Tire plugging question…
Discussion in '3rd Gen. Tacomas (2016-2023)' started by High_Desert_Rex, Nov 11, 2021.
  1. Nov 11, 2021 at 2:02 PM
    High_Desert_Rex
    High_Desert_Rex [OP] Well-Known Member
    Adam
    SLC and Kanab, UT
    Cement ‘21 TRDORDCSB w/GFC - Red ‘19 TRDORDCSB6MT w/GFC (rip)
    GoFastCampers Platform Camper
    Any advice on plugging this? I’ve plugged tires before, but only in the tread area not the sidewall like this. I know tire shops won’t do it. E4EFB9F5-96D8-4492-B14F-7493AE014ED3.jpg
  2. Nov 11, 2021 at 2:05 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Plug it, use it as a spare. :anonymous:
  3. Nov 11, 2021 at 2:06 PM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Plug it, ride on
    Bleep100, CusterFan, boston23 and 2 others like this.
  4. Nov 11, 2021 at 2:17 PM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    Plug it the same as you would on the tread.
    CusterFan, boston23 and Mark77 like this.
  5. Nov 11, 2021 at 2:19 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Can u repair it from the inside? I would try that way 1st.
    kgilly likes this.
  6. Nov 11, 2021 at 2:21 PM
    MGMDesertTaco
    I'd replace it. I don't like plugging tires especially when it's on the sidewall. I suppose you could save it for a spare, but I wouldn't.
  7. Nov 11, 2021 at 2:25 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Hmmmm.......
    Suggest a plug as a temporary repair. Then to a tire shop for a patch inside the tire.
    Both the plug and patch are a bit on the iffy side, because the hole is in a high flex area of the tire, known as the shoulder.
    Relegate that tire to Spare tire duty.
  8. Nov 11, 2021 at 2:26 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    ^^ This. I won't have a tire with sidewall damage repaired. If it's tread and can be patched then ok, but not sidewall damage.
  9. Nov 11, 2021 at 2:27 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    tire shop might not do it if the wheel is on the vehicle due to liability concerns
    SR-71A and TRD2021SPORT like this.
  10. Nov 11, 2021 at 2:37 PM
    High_Desert_Rex
    Adam
    SLC and Kanab, UT
    yup, nobody will do it. I’ve plugged it for now, seems pretty solid. Going on a trip in a week. I’d buy a new tire (I hate to replace just one, but this set only has 6000 miles on it), but nobody has a 255/75/17 ko2 in stock or can get one in stock before my trip. My spare which is on currently is a 265/75/16 wildpeak.
  11. Nov 11, 2021 at 2:40 PM
    Knute
    Might be a good time to rent a car........
    just had a 2nd thought.
    What is the difference in the outside tire diameter between the spare and the 17s??
    I could be wrong, but calculation wise, the diameter differs by 0.4 inch. You may be able to slide by with the spare on the rear.
  12. Nov 11, 2021 at 2:42 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    that dont look too deep, just pull it out, i bet that didnt puncture the tire
    if you want just spit on it before pulling it out and see if you get any bubbles
    Tacosha, boston23 and Mark77 like this.
  13. Nov 11, 2021 at 2:55 PM
    High_Desert_Rex
    Adam
    SLC and Kanab, UT
    ya, it’s not bad. I actually have all 4 old tires/rims I may just throw on for this trip. Just no tpms, but meh. Definitely not renting a car. This trip is mostly off-road, but we can always take my wife’s forester if we need too.
    Oh it did. The whole reason I noticed is because I’ve had a slow leak for the past few weeks.
    uurx[QUOTED] likes this.
  14. Nov 11, 2021 at 2:57 PM
    High_Desert_Rex
    Adam
    SLC and Kanab, UT
    I plugged it. Letting it sit overnight to see if my plug holds up well. I’m just a little nervous about driving on it, but it’s probably fine. 6F44CFFB-19A7-4C9C-9D68-0BAD5E475491.jpg
    Kev250R likes this.
  15. Nov 11, 2021 at 2:58 PM
    Knute
    Both are better options.
    Toss on the ol' 16s (the set) or roll with the Subaru. Is the Suby easier on fuel???
    Tacosha likes this.
  16. Nov 11, 2021 at 3:07 PM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    I plugged a tire years ago, further down on the side wall then that. I finally wore the set out and that plug held for the life, several thousand miles, of that tire.
    SO, I'd plug that sucker and live on. Worst it'll due is start to leak again.
    SR-71A, boston23 and Mark77 like this.
  17. Nov 11, 2021 at 3:12 PM
    High_Desert_Rex
    Adam
    SLC and Kanab, UT
    Huh, that’s reassuring. The only thing I’m really worried about is it causing some kind of a blowout because it’s kinda on the tire shoulder.
  18. Nov 11, 2021 at 3:13 PM
    High_Desert_Rex
    Adam
    SLC and Kanab, UT
    Ya, I may throw the 16s on. We kinda need the truck for camping. The subie is easier (slightly) on fuel. It drinks 91 premium because it’s a Fozzy XT (turbo). Super fun car to rally on gravel roads thou.
  19. Nov 11, 2021 at 3:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's always worth it to try a plug. Worse case you buy a new tire anyways
  20. Nov 11, 2021 at 3:16 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Toss it and purchase a new one, it’s a liability on a garage to fix that. The damage is on the sidewall.
