Tire install cost
Discussion in 'Wheels & Tires' started by nermalgod, Nov 20, 2010.
  1. Nov 20, 2010 at 5:29 PM
    nermalgod
    nermalgod [OP] Well-Known Member
    Bend, OR
    Offroad boat hauler
    Not going to brag.
    I need new tires. The cost of the rubber is easily compared between shops, but I'm at a loss as to other costs.
    I was just quoted by Sears;
    • Free Mounting
    • Tire Disposal $2 each
    • Tire Balance $13.25 each
    • Rebuild TPMS valves $6.99 each
    • Install TPMS maintenance kit $5.00 each
    • Alignment $69.99
    There are a couple items that I wonder if I even need. Do valves need to be rebuilt every time tires are changed? That's almost $50 for parts and labor. I feel like the $53 to balance the tires is a little excessive too and the alignment is just not needed.
    Or am I completely wrong and should be paying $180 beyond the cost of tires?
    The tires are 265/75/16 General Grabber AT2 priced at $149 each.
  2. Nov 20, 2010 at 5:31 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you try calling different shops?
  3. Nov 20, 2010 at 5:33 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    why would they rebuild the tpms valves?
    i just got tires installed and he said he didnt replace the valves since we have tpms
  4. Nov 20, 2010 at 5:39 PM
    macjedi
    macjedi Member
    Robert
    Sacramento, California
    2011 PreRunner SR5 DCLB
    I just got new tires a few hours ago from Americas Tire Co, and they didn't charge me for alignment or TPMS.
    My receipt shows:
    Qty: 4 Environmental Fee $1.75
    Qty: 4 Lifetime Spin Balancing $16.00
    Qty: 4 Lifetime Repairs Included $.00
  5. Nov 20, 2010 at 5:42 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    All of this is up to you if you want to have it done, except for the tire disposal and balancing. Both the $2 disposal and the $13 balancing fees are very average.
    As far as having your TPMS valves rebuilt, that's usually a maintenance item that should be done every once in awhile, as they use a rubber o-ring as a sealer and can wear out like any other gasket. The rebuild kit usually includes a new aluminum sleeve too. You can probably get away with using your existing valves as-is, or you can have them rebuilt for peace of mind against future leaks. Totally up to you.
    As far as alignment goes, same thing. How do the tires coming off the truck look? Are the evenly worn? If they are, you're probably fine. If they aren't, you obviously will want an alignment done so that you don't prematurely ruin your new tires.
  6. Nov 20, 2010 at 5:46 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    They wouldn't have charged you for an alignment because Americas Tire doesn't perform alignments. Being that you have a 2011, you shouldn't need an alignment or TPMS rebuild. The OP has a 2006 though, so he may need both.
