pressure equals better gas milage, but tires will suffer. Just as they are probably suffering from to low of pressure. My tpms lights up at about 22 psi.
    Yes, the 2nd Gen sr5 came with 16" wheel and the same tire size.
    VBdiver58[OP] likes this.
  3. Oct 11, 2023 at 11:32 AM
    Joel114
    Joel114 Well-Known Member
    Western Mass
    2023 TRD OR MT MGM
    You could also do the caulk method to check just to see if they would wear weirdly
    VBdiver58[QUOTED][OP] likes this.
